usa3776 Posted March 7, 2009 Share Posted March 7, 2009 well i tried searching but couldnt find what i need. im almost done with my 260Z ls1 swap and im trying to install the datsun coolant temp sensor but i cant find adapters to make it fit. any suggestions? i pulled the plug out of the passenger head, but none of the hardware stores can figure out what type of thread it is. it seems like its almost a 1/4 NPT please help me get this thing on the road Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted March 7, 2009 Administrators Share Posted March 7, 2009 On/in the GM LSx engines, ALL threads, are metric. You will not find any SAE pipe threads on the LSx. In fact, I don't think there are any metric tapered pipe threads either. At any rate, the the plug/CLT temp sensors in the LSx heads are not a tapered pipe thread, just a straight metric thread. I just took a quick look at my LSx head plug and stock Datsun water temp sender for the gauge. (I don't have my LSx heads handy) Fortunately the Datsun water temp sender is larger diamter so you should be able to drill and tap the head for the datsun sender. Unfortunately, I don't recall what the threads are for the Datsun sender, other than it is metric and possibly tapered pipe? (Mine was still installed in a Thermostat housing. I think the JTR manual might callout the threads, I'd have to go out and dig that up to be sure). Also, the Datsun gauge sender is a little longer/deeper so be sure there is ample room in the head for the sender in that location, i.e. it doesn't crash into the chamber/port wall etc. Quote Link to comment Share on other sites More sharing options...
garvice Posted March 7, 2009 Share Posted March 7, 2009 I replaced my Datsun Temp sensor with a new sensor. I was prepared to drill and tap but I didn't have to. They were both M12x1.5 Quote Link to comment Share on other sites More sharing options...
m1noel Posted March 8, 2009 Share Posted March 8, 2009 I used the adapter from JCI that replaces the "freeze" plug in the drivers side head. Seems to work just fine. Mike Quote Link to comment Share on other sites More sharing options...
usa3776 Posted March 8, 2009 Author Share Posted March 8, 2009 well at least i have the size and pitch now. thanks i bought a tap and dye set so ill probly hack up some adapters heres what i got so far. all stock and now Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted March 8, 2009 Administrators Share Posted March 8, 2009 Very nice... Quote Link to comment Share on other sites More sharing options...
garvice Posted March 8, 2009 Share Posted March 8, 2009 Looks good mate. Is that first picture how it was? or is it a picture showing that from the outside it all looks stock? Either way, motor install looks the part. Brad Quote Link to comment Share on other sites More sharing options...
usa3776 Posted March 8, 2009 Author Share Posted March 8, 2009 the first pic was the day it rolled into my backyard but it still looks the same been trolling around the forum for a little while now, thanks for all the help. also big thanks to bigdeezs on here. he decoded all the wiring for me donor Quote Link to comment Share on other sites More sharing options...
Dudeboy Posted March 9, 2009 Share Posted March 9, 2009 Went through my receipts and found the adapters. Someone here posted this link http://www.autobarn.net/eqoilpreselt.html Nice sleeper look by the way. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted March 9, 2009 Share Posted March 9, 2009 what part of hollywood are you in? i think i have seen that car before. Quote Link to comment Share on other sites More sharing options...
usa3776 Posted March 9, 2009 Author Share Posted March 9, 2009 east side of hollywood, the car is from santa rosa. another question for you guys. with the stock temp gauge hooked up where does your needle sit? mine is pretty high. probly 3/4 of the ways up. not in the red but up there. thanks Quote Link to comment Share on other sites More sharing options...
garvice Posted March 9, 2009 Share Posted March 9, 2009 I am still running an L28et so mine is about half way (70-80degC). Quote Link to comment Share on other sites More sharing options...
Bigdeezs Posted March 9, 2009 Share Posted March 9, 2009 also big thanks to bigdeezs on here. he decoded all the wiring for me ...go westside LS1 Datsun club! LOL Quote Link to comment Share on other sites More sharing options...
Stephonovich Posted March 14, 2009 Share Posted March 14, 2009 I used the adapter from JCI that replaces the "freeze" plug in the drivers side head. Seems to work just fine.Mike I remember reading in one of the many LS1 Swap Guides floating around that someone had trouble with that adapter bumping into the JTR headers. Did you have to do anything special to get it to work? Quote Link to comment Share on other sites More sharing options...
heavy85 Posted March 14, 2009 Share Posted March 14, 2009 east side of hollywood, the car is from santa rosa. another question for you guys. with the stock temp gauge hooked up where does your needle sit? mine is pretty high. probly 3/4 of the ways up. not in the red but up there. thanks I used the John's adapter that goes into the block on the drivers side. There is a huge plug threaded in that you replace with a special adapter and Datsun sender. You could easily drill and tap the stock plug though. It runs in the first leg of the 'M' on the gauge - just over half way. On track it creeps up higher to the 'P'. Since I dont know where TEMP is in degrees I just added an Autometer gauge. Have not run the car yet but it's sender goes into the unused port on the passenger head. Internet search will easily find sender to LS adapter. I've read that the heads are not consistent due to flow path of the water so it will be interesting to see what the head temp tells me. I'm running JTR headers and they clear fine. Cameron Quote Link to comment Share on other sites More sharing options...
