Accurate Injection Posted December 14, 2007 Share Posted December 14, 2007 Hey Guys: We now have a Tig Welded 7MGE Manifold! 45mm OD to stock size "Oval Ports! Runner length of manifold is 2.75", additional runner length can be had thru our "Length Tuning" Extensions! Throttle Body is 3", Base Plate and horn adds an 3/4", for a total runner length of 6.5" Another 3" to 6" can be added thru Length tuning if desired or needed! Kevin Quote Link to comment Share on other sites More sharing options...
Gareth Posted December 14, 2007 Share Posted December 14, 2007 It looks great, but I'm just wondering - is it really worth to modify the 7M-GE in the NA form? Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted December 14, 2007 Author Share Posted December 14, 2007 The 7MGE is an very good flowing head! Turbo's are not always the answer, especially if your Auto-xing or racing on short tight twisty's! By the time Boost comes on, the N/A guy is around you and 2 turns further up the track! Just my 2 cents! Kevin Quote Link to comment Share on other sites More sharing options...
Gareth Posted December 14, 2007 Share Posted December 14, 2007 OK, I get it, thanks for the answer. I just thought that the 5M and 6M engines are the ones that are more frequently used in NA tuning, but it's good that you're trying to do something else. I'm waiting for pics of a complete setup! Quote Link to comment Share on other sites More sharing options...
olie05 Posted December 14, 2007 Share Posted December 14, 2007 Any manifold you make for these throttle bodies will also bolt up any dcoe style carburetor right? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted December 15, 2007 Share Posted December 15, 2007 this looks great! especially after trying to make my own manifold... very impressive! Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted December 18, 2007 Author Share Posted December 18, 2007 DCOE Carb bolt up? Well not quite! See the DCOE Bolt Pattern has a Conflict with our ITB Design, so and ITB Plate/manifold we build we use the IDF Pattern! Which is the Same as the IDA "The angle across the Bore is Different for DCOE than it is for IDA/IDF" All you would need to do is re-drill the ITB Plate on the Manifold for DCOE, but honestly that is not why we built the 7MGE Manifold! Hahaha! Kevin Quote Link to comment Share on other sites More sharing options...
theianmonster Posted December 20, 2007 Share Posted December 20, 2007 Stop tempting me. I wanted to do something like this on the 7M that's going in my '85 Cressida. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 20, 2007 Share Posted December 20, 2007 Accurate Injection said: The 7MGE is an very good flowing head! I wouldn't say very good, atleast not when comparring them to JZ heads. Maybe a little better than an L though. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted December 25, 2007 Share Posted December 25, 2007 7m heads do NOT flow well, 178 at 25" on the intake track, when a STOCK P90 flows 172 at 25" of water. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 25, 2007 Share Posted December 25, 2007 You never told me you did a 7M head. I figured they flowed about the same as a L head as the power to boost was about the same. Kevin, have you put this on any of the Supra boards? Supramania is probably the friendliest and will let you post stuff in the vendor section without paying, or atleast they used to. Supraforums is another story. Quote Link to comment Share on other sites More sharing options...
theianmonster Posted December 26, 2007 Share Posted December 26, 2007 How much is this piece going to cost? Quote Link to comment Share on other sites More sharing options...
supra goddess Posted December 28, 2007 Share Posted December 28, 2007 huh? How does a 7M DOHC 24 valve head not flow well? Especially when compared to a SOHC 12 valve head? I really would like to know, the Supra guys have been arguing over the 5M 12v versus 7M 24 head flow for YEARS. Personally, I don't give a damn how good or bad the 7M head flows, I think it's ugly. If I ever do go 3.0 liter, I'm doing it with a 7M block and 5M head Anyway, great job on that manifold, looks very nice! Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 28, 2007 Share Posted December 28, 2007 supra goddess said: huh? How does a 7M DOHC 24 valve head not flow well? Especially when compared to a SOHC 12 valve head? Port design. How does a 7m flow so much less than a 2jz and how does a JZ head flow less than some Honda heads. Quote Link to comment Share on other sites More sharing options...
Pete84 Posted December 31, 2007 Share Posted December 31, 2007 Shot in the dark, but is the port design aiming for say, torque on the 7M? Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted December 31, 2007 Author Share Posted December 31, 2007 Clifton: We have a Guy all over the Super/Toy Forums permoting for us! Good Guy and he means well, he has that manifold now testing it! Price? It's all located on our .biz website! Guys remember the 7m came out 20 years ago! It was probably designed 2 years prior to that! F1 has had an impact on Honda to say the least! Kevin Quote Link to comment Share on other sites More sharing options...
MrWOT Posted January 28, 2008 Share Posted January 28, 2008 Thanks for the 7MGE love, with MAFT-pro working on the GE now, this is a great addition! Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted January 28, 2008 Author Share Posted January 28, 2008 Hey MrWOT: NP!!!!!!!!!!!!!! We have so many different projects going it's unreal! Our Philosophy is to find the Missing Link between a good application and our ITB's and do a little investment on our end, and in this case it was a Good Manifold that was needed! Working on a Billet Manifold and Direct to HEAD fitment for the E36/M50/M52 Motors now! Have our fabricator building a Turbo/M52 in a E30 Chassis and we are picking up a 95 E36 325is in the next week or 2 for a test bed! Life is Good! Kevin Quote Link to comment Share on other sites More sharing options...
