Dyno'd the Galactica
Bernardd
422hp at 6800rpm
366 ftlb's at 5200rpm
This was on a mustang dyno and running 21-22psi.
No scanner at the moment to post up the graph.
Bernard
Wow! peak power at 6800 with an L6. That's impressive. You must have some decent head work done. Do you have a custom intake?
Excellent results !! (though I always figured you had to be over the 400HP mark).
Nice to see the stock intake able to support so much HP at high RPM, even considering the extensively worked on head. I imagine that turbo can shove in quite a bit of air to make up for some of the restriction.
What about the exhaust manifold, is it still stock?
