Hotrodpez 10 Posted October 1, 2008 Share Posted October 1, 2008 So I've done some searching, but I can't really seem to find this info. What would the color have been (factory) for most of the parts of a Z? I know the engine block is blue, but what about trans, driveshaft, differential, control arms, and struts? The head and valve cover were raw aluminum, right? Quote Link to post Share on other sites
cockerstar 26 Posted October 2, 2008 Share Posted October 2, 2008 Sounds like something that you would be able to find out over at www.classiczcars.com. They're more into the whole original thing. They like stock. We like fast Quote Link to post Share on other sites
gwnwar 10 Posted October 2, 2008 Share Posted October 2, 2008 If I remember all black but trans it is raw alum also.. Quote Link to post Share on other sites
S30TRBO 1 Posted October 2, 2008 Share Posted October 2, 2008 Alan Thomas where are you Quote Link to post Share on other sites
Hotrodpez 10 Posted October 2, 2008 Author Share Posted October 2, 2008 Well, I'm not so much concerned about "stock", but I've never been a big fan of being "flashy"... It doesn't matter if you paint your engine block Candy Purple and polish everything, your car is still slow. I'd rather spend my money to make power, not looks. But in any case, I have to spray paint them *some* color, so why not stock? Make the people at car shows that don't know Datsuns that well wonder if it came from the factory with a gigantic turbo... Quote Link to post Share on other sites
cockerstar 26 Posted October 3, 2008 Share Posted October 3, 2008 If you're going to paint it I would suggest rustoleum satin black over rustoleum primer. It looks very crisp and holds up well. Quote Link to post Share on other sites
blue72 12 Posted October 3, 2008 Share Posted October 3, 2008 Hey, that's one of those 260ZX's right? Yeah, I remember when those came out. Real fast with that supercharged V8 from the factory. Course, I whomped on 'em with my X-package Gremlin. Â Well, as far as I can tell, and from looking at pictures of nice restorations, there isn't much color variation across the board. The block, alternator bracket, crankcase breather tube and harmonic balancer/pulley were painted light blue. The core plugs were steel. The transmission, front cover, cylinder head, valve cover, thermostat housing, distributor body, alternator body, fuel pump body, intake manifolds, balance tube and carburetors were unpainted aluminum. The engine bay, of course, was body color. The radiator and brake booster are a gloss or satin black with appropriate decals on them. Brake booster vacuum tube bracket is black, and possibly the fuel filter bracket. Engine mounts and oil pan are black too. Oil filter is a blue Nissan piece. Most of the ignition coils seem to be a semi-gloss black. I've never seen date stamped spark plug wires, but I'd guess a gray or black color. Most everything else is coated with a special mixture of zinc. Items such as the hood prop, fuel rails, hood latch hardware, ignition coil bracket, water pump pulley, inspection light, throttle linkage, emission equipment, brake and clutch solid hoses, engine hoist bracket, distributor vacuum advance mechanism, voltage regulator, and all of the nuts and bolts. As far as the rest of the driveline, the driveshaft was black, rearend black, halfshafts black. I believe that the rearend covers were painted black as well, but many people opt to polish or clean them up them as they are aluminum. That leaves the rest of the suspension, which in my observations has mostly been black. An exception being the rear drums, which are raw aluminum. Most of the hardware is zinc plated underneath as well. If anyone has any further observations/corrections just post 'em. Quote Link to post Share on other sites
Hotrodpez 10 Posted October 4, 2008 Author Share Posted October 4, 2008 Most of the ignition coils seem to be a semi-gloss black. Â LOL So what color should I paint my MSD box?? Â Â *sarcasm* (I'm not THAT interested in stock colors) Â But really good info! Quote Link to post Share on other sites
blue72 12 Posted October 4, 2008 Share Posted October 4, 2008 I'm actually seriously considering painting my Blaster2 coil black to make it blend into my engine bay scheme. I'm going for something of the same feel, looks stock from a quick glance, however, it is anything but. I'm even running a mechanical fuel pump on a P79 head. Quote Link to post Share on other sites
Hotrodpez 10 Posted October 4, 2008 Author Share Posted October 4, 2008 Its basically the ultimate sleeper... even looks stock when you open the hood. Quote Link to post Share on other sites
lgoodson@pacbell.net 11 Posted December 12, 2008 Share Posted December 12, 2008 I have a oringial paint yellow 71 car. Does anyone know where I can go to get the paint code number as it is no longer on the car, a web site that lists them by year or something like that, I think there is a couple of Yellows. Thanks This web site has the touchup paint WWW.automotivetouchuppaint.com Quote Link to post Share on other sites
lgoodson@pacbell.net 11 Posted December 12, 2008 Share Posted December 12, 2008 PS. The color of the car is now Dessert Gold but the engine bay and door jams ar oringinal yellow which matches pretty close Quote Link to post Share on other sites
cockerstar 26 Posted December 12, 2008 Share Posted December 12, 2008 Search! Your answer is in the stickies in the paint section. Your question also doesn't belong in this thread Quote Link to post Share on other sites
lgoodson@pacbell.net 11 Posted December 13, 2008 Share Posted December 13, 2008 Thanks Quote Link to post Share on other sites
