MoNkEyT88 Posted June 10, 2008 Author Share Posted June 10, 2008 Apply wax, PVA release and let dry. Apply gel coat.. then run out of gel coat, and have to purchase more. Turns out you'll need about 2 qt's per door. Quote Link to comment Share on other sites More sharing options...
73DatsunZ Posted June 11, 2008 Share Posted June 11, 2008 The CF dash looks awesome. I want. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted June 12, 2008 Author Share Posted June 12, 2008 Me too.. Recently I've come to appreciate all the hard work that goes into producing the molds, and CF parts.. I don't even have any CF parts completed for the datsun, and I've got countless hours into it already. Not to mention expenses. Composite prices are up, and the consumables used for the molds, and products aren't cheap. You can look at a part and assume it wouldn't cost much, but when you add up the gel coat, fiberglass, epoxy and man hours used to make just the mold, then add the vacuum pump, epoxy, carbon fiber, clear gel coat, or clear coat, peel ply, breather material and flow material that is used to create the final part, it's kind of overwhelming. So... respect for those guys who've done it on their own, or those of you doing it for a living. Quote Link to comment Share on other sites More sharing options...
johnc Posted June 12, 2008 Share Posted June 12, 2008 Glad someone out there understands this. Add in the cost of heat cured epoxy resin, bags, and a pump. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted June 13, 2008 Author Share Posted June 13, 2008 Well John, I hope my parts turn out as good as yours. What kind of epoxy are you using that cures in an autoclave or oven? Is it a two part epoxy, or heat activated catalyst? Quote Link to comment Share on other sites More sharing options...
johnc Posted June 13, 2008 Share Posted June 13, 2008 Benchmark Composites makes the parts for me, I take no credit for the quality of the parts I sell. I do own the molds. Stan uses an epoxy resin that's almost solid at room temperature, it needs to be heated to get it out of the container and applied and then heated to cure. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted August 5, 2008 Author Share Posted August 5, 2008 I'm at just over a year on this project. LOL, not really much going on now, I've put it on the back burner while I'm buying a house. Also, might be picking up a Miller MIG welder off craigslist. It should be more than sufficient for the roll cage, and the frame. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 1, 2008 Author Share Posted September 1, 2008 I need to keep reminding myself to do things, So I'm going to make a list. 1. Order parts from TABCO. 2. Order suspension coil over kit. 3. Finish floor/sub frame. Okay, I think I'm going to go with the Ground Control coil over kit. I don't know what spring rate I need, but I'm planning on getting the car under #2,000lbs. Anybody got some first hand experience? Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 1, 2008 Author Share Posted September 1, 2008 I've decided to put the carbon fiber fab on hold for a while. I think I need to get the chassis/engine done and get this thing rolling before getting antsy about body parts. Anyways. I'm leaning towards a V8 now. Still got a while to make up my mind on that though. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 11, 2008 Author Share Posted September 11, 2008 More chop chop... Need pretty big flares to fit these tires. They make the 275's on my M3 look like snow tires! I'm leaning towards flares like this, I'll have to make my own from carbon fiber. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 11, 2008 Author Share Posted September 11, 2008 Steel floor kinda. OMGZ, cut by hand, no funz. Close enough, I'm tired. Quote Link to comment Share on other sites More sharing options...
Cobra_Tim Posted September 11, 2008 Share Posted September 11, 2008 Depending on your shocks... look between 275 and 350 lbs for springs. Stagger front to back with a 25-50lb difference. Now thats just a ball park... things like sway bars will have to be thrown into the equation aswell. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 12, 2008 Author Share Posted September 12, 2008 Thanks Tim, I guess I'll just wait and see when I get it kinda assembled. Anyway, I found a guy locally thats parting out a 92 Q45. VH45DE DOHC V8 Also kinda welded the floor pan in, needs more work later. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 13, 2008 Author Share Posted September 13, 2008 The guy said after quoting me that a shop would take 7 hours to remove it, at around 80$ an hour, he couldn't sell it for 375$. (based off of Vh45's on car-part.com with 200,000 miles) O well, I was thinking, the transmission adapters are hard to find/expensive. We'll see later on. Quote Link to comment Share on other sites More sharing options...
Jer260Z Posted September 13, 2008 Share Posted September 13, 2008 Did you have any problems towing with a dolly? Will be moving mine this weekend... Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 13, 2008 Author Share Posted September 13, 2008 Besides getting lost in Madison, and going right up to the capitol to find my bearings. I think we towed it over 150 miles. Just make sure both tow vehicle and the Z are road worthy enough to make it. Quote Link to comment Share on other sites More sharing options...
ab0z Posted September 13, 2008 Share Posted September 13, 2008 7 hours to remove it? Man that's a long time to unplug some wiring and unbolt a transmission. Tell him you'll roll in there and yank that thing yourself! Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 14, 2008 Author Share Posted September 14, 2008 Getting late, too loud to use the saws all or the cut off wheel, so I decided to bring out the impact and pull off my coils. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 17, 2008 Author Share Posted September 17, 2008 How do I know which shocks I have? Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 17, 2008 Author Share Posted September 17, 2008 New stuff. OMG Quote Link to comment Share on other sites More sharing options...
