I need help wiring my l28et swap
stravi757
i just put my l28et in my 78 280z and i have everything bolted up but i desperately need help with the wiring. i have searched all over the forums but wiring just isnt for me. so i live in danville ca. which is like ten minutes away from walnut creek, if anyone knows how to wire my car that lives in the bayarea will help me, i will pay you 100$ cash to finish wiring my car. call me for details, 925-487-9302 or just pm me. michael
ok im gonna give it another shot, okay this is where i am stuck, i have no idea what to do with these wires, can anyone label them and tell me where i need to move them?... and i know that the blue is for the tach and the black with white stripe is for switched power.
http://i233.photobucket.com/albums/ee6/stravi757/Picture002.jpg
http://forums.hybridz.org/showthread.php?t=99620&page=2
Click the link above and the third picture from the bottom shows the connector you are asking about. I mention what they are for in the description above the picture. I did go ahead and ground the green/blue wire and I suggest you do as well. My car is actually tearing up the road now so I will be doing a full write-up as soon as I catch a sunny day to take some pics so that might help you as well. Looks like you're close! :icon6:
When I did my turbo swap years ago this the what I used for my wiring
You need to get a Haynes manual for ’79 to ’83 280ZX. This is the one with
the red cover. Look on page 252, this is the wiring diagram. You will see
3 plugs labeled “1,2,3” with circles around the numbers. This is at the
lower left-hand side of the page.
The wires are as follows:
Plug 1= BR 12v power source. Positive
G 12v power source. Positive
Plug 2=Y start signal (+)
GL ground for inhibitor switch
YW speed sensor (not necessary)
Y A/C signal (+)
YW coil (-)
B fuel pump ground if using modulator
Plug 3=LR fuel pump relay
G ignition .signal (+) for air regulator
W not used
Y not used
BW ignition signal (+)
  • 1 year later...
