theianmonster Posted December 17, 2007 Share Posted December 17, 2007 I thought I might as well join in and let everybody know about my project that I have going on. By the way, this is my drift car... A little background on the car. I bought the car for $900 last January, and spent a good amount of time getting it running, doing some mild suspension, fixing the brakes, and putting the air dam off of my old car on it. Specs: - Tokico Illumina Shocks - Eibach Pro-Spring Kit - Nismo T/C Kit - Nismo Steering Couplers - Long-nose R200 Rear Differential - Rear Sway Bar - BRE Hangers - Poly Bushings Here are some pictures before I tore the car apart: Then one day, after a few beers, my buddy convinced me to go for the 1JZ-GTE swap: Then I gave in again and did the S13 dash swap, not complete, obviously: And test fitted some 15x10 -38 Diamond Racing Wheels. I will be running the exact width and offset, but in a 16" rim: Here are the specs on my motor so far: - 1JZ-GTE from Toyota Chaser - W58 5-Speed (Came out of my friend's 1JZ powered MX83 Cressida, 400rwhp) - XTD Stage-3 Clutch - 2JZ-GE OEM Flywheel - OEM Flywheel Bolts - 2JZ-GE Bellhousing - MKIV Clutch Fork - 5M Starter - Megasquirt w/ 2-Step and Boost Cut I have the whole front of the motor to finish. I'll keep you guys updated. - Ian. Link to comment Share on other sites More sharing options...
Gareth Posted December 17, 2007 Share Posted December 17, 2007 Looks good, but don't you think that the car could use some bigger brakes? Stock brakes just won't cut it with a high-powered turbo engine... Link to comment Share on other sites More sharing options...
Pete84 Posted December 17, 2007 Share Posted December 17, 2007 Nothing more terrifying than being on a winding mountian road with fading brakes . . . When you REALLY need to break for the next corner, and it is all downhill for several more miles. You going to use the swap directions from this sub-forum? Would be interesting to get some feedback, it looks very straight forward. Might get the earlier 1JZ with the TT's and call it a 2JZ Supra swap . . . . and get it smoged Link to comment Share on other sites More sharing options...
JustinOlson Posted December 18, 2007 Share Posted December 18, 2007 I love it. Your car is very badass looking! Justin Link to comment Share on other sites More sharing options...
theianmonster Posted December 19, 2007 Author Share Posted December 19, 2007 I have brake plans, don't worry. Thanks for the feedback. Link to comment Share on other sites More sharing options...
timbo1jz Posted December 27, 2007 Share Posted December 27, 2007 very cool man, I am in the same boat as you. Get some good pics during your build up! Link to comment Share on other sites More sharing options...
theianmonster Posted April 16, 2008 Author Share Posted April 16, 2008 Finally got some time to work and order some parts for this damn car, motor should be in next week on my custom crossmember. - Ian. Link to comment Share on other sites More sharing options...
ghost1530 Posted April 25, 2008 Share Posted April 25, 2008 sweet...dude. i'm planning on doing a 2jz into my 240z. i want to know if a 1jz tranny bolts onto a 2jz motor? Link to comment Share on other sites More sharing options...
ShaggyZ Posted April 25, 2008 Share Posted April 25, 2008 sweet...dude. i'm planning on doing a 2jz into my 240z. i want to know if a 1jz tranny bolts onto a 2jz motor? Yes, but look around and you'll find some info on this. The short: R154 requires hard-to-find bellhousing; W58 is easy. Link to comment Share on other sites More sharing options...
timbo1jz Posted April 26, 2008 Share Posted April 26, 2008 the bellhousing is not hard at all to find. My friend sells them from his shop as do a lot of other shops. They are pricey though. Driftmotion.com Link to comment Share on other sites More sharing options...
ShaggyZ Posted April 26, 2008 Share Posted April 26, 2008 the bellhousing is not hard at all to find. My friend sells them from his shop as do a lot of other shops. They are pricey though. Driftmotion.com Right. I meant hard to find used. You can buy them new for under $400. Link to comment Share on other sites More sharing options...
Z-Gad Posted April 27, 2008 Share Posted April 27, 2008 Right. I meant hard to find used. You can buy them new for under $400. ... and that's cheaper than having to replace your first broken W58 Link to comment Share on other sites More sharing options...
ShaggyZ Posted April 27, 2008 Share Posted April 27, 2008 ... and that's cheaper than having to replace your first broken W58 Very true. Actually, the R154 I have now I basically got for free plus $150; plus, it came with a new stock clutch, shifter and driveshaft. Previously, I was looking at spending ~$700 for an ebay R154 with the way they sell there. I'd say I'm off to a good start on my budget build Link to comment Share on other sites More sharing options...
shinji Hirako Posted April 19, 2009 Share Posted April 19, 2009 Is it ok for me to steal you color scheme idea for my 240Z Project! Link to comment Share on other sites More sharing options...
shinji Hirako Posted April 22, 2009 Share Posted April 22, 2009 Update!!! Please Update! Link to comment Share on other sites More sharing options...
WizardBlack Posted April 24, 2009 Share Posted April 24, 2009 Great looking setup. Update with PICS! Link to comment Share on other sites More sharing options...
piston Posted April 24, 2009 Share Posted April 24, 2009 pics didnt work or me? dont see the rest of the pics? Link to comment Share on other sites More sharing options...
orange76 Posted June 17, 2009 Share Posted June 17, 2009 will that suspension setup work fine with the 1jz cause im looking to do a swap and i have the illumina shocks and the eibach springs? thanx Link to comment Share on other sites More sharing options...
aziza z Posted June 17, 2009 Share Posted June 17, 2009 Last Activity: January 24th, 2009 02:52 PM Ill try to get his attention on FB. Link to comment Share on other sites More sharing options...
theianmonster Posted June 18, 2009 Author Share Posted June 18, 2009 Yes,this suspension will work fine. I was going to upgrade to custom Stance coilover set up. THIS CAR HAS BEEN SOLD. I never completed the project due to money issues. I'm sorry there haven't been updates. I WILL build a 1JZ 240Z in the future. Link to comment Share on other sites More sharing options...
