HICKL Posted September 11, 2007 Share Posted September 11, 2007 I under my car removng my broken diff and I noticed that one of my cv boots is twisted as if the shaft jumped a tooth or something. Not knowing what the inside of a cv joint looks like, I don't even know if this is possible. Anybody know? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 11, 2007 Administrators Share Posted September 11, 2007 Only if it is busted. Quote Link to comment Share on other sites More sharing options...
mark Posted September 11, 2007 Share Posted September 11, 2007 Which CV set up do you have? Quote Link to comment Share on other sites More sharing options...
HICKL Posted September 11, 2007 Author Share Posted September 11, 2007 280 zx...I think. Not sure of the origin, all I know is they came stuck in an R200 and had rear disk. Quote Link to comment Share on other sites More sharing options...
mark Posted September 11, 2007 Share Posted September 11, 2007 This is what happend to mine. I've taken apart a set up like yours and I don't think they can fail like mine did. http://forums.hybridz.org/showthread.php?t=124653 Quote Link to comment Share on other sites More sharing options...
HICKL Posted September 17, 2007 Author Share Posted September 17, 2007 I have looked at mine some more and it appears that it defineatly slipped. The boot was for sure twisted but all seems to be in working order. looked under the boot and although I don't really know what I am looking at, all looks to be good. I remember seing the boot twisted under the car so it has been like that for a little while. Is this possible? Is the cv any good? Still seems to function properly. I pulled and pushed on it to see if it could have happened during assembly. I can't get it to move or do anything funny. Can I take it apart for further inspection? If so, how do they come apart? Thanks Jeff Quote Link to comment Share on other sites More sharing options...
Bartman Posted September 17, 2007 Share Posted September 17, 2007 I don't know if these are the same type CV's you have, but this should help explain how to assemble and disassemble them. http://forums.hybridz.org/showthread.php?t=90068 I don't see how it could slip and not be broken. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 17, 2007 Share Posted September 17, 2007 280ZX CVs are different and harder to disassemble and reassemble. Search, I know blueovalz has posted a write up on it before. I too don't think they could possibly slip. The only one that I could see slipping is the R230 setup that people have developed. As far as I know there is no way for the tripod bearings to slide out past their races which would HAVE to happen for it to slip. Otherwise it would break, but not slip. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted September 18, 2007 Share Posted September 18, 2007 Did the joint slip or did the boot just get rotated? Mabe it got hung up on something. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 18, 2007 Share Posted September 18, 2007 Did the joint slip or did the boot just get rotated? Mabe it got hung up on something. I was thinking this too. Maybe a sway bar end link or something. Quote Link to comment Share on other sites More sharing options...
HICKL Posted September 18, 2007 Author Share Posted September 18, 2007 I tried to rotate the boot as I was thinking the same thing. I couldn't get it to move nor where there any marks on it. I remember a few weeks after I put the cv's in, the car developed a weird sound/feel under load in first and second gear. I couldn't figure it out, so I finally just hammered on it a few times figuring I'd break whatever was bad and then fix it. Well, after two hard launches, the noise went away. Who knows... Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted September 18, 2007 Share Posted September 18, 2007 I tried to rotate the boot as I was thinking the same thing. I couldn't get it to move nor where there any marks on it. I remember a few weeks after I put the cv's in, the car developed a weird sound/feel under load in first and second gear. I couldn't figure it out, so I finally just hammered on it a few times figuring I'd break whatever was bad and then fix it. Well, after two hard launches, the noise went away. Who knows... LOL that is the most satisfying way to "diagnose" a problem sometimes... Quote Link to comment Share on other sites More sharing options...
