mobythevan Posted August 22, 2008 Share Posted August 22, 2008 Here is the link to the original thread: http://forums.hybridz.org/showthread.php?t=102244 I saved the jpeg re-linked it for this thread in case the original poster loses it. Link to comment Share on other sites More sharing options...
big-phil Posted August 23, 2008 Share Posted August 23, 2008 as in the MSnS Extra Ignition Manual. You need to change your dwell from the 3 settings (cranking, running, minimum)when using a single coil, to a fixed dwell at 50% when using the MSD 6A I did this today and the car revs, and pulls hard at 20lbs of boost. this is single coil http://www.msextra.com/manuals/MS_Extra_Ignition_Hardware_Manual.htm#singlecoil this is msns1 v3.0 with MSD http://www.msextra.com/manuals/MS_Extra_Ignition_Hardware_Manual.htm#msdout it looks like you must change your dwell settings! Link to comment Share on other sites More sharing options...
mobythevan Posted August 25, 2008 Author Share Posted August 25, 2008 and the tach info from Phil: also just hooked up the MSD tach adaptor pn 8920 and my 78 280z tach works!! this is the link to hooking up that: http://www.msdpowersports.com/pdf/frm22049_pn8920.pdf Link to comment Share on other sites More sharing options...
big-phil Posted August 26, 2008 Share Posted August 26, 2008 and the tach info from Phil: Thanks forgot about that. I tried hooking the tach to the MSD tach out put with no luck. But with the tach adapter it works as good a the stock one did! Link to comment Share on other sites More sharing options...
jeffer949 Posted September 29, 2008 Share Posted September 29, 2008 Hrrm didnt know this. Wonder how much it will help in the 1/4 Link to comment Share on other sites More sharing options...
Z31Guy Posted October 25, 2009 Share Posted October 25, 2009 hey guys, i must be really dumb not to be able to figure this out, but... i just can't figure out how to wire this thing up. 87' 300zx Turbo: MSq-II v3.0 I mean, i could build the darn thing, but i just dont know what wires to connect where... thanks for any help you feel like handing out (I used the search ALOT!) just doesnt seem to click for me. Link to comment Share on other sites More sharing options...
yhlz Posted September 20, 2010 Share Posted September 20, 2010 sorry to bring this thread back but is this how you hook up Megasquirt to an L28et? which version of MS does this apply to? thanks. Link to comment Share on other sites More sharing options...
Tennesseejed Posted April 6, 2012 Share Posted April 6, 2012 There is another way to wire MSD6 - which I have been running for a couple of years now - that may appeal to people who are not using a ZX distributor. I recently tried, unsuccessfully, to trigger MS (Ver: 3.57; Code: 3.2.1) directly from the VR sensor on a 280Z distributor (non-ignitor/HEI). Didn't work. Instead of having MS drive the MSD box - as in the schematics above - you can (conceptually speaking) put the MSD in front of MS and trigger MS using the tach out. The tach out on MSD6 is a 12V square wave. You wire the MSD box for a typical VR installation: Green and Violet wires to VR sensor; White wire is not used; Heavy Black and Red wires to ground and battery, respectively; Light gauge Red wire to 12V switched; Medium gauge Black and Orange to coil negative and positive, respectively. The tach out goes to Pin 24 (DB37). Viola. I have wired my MSD system twice using this configuration and it works very well. Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 4, 2013 Share Posted July 4, 2013 I'm using a MS2 v3.57 with a VR distributor. You have to adjust the trim pots to get the signal. The problem with wiring the MSD6 before the MS is it doesn't allow MS to control timing advance/ retard. Link to comment Share on other sites More sharing options...
