the start of the B.customs Z has begun..2jz 1000hp
Overkill Z
  • Replies 465
Posted Images
12 minutes ago, Nelsonian said:
Could you elaborate a little more on this as opposed to an aftermarket option?
Having the oversized intake manifold made it really touchy on throttle tip in. So I went from a 100mm to a 90mm throttle body on a stock manifold.
the stock manifolds actually flow well enough for over 1000hp
Thank you for your input as I find your first hand experiences as tremendously invaluable info for my 2J build. I am in no way trying to build something with your power goals (550+ high boost on E-85) and am certain I will run the stock intake. It will also save a nice amount of money as most aftermarket intakes are not cheap. Now if I could just make up my mind as to go forged rods and pistons or cleaned up stock bottom end. I have everything else for the top end minus the intended port work. Thanks again....
You’ll do just fine on a stock bottom end at those numbers.
  • 1 month later...
