High Oil Pressure
78 280z 4spd man.
While driving I noticed I had very high oil pressure, it was nearly constant at 80psi. Once I arrived at my destination I checked my oil level and it read at the minimum level. Ignoring the Oil pressure I just put more oil in and drove it home.
The car runs fine but I'm actually loosing oil and the pressure is still way to high. It idles at about 60-70psi and as soon as I bring the rpms up it shoots to 90 and stays.
I'm sorry if this goes on and on but I want to make sure and give you all of the details.
As far as oil consumption is concerned I did an oil change about a month ago and had it filled to the max level. It took me about 2 quarts to get it back to the max level. I'm using Royal Purple 5w-30 oil.
Another little detail is that it seems to be spitting black stuff out of the tail pipe at high rpms(oil?). I noticed this when I was sitting in my garage and around 4500 rpms it begins doing this.
So my first thought was that I needed a new oil pressure sender but now I'm not so sure; is there any way to test my sender without buying a new one? Does anyone have any ideas what the problem may be?
Thanks-
Joshua
Mine (83zx na) will be at eighty when cold. Idel will be up close to yours as well.
When heated up, not nearly so high. (really warmed up)
Could just be a gauge problem, the loss of oil should not be a factor in why it is soo high.
Search, there was some advice to a mach. gauge on the engine at the sensor location, if I remeber correctly.
So... I changed my pressure sender and the pressure is still high, it's as if once the pressure increases it just stays there. So I decided to drain my oil and replace the filter in case it was broken and or plugged. It wasn't the filter.
When I did this I found a new part of the problem. My oil is now water thin, smells of gas and is brown(which is wierd considering it was purple). So, what is causing my oil to fill with gas? I've done some searching but can't find much. : (
Once again
Thanks for all your help.
Some history of the car that may be helpful...
I bought the car from the 2nd owner who said he was not sure whether it was at 40,000 or 140,000 miles because he was selling it for his dad. People who have seen it in person say it's probably 40,000 because it's in good condition and things like the seats are nearly perfect.
Since I bought it I have switched to a 240sx throttle body, mainly so I could use a throttle cable. I replaced the radiator because it had been seeping for who knows how long. My heater core or valve is leaking so its just not hooked up right now. I had a pretty bad exhaust leak so I've replaced the intake/exhaust gaskets. While I was in there I put new electrical connections on almost the entire efi harness, put new seals on the injectors and new fuel hoses, vacuum hoses and hose clamps thru out. I'm sure there is more but that is all I can think of right now.
Hope that helps
I just found some info searching Zcar.com and it looks like it may be my valve seals so I'm going to go check my compression and then I'll let you all know the results. Also I just got off the phone with my dad who was a mechanic for many years but he's not familiar with imports; he says it may be the fuel pump leaking at the diaphram if it's mechanical. So another question I have is whether or not the fuel pump is electric or not on my 78.
I will research for this as well as more info on the fuel system but if I could get a quick answer it would be very helpful.
Haven't tested compression yet but after talking to my dad again we've come up with a new theory... It's a little long winded so bear with me. The oil pressure sender has two pins on it, one for the oil pressure gauge and one for fuel cut in the case of a wreck and fire.
Since I have high oil pressure(still don't know the cause) the fuel pump doesn't shut off when the engine does. If the ignition is on and the sender still sees engine oil pressure it will keep pumping gas thru the system. This still isn't a problem. The next "if" in this theory is that I may have one or more leaky injectors.
So basically whenever I leave my ignition on to test something or just to see what the gauges are reading with the engine off I may be pumping gas into one or more of my cylinders.
I have experienced a lot of smoke on start up before so maybe this is it or at least the reason for gas in my oil. I'm going to test this tommorow by leaving the ignition on for a while and seeing if that causes a ton of smoke on start up.
first check the sensor connections its not un-heard of to have a bad connection, shorted or open connections, the fuel pump should not run if the ignitions not in the on- possition, verify with a vom meter that the pumps not getting power when the keys removed.
next find the source of the fuel leak, yes as you surmised itmight be a leaky injector but that may not be the only problem.
remove the new ,old oil, and replace it carefully checking for new fuel contamination after, a few days, running fuel oil mix will quickly destroy rings
is think your oil pressure is being hightened by the crankcase pressure that your cylinders may be blowing by. have you checked to make sure all vac lines and all PCV hoses are not plugged and the oil is circulating out of the crank case?
Ok guys... Sorry for the double post and I would have given an update sooner but I was having some problems with hybridz.
Last night I finally got fresh oil in it, which I would have done sooner but I couldn't get to the store and didn't want to put the bad oil back in.
With the fresh oil the pressure sender is working perfectly. I think without oil to lubricate it the sender was not returning properly and showing I had much higher oil pressure than I did.
My dad thinks I may have been using to thin of an oil and it was just washing past the rings. He's told me to watch my oil consumption closer and start fresh and I'm doing just that.
I am still going to do a fuel pressure and compression test some time in the near future. Thanks everyone for your continued help and I will let you all know how this batch of oil turns out.
