Yorgee Posted July 5, 2007 Share Posted July 5, 2007 I was going to buy the Palnet spacer but thought I'd try and make one myself. Was tough to make the 60mm hole, but I think it'll work. Quote Link to comment Share on other sites More sharing options...
hughdogz Posted July 5, 2007 Share Posted July 5, 2007 How did you get the hole to end up round?? Quote Link to comment Share on other sites More sharing options...
Yorgee Posted July 5, 2007 Author Share Posted July 5, 2007 First I drilled a hole on the inside that was about 50mm. Then cut that out. After that I used a grinder attached to an air compressor to enlarge the hole. Griding the 60mm I had traced from a gasket I made, then polished it. Quote Link to comment Share on other sites More sharing options...
Cruez Posted July 5, 2007 Share Posted July 5, 2007 I don't quite understand the need for a spacer.... I put mine on without one.. http://www.cruez.com/gallery/displayimage.php?album=3&pos=7 Quote Link to comment Share on other sites More sharing options...
Yorgee Posted July 5, 2007 Author Share Posted July 5, 2007 I don't quite understand the need for a spacer.... I put mine on without one.. http://www.cruez.com/gallery/displayimage.php?album=3&pos=7 Yeah, I tried putting the throttle body the way you have yours cruez, but I ended up with a small exposed hole from the intake. When the throttlebody is flipped so that the throttle linkage on the opposite side, the throttle hits the intake, and you need the one inch spacer. Atleast, I think that is why you need it. Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 5, 2007 Share Posted July 5, 2007 I used a 65mm Rotobroach, and in the past have used Blu-Mol hole Saws from Home Depot. With lots of cutting oil and a drill press, you go right through! Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted July 5, 2007 Share Posted July 5, 2007 man... you really ought to invest in a set of hole saws and a set of drum sanders. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted July 5, 2007 Share Posted July 5, 2007 Alright! Another drill, hacksaw, and rat-tail file guy!!! We don't need no milling machine! Just give us a week and we'll make you a semi precise billet whatever. Nice handiwork. Quote Link to comment Share on other sites More sharing options...
Yorgee Posted July 5, 2007 Author Share Posted July 5, 2007 Alright! Another drill, hacksaw, and rat-tail file guy!!! We don't need no milling machine! Just give us a week and we'll make you a semi precise billet whatever. Nice handiwork. Haha thanks cygnus, no need to spend extra money on tools when you have patients to use the tools you have. But I did have one of those 65mm drill holes Tony D, but I thought it would be too big. So I just went the next size down. Quote Link to comment Share on other sites More sharing options...
