freakshow Posted July 21, 2008 Share Posted July 21, 2008 I have a 1990 infiniti m30 with new brakes, struts, bearing ect. in the suspension, I am in the process of going through the suspension of my 79 datsun, I was wondering if anyone knew if I could use the parts off of the infiniti on my datsun, I read on f131club that the 280zx stuts make the m30 sit higher, i was thinking the infiniti parts would lower my dastun, but im not sure about the fronts, and the brakes, they are much bigger on the infiniti, and i would love to change them over, I have a set of 16 inch wheels and will be ordering spacers very soon, I have both cars now, will be tearing down the infiniti soon in prep of sbc swap, already test fit engine, looking for a solid axle to put in rear, and suspension parts for the infiniti, everything is being gutted out of the ininiti, so I have all those parts at my disposal Quote Link to comment Share on other sites More sharing options...
freakshow Posted July 25, 2008 Author Share Posted July 25, 2008 going to start tearing the rear end out from under the infiniti tomorrow, I like the bigger brakes, and the cv shafts. overrall width of the two cars is similar, just over 60 inches, but the rear suspension crossbember on the infiniti is about 4 inches wider, control arm mounting points are very close to the same width, and the control arms are set up almost identical, hoping the infiniti struts will lower my car 1-2", and be stiffer, given the weight difference of the two cars, maybe control rear end dive a little. Quote Link to comment Share on other sites More sharing options...
freakshow Posted May 9, 2009 Author Share Posted May 9, 2009 So, after almost a year of running on wore out 280zx springs in the rear, and cheap ass gabriel struts, I got fed up with my noodle suspension and pulled the infiniti strut assemblys. The things bolted right in. Got maybe a half an inch of drop, if that. The Infiniti springs are slightly stiffer, but not excessive, and I now have three way adjustable struts in the rear, so far I have only used the stiff and soft settings, but the soft is good for driving, and the stiff is good for handling. I am going to pull the fronts off of the infiniti tomorrow. The springs look like they are very close, but might be too stiff, as the zx fronts are still plenty stiff. I will post some pics of the car soon. Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted May 9, 2009 Share Posted May 9, 2009 I find that interesting, I also think its unusual no one replied to this last year. Quote Link to comment Share on other sites More sharing options...
freakshow Posted May 9, 2009 Author Share Posted May 9, 2009 I imagine the reason I got no response is because the m30 is even harder to find parts for than the 280zx. Quote Link to comment Share on other sites More sharing options...
freakshow Posted May 9, 2009 Author Share Posted May 9, 2009 http://s699.photobucket.com/albums/vv351/freakshow_mcnuts/datsun/ Quote Link to comment Share on other sites More sharing options...
260DET Posted May 10, 2009 Share Posted May 10, 2009 Would that be the Z31 suspension I wonder, apparently it was an improvement on the S130's. Had the squat angle reduced. Quote Link to comment Share on other sites More sharing options...
freakshow Posted May 10, 2009 Author Share Posted May 10, 2009 You probably already know this, but the chassis code for the m30 is f31. I dont know how close the f31 chassis is to the 300z, but I know that it looks almost identical to the 280zx suspension. I didnt get much of a chance to drive the m30, so I couldnt compare the two. So far the only things I have changed are the strut assembly's. The strut mounting points on the m30 arms are about an inch higher, hence my assumtion that the 280zx would be lowered. Other than that, I dont know what is different as far as actual part dimensions, and I will not know until I get into the m30 more. Quote Link to comment Share on other sites More sharing options...
frank280zx Posted May 12, 2009 Share Posted May 12, 2009 apparantly the rear a arms widen the track and correct for camber on an extremly lowered car. Talk to mcadam he did it aswel on his Quote Link to comment Share on other sites More sharing options...
freakshow Posted May 19, 2009 Author Share Posted May 19, 2009 I have been driving the car now for a couple weeks with the infiniti struts. I now drive with the struts set on hard all the time. The car is much more responsive and sticks a lot better around corners. The combination of the infiniti spring and struts, and the sumitomo tires is absolutely incredible. If you are looking to maintain a stock ride height, but get a better more responsive ride I would definitly reccomend this setup. The rear end squat on acceleration is almost nothing now. The car hooks up very well, and doesnt break traction nearly as easy as before. Good stuff. Cornering is incredible. Quote Link to comment Share on other sites More sharing options...
freakshow Posted December 21, 2010 Author Share Posted December 21, 2010 Little update, broke a stub shaft in the early part of the summer, so I took the whole control arms, and c.v. shafts, and pig out of the Infiniti, and bolted them to the Datsun crossmember. The parts bolted on and it only needs some slight adjustments to the toe, maybe some to the camber. I have to have a driveshaft made up because the flange on the pig is different, but I needed a new driveshaft anyway, U-joints were bad. Gonna get one made up with replaceable U-joints. Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted December 22, 2010 Share Posted December 22, 2010 Little update, broke a stub shaft in the early part of the summer, so I took the whole control arms, and c.v. shafts, and pig out of the Infiniti, and bolted them to the Datsun crossmember. The parts bolted on and it only needs some slight adjustments to the toe, maybe some to the camber. I have to have a driveshaft made up because the flange on the pig is different, but I needed a new driveshaft anyway, U-joints were bad. Gonna get one made up with replaceable U-joints. You should really post some pictures up. Quote Link to comment Share on other sites More sharing options...
bluezx Posted December 23, 2010 Share Posted December 23, 2010 I saw an M30 at my local junkyard recently... Looks like I'll have to revisit it after X-Mas. Thanks for the info, pics would be nice. Quote Link to comment Share on other sites More sharing options...
freakshow Posted January 18, 2011 Author Share Posted January 18, 2011 I will post some pics up soon, I have to pull the rear end back out to address the toe issue. I live in Michigan and its a little cold to work in the garage with no heat. Quote Link to comment Share on other sites More sharing options...
Calico Posted January 18, 2011 Share Posted January 18, 2011 this is very interesting Quote Link to comment Share on other sites More sharing options...
freakshow Posted March 5, 2011 Author Share Posted March 5, 2011 Got the driveshaft done by D&R Driveline. Going to start on it again this week, supposed to get a slight warm up.. I will start posting pics as I go. Quote Link to comment Share on other sites More sharing options...
freakshow Posted March 8, 2011 Author Share Posted March 8, 2011 Here are a couple pics. one shows unfixed toe, other shows the camber. These are just from bolting the parts together, Infiniti arms on Datsun crossmember. I have to pull the whole rear out to slot the arms to correct toe. The camber is much worse after the car has been moved..I had just jacked the rear up and set it back down before the pics. Also a pic of the new driveshaft. Quote Link to comment Share on other sites More sharing options...
freakshow Posted May 7, 2011 Author Share Posted May 7, 2011 (edited) OK, I am ready to have the crossmember modified for the Infiniti swap. I am going to use the Infiniti crossmember, control arms, differential, and cv shafts. I was looking for bushings to use because I cant get the old ones out to try to save them, haven't tried heat, but that will destroy the bushings anyway. The Infiniti bushings are bigger around, so I think they will add too much slop, and I think the smaller Datsun bushings will be easier to work with as far as spacing on the crossmember. I haven't been able to find a 280zx specific bushing for the subframe and I was wondering if anybody had a part number or something close. I am cutting the ends of the crossmember off and having new mounts welded on so outer diameter doesn't matter too much..but the inner diameter does as this has to mount on the original bolts in the car. Edited May 7, 2011 by freakshow Quote Link to comment Share on other sites More sharing options...
macambra Posted October 27, 2011 Share Posted October 27, 2011 OK, I am ready to have the crossmember modified for the Infiniti swap. I am going to use the Infiniti crossmember, control arms, differential, and cv shafts. I was looking for bushings to use because I cant get the old ones out to try to save them, haven't tried heat, but that will destroy the bushings anyway. The Infiniti bushings are bigger around, so I think they will add too much slop, and I think the smaller Datsun bushings will be easier to work with as far as spacing on the crossmember. I haven't been able to find a 280zx specific bushing for the subframe and I was wondering if anybody had a part number or something close. I am cutting the ends of the crossmember off and having new mounts welded on so outer diameter doesn't matter too much..but the inner diameter does as this has to mount on the original bolts in the car. Where are you on this modnow? Any pics available? I'm thinking of doing this myself. Quote Link to comment Share on other sites More sharing options...
freakshow Posted November 29, 2011 Author Share Posted November 29, 2011 Where are you on this modnow? Any pics available? I'm thinking of doing this myself. no pics yet.. been working 70 -80 hours a week.. no time to work on anything.. Quote Link to comment Share on other sites More sharing options...
