janaka Posted September 15, 2008 Share Posted September 15, 2008 So I've had my '76 280Z LS1 swap for a few months now give or take and when we first got it up and running the new driveshaft yoke would hit the rear sway bar on any significant acceleration. So the easy thing to do was remove it, problem solved. The driveshaft is the custom aluminum one from John's Cars Inc in Texas and it bolted right in. Well my friend with an MR2 wants to do some lapping and I think I'd like to have a rear sway bar for that. I've searched a bit here and there and hadn't found anyone else running into this problem Good for you, bad for me. I was running a 7/8" MSA rear bar for the record. Can anyone post pics of their rear sway bar so I can see if mine was originally installed incorrectly from the last owner or if I have an anomoly on my hands. Any input is appreciated guys. Thanks Quote Link to comment Share on other sites More sharing options...
buZy Posted September 16, 2008 Share Posted September 16, 2008 A couple of options. Check your front pinion mount for movement. Adjust your DS running angle to achieve more clearance. A vertical adjustment of your rear end may be all you need to gain the slight needed clearnace. If your still running oem half shafts just switch to a 240 style rear mounted bar. It's an Easy swap. Quote Link to comment Share on other sites More sharing options...
janaka Posted September 16, 2008 Author Share Posted September 16, 2008 A couple of options. Check your front pinion mount for movement. Adjust your DS running angle to achieve more clearance. A vertical adjustment of your rear end may be all you need to gain the slight needed clearnace. If your still running oem half shafts just switch to a 240 style rear mounted bar. It's an Easy swap. Thanks I'll take a look into this. Much appreciated. jason Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 17, 2008 Share Posted September 17, 2008 This seems to be a problem with mine too. Quote Link to comment Share on other sites More sharing options...
mark Posted September 17, 2008 Share Posted September 17, 2008 I had to space my bar down. I used some .5 inch aluminum and made some spacers. Works well. Quote Link to comment Share on other sites More sharing options...
deja Posted September 17, 2008 Share Posted September 17, 2008 I have this problem with my 280Z LT1 swap. Right now I am running without the rear bar. Where did you put those .5" spacers? I had to space my bar down. I used some .5 inch aluminum and made some spacers. Works well. Quote Link to comment Share on other sites More sharing options...
mark Posted September 17, 2008 Share Posted September 17, 2008 .5 inch aluminum plate from the local scrap yard. Used a jig saw to cut them out and used the bushing mount as a template to drill the holes in the aluminum. The spacer fits between the bushing and the body of the car. Quote Link to comment Share on other sites More sharing options...
deja Posted September 17, 2008 Share Posted September 17, 2008 The spacer fits between the bushing and the body of the car. That was my plan. But the 280Z has a welded on bracket with a 1 bolt and slot strap that holds the bushing in. Without major modification to that bracket I can't add the spacer. Quote Link to comment Share on other sites More sharing options...
mark Posted September 17, 2008 Share Posted September 17, 2008 I see your point. My car came with out any provisions for a rear bar so none of this was a big deal. If you want a rear bar, it looks like you will need to do some work. I'm not sure I would go to the trouble unless this was a track only car. Quote Link to comment Share on other sites More sharing options...
deja Posted September 17, 2008 Share Posted September 17, 2008 Right now its not a big deal. My car is pretty much a street car with an occasional trip the the drags. I see your point. My car came with out any provisions for a rear bar so none of this was a big deal. If you want a rear bar, it looks like you will need to do some work. I'm not sure I would go to the trouble unless this was a track only car. Quote Link to comment Share on other sites More sharing options...
