srbigbutt Posted August 14, 2008 Author Share Posted August 14, 2008 Just wanted to share a couple more pics of the car lowered now! I cut the stock springs for now. I was getting tired of the 4x4 look and I probably won't buy new shocks and springs for a little while. I think it looks a hell of a lot better. I do get a little rubbing in the back over big bumps, but I think with a stiffer setup and rolling the lip I will be ok. Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted August 15, 2008 Share Posted August 15, 2008 Looks Better! How many coils did you cut off? From the top or bottom of the spring? Justin Quote Link to comment Share on other sites More sharing options...
bobbyc Posted August 15, 2008 Share Posted August 15, 2008 looks good! really like the new look! Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted August 15, 2008 Author Share Posted August 15, 2008 Thanks. I suddenly love taking pictures of my car. I cut 1.5 springs all around from the top. Ride quality didn't change to much. May have actually improved. But I still want it a little stiffer but the same ride height. Any suggestions? Quote Link to comment Share on other sites More sharing options...
HoustonZ Posted August 15, 2008 Share Posted August 15, 2008 The lowered look makes all the difference in the world! Quote Link to comment Share on other sites More sharing options...
Devilcat Posted August 15, 2008 Share Posted August 15, 2008 That there car looks good now boy and it all ties in well. Glad the hear that the ride has no degradation and perhaps a improvement. Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted August 16, 2008 Author Share Posted August 16, 2008 I also added the new round chrome mirrors which fits in nicely with the polished lip on the wheels. I would like to get some 240z bumpers soon to enhance the look. Also did some interior work also. Just refinished a used 240z steering wheel I bought. Quote Link to comment Share on other sites More sharing options...
datfreak Posted September 29, 2008 Share Posted September 29, 2008 hi, Those wheels look awesome-- thankyou for posting these pics. Im keen on these wheels for my 71' 240z, so im curious on how tight of fit it is. How close to the struts(front and rear) and guard lips? Can you get full lock both ways with steering? You said it rubs abit after you lowered it, will guard rolling fix this? Do you think 235/45/17 tyres would fit? (the local made cars use this size so they are dirt cheap- ie $115 Au) I read that someguy had to use sticky balance weights because knockon ones rubbed- now thats close!! I'm being anal about this as I'm in Australia and its a LONG way to send these wheels and I wanta be sure that they fit.. thankyou scott Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted September 29, 2008 Share Posted September 29, 2008 hi,Those wheels look awesome-- thankyou for posting these pics. Im keen on these wheels for my 71' 240z, so im curious on how tight of fit it is. How close to the struts(front and rear) and guard lips? Can you get full lock both ways with steering? You said it rubs abit after you lowered it, will guard rolling fix this? Do you think 235/45/17 tyres would fit? (the local made cars use this size so they are dirt cheap- ie $115 Au) I read that someguy had to use sticky balance weights because knockon ones rubbed- now thats close!! I'm being anal about this as I'm in Australia and its a LONG way to send these wheels and I wanta be sure that they fit.. thankyou scott i'll comment on the tire size. i have a 17x8.5" wheel on my z [check pics in my gallery] and have run the 235.45.17 with no problem. if memory serves me correctly the tire sidewall was just about even with the lip on the rim [they didn't bulge out]. currently running 245.35.17, and the tire sidewall bulges a bit beyond the rim lip [gives me a bit of 'curb' protection]. i'd guess that the 235 would be the widest you could run with this rb-r wheel unless you milled the +4 off the back of wheel and ran coilovers or your tire would probably hit either; fender, strut or both. Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted September 29, 2008 Author Share Posted September 29, 2008 I'm not going to lie. The fit is tight. The front is extremely tight to the spring perch and the rear is close on the fender wall. I'm the one who had to use sticky weights to get it to clear the spring perch. Now I've heard that 240Z's spring perch sits higher and shouldn't be as bad a problem. I'm pretty sure that when I roll the fender lip in the back I won't have a problem. Also I feel like my suspension is getting softer and softer making it rub when I hit multilple dips on the road. So I've been shopping for a new stiffer suspension setup. As far as 235 wheels are concerned. It would probably make it rub more, but each tire is different. Quote Link to comment Share on other sites More sharing options...
madkaw Posted September 29, 2008 Share Posted September 29, 2008 Datfreak, on a 240z you will have to trim the rear quarter lip,or roll the lip, to get 235's. You will have plenty of room on the inside rear, but the front is tighter. I currently have 245/45/17 on mine with stock suspension. I had to trim almost all the lip away at the 10 thru 3 o'clock postion on the rear. The front perch had to be beaten in flat to resume the same clearance I had with the 235's. I will be suprised if it never rubs, but I did run the suspension thru its full travel. http://forums.hybridz.org/showthread.php?t=135971&highlight=hyper+black Quote Link to comment Share on other sites More sharing options...
ktown z Posted September 29, 2008 Share Posted September 29, 2008 Well I tried to order my hyper black rb-r's but I wanted 17X7.5 front and 17X8.5 rear. I love the staggered look and it allows alittle more clearance. I called around and e-mailed numberous places but I guess they don't make 17X7.5. Quote Link to comment Share on other sites More sharing options...
palauoriginal Posted September 30, 2008 Share Posted September 30, 2008 sweet drop the 240z bumpers would really complete it. i daily'd cut springs for a while and i liked it better then my performance ones now... depending on how much you cut cutting gives it a low confortable ride. Quote Link to comment Share on other sites More sharing options...
datfreak Posted October 6, 2008 Share Posted October 6, 2008 thanks for the info guys--- I've already bought the tyres.. Now im looking for a supplier for the wheels. Ive tried lsdmotorsport and 18racing.. Has anyone used lsd before? Quote Link to comment Share on other sites More sharing options...
datfreak Posted October 16, 2008 Share Posted October 16, 2008 got the wheels--- they look great- with 235-45-17 tyres on the back it is a tight squeeze. The lip has already shaved off some rubber... I hope getting the guards rolled with be enough. Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted October 16, 2008 Author Share Posted October 16, 2008 Got some pics? 235 would be cutting it pretty close. I ordered some Tockico shocks and springs to help with my soft suspension. Hopefully that will help with my rubbing. Quote Link to comment Share on other sites More sharing options...
datfreak Posted October 17, 2008 Share Posted October 17, 2008 grrrrr-- now the fronts are hitting.... The wheel actually touches the spring platform damit do the 260z struts have a lower platform? Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted October 17, 2008 Author Share Posted October 17, 2008 Whats hitting. The rim or the tire? My spring perch lined up right with the lip of the rim. Quote Link to comment Share on other sites More sharing options...
datfreak Posted October 18, 2008 Share Posted October 18, 2008 mmm-- looks to be about .5mm above the rim on the tyre-- or maybe its touching both. It locks the wheel when the nuts are tightened. I will try flattening the platform will a hammer- maybe grind abit off the bottom spring, it will be very very close. Otherwise -there is always geting a spacer or coilovers Quote Link to comment Share on other sites More sharing options...
datfreak Posted October 19, 2008 Share Posted October 19, 2008 nope - the hammer and grinder didnt give enough.. I tried 260z hubs and that didnt give any more. A 240k hub seem to give 5-10mm but i only have 1-- Quote Link to comment Share on other sites More sharing options...
