1rad280 Posted September 23, 2008 Share Posted September 23, 2008 Can there be a filter added befor the fuel pump on my 76 280 or will that burn the pump up. sorry about the title. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted September 24, 2008 Share Posted September 24, 2008 It's been done of aftermarket pumps plenty of times, but you have to use a much coarser filter. If you use one such as intended for the primary filter that is built in-line after the pump, it will indeed kill it. Most fuel pumps can't pull very hard to themselves. Quote Link to comment Share on other sites More sharing options...
GeeZ Posted September 25, 2008 Share Posted September 25, 2008 It's been done of aftermarket pumps plenty of times, but you have to use a much coarser filter. How do you determine or get a coarser filter. I have used a regular fuel filter in the past but don't remember having problem or even thought of it as a problem. Quote Link to comment Share on other sites More sharing options...
jerryb Posted September 25, 2008 Share Posted September 25, 2008 Unless you want rust and crap entering your fuel pump.....place the filter before...not after. Quote Link to comment Share on other sites More sharing options...
azcarbum Posted September 25, 2008 Share Posted September 25, 2008 Dustin ( aka: BURRL ) has a shop and puts the following filter on his customers cars. He recommends: fuel filter / Car Quest #86299 Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted September 25, 2008 Share Posted September 25, 2008 I've done plenty of Aeromotive fuel setups, etc. They have filters (that are serviceable) that are fine for post-pump to avoid small particles entering the injectors and a coarse filter (100 micron or something) to avoid big stuff getting into the pump. They are done thusly; [Tank]--->[C.Filter]--->[Pump]--->[F.Filter]--->[injectors] I honestly don't think that particulates are much of a problem for the fuel pump itself except if you have an old gas tank, accidentally drop something in the fuel (grit, etc.) or have a really crappy source for fuel. I've never really set up a "built" fuel system where crappy gas or an old gas tank was used, however. In any event, 100 micron should get anything out that's going to hurt the pump. Leave the rest for the post-pump filter where the pump can push past/around it (in the filter media) much easier. I've no idea what type of filter you used or how fine the mesh was or even what pump you used. Some pumps can, some can't. Depends on a lot of factors, I suppose. I've been told the A1000 can suck fuel to itself but I never trust that when setting a car up. Here's a link: http://www.aeromotiveinc.com/products.php?prod=179 Quote Link to comment Share on other sites More sharing options...
lgoodson@pacbell.net Posted September 26, 2008 Share Posted September 26, 2008 My 75 280 has a filter built in thr the pump inlet which gets dirty. It can be removed carefully (very). You have to kind of dig it out. I use a small screw driver. Quote Link to comment Share on other sites More sharing options...
