power steering and full time posi rear end
i want to put power steering in my 78 280 z it still has the l28 in it all stock motor but im about to turbo it i have heard about putting a mustang pump in it but are there any other options? or anyone that makes pumps specifically for a l28? and also i have a limited slip rear end in mine now but i want full time posi rear end in it can i buy one anywhere for it because i dont want to have to weld it and rig it i am a certified welder and i know what im doing but i would rather buy a posi rear end that is already made like that any suggestions?
"yea im positive it is limited slip but i want full time positive traction bc mine will only posi up when its wet or on a down hill grade"
my 280z has a stock diff and it spins both wheels when it's wet out :) my neighbours, friends, parents of friends and a couple members of the Ontario Provincial Police will back me up on that :P
P.S. a full posi in an s30 probably work that well, ie. trying to turn
no im not wrong and when i come out onto the road and i get on it it spins one wheel not two. it will spin two wheels when its wet or on the slick kind of pavement like iin my shop but not on a regular asphalt road when its dry it will not spin. it is lsd i know what it is i want a true positive traction rear end meaning both wheels spin at all times!!!!
oh yea and lsd isnt the same as american posi my chevrolet and my ford truck both have lsd meaning both wheels wil only spin in certain conditions
It is the same... just trust the advice you are given. If you dont believe us then search or email a drivetrain specialist for an "official" answer:rolleyesg.
Don't take this the wrong way, but you clearly do not know what limited slip and positraction mean. Positraction was GM's name for the Eaton limited slip back in the 60's and 70's. The name has become pretty much synonymous with limited slip differentials. Chrysler had Powr-Lok, Ford had Tru-trak. They are all limited slips. You have an open differential.
http://en.wikipedia.org/wiki/Limited_slip_differential
How differentials work:
http://auto.howstuffworks.com/differential.htm
Differential description:
http://auto.howstuffworks.com/differential1.htm
Open diffs:
http://auto.howstuffworks.com/differential2.htm
Clutch style limited slip:
http://auto.howstuffworks.com/differential4.htm
Viscous LSD:
http://auto.howstuffworks.com/differential5.htm
Torsen:
http://auto.howstuffworks.com/differential6.htm
http://forums.hybridz.org/showthread.php?t=92318
I have an open diff in my Z, I know, I've had it apart. I've also done a burnout in the parking lot and seen two black marks on the pavement. Like Jon said, it's semi-normal Z behavior even though it has an open diff. Be careful not to murder the spider gears getting one wheel spinning too fast though.
It also took me all of 5 seconds to type "power steering conversion" into the search box, and the first page of results had three separate threads that dealt with different racks and conversions that have been done in the past.
