ORANGEZ Posted November 8, 2008 Share Posted November 8, 2008 On my 72 Datsun Z while driving above speeds of 50MPH the steering wheel begins to shake excessively. I recently replaced the steering coupler so it cant be that. Could a bad allignment be the cause of this? I just wanted to this if this has happened to anyone before i start taking and replacing parts. Quote Link to comment Share on other sites More sharing options...
jerryb Posted November 8, 2008 Share Posted November 8, 2008 Wheel balance? And check all the suspension bolts to make sure they are tight! On my 72 Datsun Z while driving above speeds of 50MPH the steering wheel begins to shake excessively. I recently replaced the steering coupler so it cant be that. Could a bad allignment be the cause of this? I just wanted to this if this has happened to anyone before i start taking and replacing parts. Quote Link to comment Share on other sites More sharing options...
LowCarbZ Posted November 8, 2008 Share Posted November 8, 2008 Had that when I bought my Z. I changed the worn out strut rod bushings and it cured the problem. The driver's side was broken away pretty bad. Start there and then just work your way thorugh the suspension. It'll be a slight amount of movement that's being amplified at speed. Quote Link to comment Share on other sites More sharing options...
gwnwar Posted November 9, 2008 Share Posted November 9, 2008 Tighten/check all bolts including wheels..check bushings.. Balance wheels Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted November 9, 2008 Share Posted November 9, 2008 Well my wheel didnt shake 'excessively' but it did shake a little between 60-70 mph when one of my front bearings was going out. [i'd check the other stuff first] Quote Link to comment Share on other sites More sharing options...
ORANGEZ Posted November 9, 2008 Author Share Posted November 9, 2008 yeah alot of my bushlings are toast. I'll check em out on the morning.thanks Quote Link to comment Share on other sites More sharing options...
eec564 Posted November 9, 2008 Share Posted November 9, 2008 Also check out your inner and outer tie rod ends. You mention alignment, does it pull when it's shaking? If so, definitely check the inner tie rod ends for play. With enough wear they can pull out, then BAM. Your steering rack is no longer controlling the direction one of your tires is pointing. In any case, with cars these old, it's a good idea to replace many suspension parts. Some bushings may or may-not be needed, depending on how many miles and where the car lived, but ball joints and tie rods (or sometimes just ends) are nearly always on the list. Quote Link to comment Share on other sites More sharing options...
