Sc project finally taking shape!!
azcarbum
After 2 yrs of putting all other projects ahead of my own, I've finally began to assemble my engine.
I started with a JCR Supercharger setup I purchased from 1TuffZ. In working out the plans for my setup, I came to the conclusion that i wanted to use the best of today's technology in the build. So this ment alot of special, and custom items were going to be needed.......So below is what I have done so far.
  • Custom SC Cam grind from with Paul Rushman's help, via Rebello Racing.
  • Kameari Twin Gear Timing kit.
  • Custom JDM Tensioner ( kameari Twin Gear setup. )
  • Kameari 1.0mm Headgasket
  • Kameari ReInforced Engine mounts
  • Kameari Fully Adj. Cam Gear
  • Kameari Valve Cover
  • Kameari (Mech. ) Oil pressure gauge
  • JDM Valve Cover Studs
  • JCR Modified Intake for Port Injection & Manifold Intake Air Sensor
  • CNC Injector holders
  • Individual Steel Braided lines to each Injector
  • 440cc Injectors
  • Modified TB from a Mustang *( 7th Injector to cool/Lubricate SC. )
  • WOLF3D -Engine Management System ( via Ron Tyler )
  • J & S Safegaurd System ( Individual Cyl. Knock control System )
  • Individual Coilpack setup ( via Ron Tyler )
  • Modified Infrared 300zx Dist. ( via Ron Tyler )
  • Oil cooler setup ( not installed yet )
  • Ceramic Heated ( not installed yet )
  • JDM Oil Temp Sensor
Today I started to assemble and test fit things. It's been to long not playing with my own toy's!!...... With any luck, I may actually get it on the road this summer......... Ron, Paul, I'll be needing your help soon if you guy's are available!
PS: Free beer and BBQ included!!:mrgreen:
Brian
Kameari Valve cover is alot thicker, and willreduce the "click-it-tee-click" of the valves some, but otherwise it just looks better.
Its going into my 76' 280z...
I am in the final stages of my Gnose developments. Making sure the fitment is the best around. Hoping to be finished in the next month of so. ( fingers crossed. )
B.
This is the old JCR setup.... 7" Camden SC.
The biggest boost pulley I have is around 10lbs.. Later once running, I may have a larger one made, or source on if possible.
The system does not allow for a intercooler, and I'm not going to boost it to the moon, so I don't think it will be that important for my uses. I will be placing the intake as far forward to pull cool air. The 7th injector will help keep the SC cooler and lubricate.
