ben280zx Posted April 29, 2009 Share Posted April 29, 2009 Any Update Mack? Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted July 1, 2009 Share Posted July 1, 2009 Bringing back up a post worth talking about. Mack, did you ever write down any kind of measurements other than the 1.25". How thick is the piece of aluminum? Did you shave most of it to fit within the original control arm and leave the rest of the thickness of the aluminum on the outside of the control arm? Also, what is the deal with the tension rod? Is it effected by the bracket?Just wondering. Trying to make a set for my car. Brilliant idea by the way. Thanks, again. Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted July 1, 2009 Share Posted July 1, 2009 I am also very interested in this! Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted July 2, 2009 Share Posted July 2, 2009 Also, are you still using the stock 280zx hubs, rotors, and calipers? or are the S13 hubs needed and possibly some other brakes? so from what I can gather the parts needed are: S13 Coilovers S13 spindles Early 90's Maxima ball joints Custom adapter am I missing anything? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted July 3, 2009 Share Posted July 3, 2009 why not just machine out the stock control arms, and get a howe screw in lower ball joint sleeve, weld it to the stock control arm on both side, then just ream out the s13 spindle to accept the howe ball joint? (I'm also in process of doing a s13 spindle swap on my s30) Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted July 3, 2009 Share Posted July 3, 2009 I just picked up S13 spindles, hubs, calipers, and rotors. Now I need to find myself a nice set of coilovers. Quote Link to comment Share on other sites More sharing options...
Domenic Posted July 14, 2009 Share Posted July 14, 2009 I would like to attempt this as well.. Anyone have measurements? Quote Link to comment Share on other sites More sharing options...
ben280zx Posted August 1, 2009 Share Posted August 1, 2009 I've guessed Mack forgot about this thread Quote Link to comment Share on other sites More sharing options...
pallnet Posted August 4, 2009 Share Posted August 4, 2009 Here's your 5 lug conversion for the S13 spindles fellas. http://www.nissansilvia.com/forums/index.php?showtopic=327691 Been there, done that, hope this helps. pallnet Quote Link to comment Share on other sites More sharing options...
Daniel13brx7 Posted August 12, 2009 Share Posted August 12, 2009 How is it going with the coilover setup? Im interested to know how you guys are making it work. JhnRX7 said: I just picked up S13 spindles, hubs, calipers, and rotors. Now I need to find myself a nice set of coilovers. Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted August 17, 2009 Share Posted August 17, 2009 Daniel13brx7 said: How is it going with the coilover setup? Im interested to know how you guys are making it work. I was wondering this myself. Has anyone made any further progress? Pictures? And what is the deal with the longer tie rod? Any updates on this MACK? Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted August 17, 2009 Share Posted August 17, 2009 Daniel13brx7 said: How is it going with the coilover setup? Im interested to know how you guys are making it work. My S13 swap got put on hold... I found a fantastic deal on a set of Enkei 92's so I picked them up and invested in refinishing them. My coilover budget ended up going into the wheels and tires. I have everything needed to do the swap except the coilovers and tie rods. I plan on saving up for a set of Stance GR+ coils. So for now, I sit back and wait to see how every one else is coming along with their swaps... As you can see, my S130 is in dire need of some coils! Quote Link to comment Share on other sites More sharing options...
Sonethirty Posted August 21, 2009 Share Posted August 21, 2009 ^^Good Choice! I chose stances for my s13. I loved them. I had also had Tein's and Cusco's. The stance's were by far my favorite. When I go coilover on my s130 it will def. be stance's. Quote Link to comment Share on other sites More sharing options...
DeleriousZ Posted August 27, 2009 Share Posted August 27, 2009 jhn, sign yourself up over at zilvia, there's a dealer there selling stance stuff for Super cheap. Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted August 27, 2009 Share Posted August 27, 2009 Thanks Delerious, I am on there and I know of the vendor you are refering to. I spoke with them before I got my wheels and got a quote for about $1000 shipped. Quote Link to comment Share on other sites More sharing options...
Sonethirty Posted September 21, 2009 Share Posted September 21, 2009 Updates? Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted September 25, 2009 Share Posted September 25, 2009 hoov100 said: why not just machine out the stock control arms, and get a howe screw in lower ball joint sleeve, weld it to the stock control arm on both side, then just ream out the s13 spindle to accept the howe ball joint? (I'm also in process of doing a s13 spindle swap on my s30) I'm with this guy. Why would you not be able to do something like this, or even just weld in an extra 1.25" into the control arm to extend the arm to accept the geometry of the 240sx spindles? OR if MACK could just share some knowledge we can all do this. LOL. Thanks. Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted February 23, 2010 Share Posted February 23, 2010 On 9/25/2009 at 3:08 AM, rwdawg2 said: I'm with this guy. Why would you not be able to do something like this, or even just weld in an extra 1.25" into the control arm to extend the arm to accept the geometry of the 240sx spindles? OR if MACK could just share some knowledge we can all do this. LOL. Thanks. Bringing this old thread back to life again since the guys over at the S130 suspension tech started to talk more about the 280zx suspension upgrades. Any input would be great. Thanks Quote Link to comment Share on other sites More sharing options...
MiKeL 260 Posted July 22, 2010 Share Posted July 22, 2010 I dont have to use s13 hubs, rotors etc.. do i? Quote Link to comment Share on other sites More sharing options...
PurePontiacKid Posted July 22, 2010 Share Posted July 22, 2010 What would you use in place of them? if you use the S-chassis spindles, you could use S13, S14, or J30 hubs and rotors if you wanted to... Quote Link to comment Share on other sites More sharing options...
