brokebolt Posted November 7, 2007 Share Posted November 7, 2007 Wow I've seen a lot of intake air filtration systems in my day (maybe not as much as some) I would strongly recommend that if you don't want to use the individual oval cleaners to use a plenum system (like what SKiddell is pedeling) and get a good aftermarket round filter from Summit or Jegs. They are supper cheap at about $26.69 (or so). Search Cone filter. Then mount that bad boy on the end or make a SS pipe and run it out the front and mount the cone on that. Simple easy and a cold air induction kit to boot. If you can weld aluminium you could fab one up in a few hours, simple square box should be fine for the garage monkey... SKiddell I may be intersted in one it the price is right, the Dollar is weak right now so may not be the best time for me. Quote Link to comment Share on other sites More sharing options...
JohnH Posted November 7, 2007 Share Posted November 7, 2007 I got these in from Pierce Manifoulds as I have the Cannon long intake & ther is very little room for any filter boxes. The screens pictured are actually black rubber with silver screens http://www.piercemanifolds.com/airfilters.htm Quote Link to comment Share on other sites More sharing options...
Doc Hawk Posted November 8, 2007 Author Share Posted November 8, 2007 Can you fix that pic, John? I'm getting the dreaded red X on your photo above. Quote Link to comment Share on other sites More sharing options...
JohnH Posted November 8, 2007 Share Posted November 8, 2007 I tried fixing it. I believe the pics are site protected for linking. Anyway the ones I bought are part # 99217.250 in the Weber DCOE section. http://www.piercemanifolds.com/airfilters.htm Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 13, 2007 Share Posted November 13, 2007 Good choice SuperDan! I bought the same ones from CB Performance for my DelLortos. Quote Link to comment Share on other sites More sharing options...
Icehound Posted August 7, 2009 Share Posted August 7, 2009 JohnH said: I got these in from Pierce Manifoulds as I have the Cannon long intake & ther is very little room for any filter boxes. The screens pictured are actually black rubber with silver screens http://www.piercemanifolds.com/airfilters.htm Anyone know if these will fit Mikunis? Quote Link to comment Share on other sites More sharing options...
Icehound Posted September 8, 2010 Share Posted September 8, 2010 This is what I did with mine. I'm going to put an NACA duct in the front of the hood to supply cold air. Quote Link to comment Share on other sites More sharing options...
Icehound Posted December 29, 2010 Share Posted December 29, 2010 Doc Hawk did you ever get these to fit your Mikunis'? If so what part numbers did you install? Thanks Dave. On 8/25/2007 at 6:49 PM, Doc Hawk said: Superdan, I like those a lot. What part # did you buy? I have written them for info; I'd like to see a diagram that shows the mounting points so I can figure out if they would bolt up to my Mikunis, behind the horns. It seems like a 6" assembly would clear my fender well, and provide plenty of headspace for the stacks. Thanks for the link! David Quote Link to comment Share on other sites More sharing options...
Icehound Posted May 29, 2011 Share Posted May 29, 2011 (edited) You will have to right click and open image in a new tab. Edited May 29, 2011 by Icehound Quote Link to comment Share on other sites More sharing options...
Chris Smith Posted November 18, 2020 Share Posted November 18, 2020 (edited) On 8/26/2007 at 5:17 PM, SKiddell said: You could get one of these I supply them (I own the molds and a collegue/friend makes them) to guys in the UK. Full carbon fibre (or glass if required) colours possible. comes with 6 x stainless over centre clips and lip seal Can be connected direct to 80mm cold air feed or cone filter. Expand Hi, I've got triple Mikuni 44s/Harada manifold assembly on the way, for my L24 240Z. I'm looking for an airbox... can you still supply these? Best, Chris Edited November 18, 2020 by Chris Smith Quote Link to comment Share on other sites More sharing options...
madkaw Posted November 19, 2020 Share Posted November 19, 2020 On 11/18/2020 at 6:13 PM, Chris Smith said: Hi, I've got triple Mikuni 44s/Harada manifold assembly on the way, for my L24 240Z. I'm looking for an airbox... can you still supply these? Best, Chris Expand I have this one . I made it myself for my set up since there were no options . I wanted cold/ clean air for my carbs . Not everyone’s taste, but I thought it was cool. I got lots of compliments for it . I would sell it because I’d love to see someone use it . PM me . I ran air horns inside the box Quote Link to comment Share on other sites More sharing options...
