Z1NONLY Posted February 13, 2009 Share Posted February 13, 2009 hello, again Z masters i just got another 78 280z and was able to start it after it has been sitting for 1 year and a half. the problem is that the motor will not rev past 2500 rpms. idles fine..starts up nice... i've change the air flow meter and still the same . changed the fuel and fuel filter. changed the plugs and wire and cap and rotor. sprayed either and found no leaks . check connections and vacuum hoses.. ...injectors click nicely... i'd appreciate any idea's or answers.. happy V and hope U get luck E. thanks jb Quote Link to comment Share on other sites More sharing options...
nismopick Posted February 13, 2009 Share Posted February 13, 2009 Check the TPS and timing. Quote Link to comment Share on other sites More sharing options...
islanddozer Posted February 14, 2009 Share Posted February 14, 2009 Getting fuel to rail ? Checked spark at plugs ? Power to coil ? Quote Link to comment Share on other sites More sharing options...
RigilKent Posted February 14, 2009 Share Posted February 14, 2009 if it runs and idles i would say that the fuel and spark is ok but i would have to go with nismopick and say that its throttle position sensor or timing Quote Link to comment Share on other sites More sharing options...
woldson Posted February 14, 2009 Share Posted February 14, 2009 What dose it do at 2500? and above? Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted February 15, 2009 Share Posted February 15, 2009 That would be the computer not seeing either tps or air flow meter. Quote Link to comment Share on other sites More sharing options...
KunoZ Posted February 15, 2009 Share Posted February 15, 2009 Computer can run with out the tps unplug it and see if it helps. Most def. check your timing too. And as for fuel pressure are you getting enough?? If Im correct I think you have to have about 34psi. And one more thing. How well is it running at idle?? Is it a smooth idle?? Quote Link to comment Share on other sites More sharing options...
AK-Z Posted February 15, 2009 Share Posted February 15, 2009 Had the same problem. Check the AFM Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted February 16, 2009 Share Posted February 16, 2009 Also check the wiring diagram to see if they share the same 5 volt reference voltage circuit. Even newer obdII cars will throw a code for a tps when the real problem is the map or mass air flow sensor for the very reason that they share the ref. voltage circuit. Very common in jeep 4.0 liters. Quote Link to comment Share on other sites More sharing options...
Z1NONLY Posted February 21, 2009 Author Share Posted February 21, 2009 thanks guys for all the info.. just checked and cleaned all the connections and bamm.. 6k on the tach.. runs good.. thanks again Quote Link to comment Share on other sites More sharing options...
ben280zx Posted February 26, 2009 Share Posted February 26, 2009 Sound great, I'm glad you got that sorted out. Maybe I should clean and tie down most of my connection. Quote Link to comment Share on other sites More sharing options...
