1sick72z Posted February 20, 2008 Share Posted February 20, 2008 wasn't sure which year/model the E88 heads came out of? Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted February 20, 2008 Share Posted February 20, 2008 http://www.zcluboftexas.org/128combo.html 72 240Z LARRY Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 20, 2008 Share Posted February 20, 2008 I've seen them on 73's and 74's. 74's had the larger ex valves. Quote Link to comment Share on other sites More sharing options...
X64v Posted February 20, 2008 Share Posted February 20, 2008 It's a labeling issue. The N33 and P50 listed on the site are labeled E88 on the head itself. Quote Link to comment Share on other sites More sharing options...
1sick72z Posted February 20, 2008 Author Share Posted February 20, 2008 so it's a came off a 2.6 liter or 2.8? Quote Link to comment Share on other sites More sharing options...
Mikelly Posted February 20, 2008 Share Posted February 20, 2008 I saw several on 2.6 motors that were stock and didn't appear to be worked on over the years. Mike Quote Link to comment Share on other sites More sharing options...
1sick72z Posted February 23, 2008 Author Share Posted February 23, 2008 o.k.. so today took the valve cover off and checked for any stamps or markings to see if it was an aftermarket cam or not... the markings on the end firewall side had a "A" marking and some small numbers on it not sure what numbers can't tell.. then it says "DEL......." DEL something. can't see it, no room for me to see clearly... Quote Link to comment Share on other sites More sharing options...
ozconnection Posted February 23, 2008 Share Posted February 23, 2008 grab a small mirror for those cam id's.....wifey might have one for her makeup....dont forget to clean the greasy fingermarks or you'll be toast man!!!!! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted February 23, 2008 Share Posted February 23, 2008 my car had the stock engine and head and it came with an e88 from every thing ive read the 260z came with the e88 that had the larger exhaust valves and the cam has the C stamped on it Quote Link to comment Share on other sites More sharing options...
1sick72z Posted February 23, 2008 Author Share Posted February 23, 2008 i'm just wondering if i have an aftermarket cam or not because one of the worksheets in the glove compartment said "non stock cam" and "fix timing". i'm just wondering if it still has the cam or not... i'll check again tomorrow... Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 23, 2008 Share Posted February 23, 2008 Measure a lobe. It would be the fastest way to know if the lift was changed. Quote Link to comment Share on other sites More sharing options...
1sick72z Posted February 23, 2008 Author Share Posted February 23, 2008 Clifton said: Measure a lobe. It would be the fastest way to know if the lift was changed. maybe that's the easiest way because theres' no way i can see the marking unless i take the camshaft out... i'll borrow my school's dial caliper and measure it on the weekdays.. Quote Link to comment Share on other sites More sharing options...
