L26 cam into L28ET
MazterDizazter
Hey guys, I'm trying to do an L28ET (w/ P90A head) swap into my '73 240Z. I'm on a tight budget because I'm saving up for a Z32 tranny and all the necessary swap parts. I read here (http://www.atlanticz.ca/zclub/techtips/cam/index.htm) that the L26 cam is the largest stock L-series camshaft. Well it just so happens that my Z has an L26 in it currently; hurray! I have to double check the head code to confirm, but I was thinking of putting that camshaft into my L28ET before installing it into the car. I assume this isn't a drop-in affair. What would I have to do to make this work? Does timing come into play?
  • Administrators
There is a 50/50 chance your P-90A has the hydraulic cam. Some P-90A heads still had mechanical lifters.
Click ME to see a P-90A with mechanical cam
Good luck,
Paul
Edited by BRAAP
New info suggesting other than what I orignally reported. Those comments deleted.
