sanders8800 Posted April 15, 2009 Share Posted April 15, 2009 I"m thinking about putting a turbo diesel in my 79 280zx. Has anybody done this? Quote Link to comment Share on other sites More sharing options...
ch3vyboi Posted April 16, 2009 Share Posted April 16, 2009 duramaxxx Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted April 16, 2009 Share Posted April 16, 2009 the weight of the engine might break the car in half Quote Link to comment Share on other sites More sharing options...
Filmjay Posted April 16, 2009 Share Posted April 16, 2009 A cummins diesel, I believe, is about 560lbs. Not MUCH more than a BBC, which has been done. You can get a LOT of power out of a diesel though...and for probably a little less than a regular V8. DO IT!!!! ...and post lots of pics. Quote Link to comment Share on other sites More sharing options...
DevilZX Posted April 16, 2009 Share Posted April 16, 2009 Yeah, I think a powerstroke is around 1,000 lbs. Wouldn't the cummins be rather tall? I say go for it! You still get to keep the inline 6! Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted April 16, 2009 Share Posted April 16, 2009 I found this. Very discouraging to me, but all I did was glance at it. I love diesel engines but I hate a ton of weight http://www.adieselengine.com/new_page_1.htm Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 16, 2009 Share Posted April 16, 2009 A cummins diesel, I believe, is about 560lbs. Not MUCH more than a BBC, which has been done. You can get a LOT of power out of a diesel though...and for probably a little less than a regular V8. DO IT!!!! ...and post lots of pics. Maybe the bare BLOCK, not a complete motor! Quote Link to comment Share on other sites More sharing options...
Filmjay Posted April 16, 2009 Share Posted April 16, 2009 Maybe the bare BLOCK, not a complete motor! Yeah, all I could find were marine weights... Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted April 16, 2009 Share Posted April 16, 2009 I say it would be great for an all out drag car, but if you plan to go around corners AT ALL it would be a bad idea. Just my opinion...that would be like a what? 65/35 front to rear weight distribution? Actually thinking about it. The Z is about 2500 lbs stock right? L6 with 4spd is 530 lbs so that would be 1970lbs. Add 1500 lbs for the diesel...3470lbs and that 1500 is all front-mid weight so it may actually be closer to 70/30? Quote Link to comment Share on other sites More sharing options...
jc052685 Posted April 16, 2009 Share Posted April 16, 2009 good luck getting one of those trannys in the stock tunnel. Quote Link to comment Share on other sites More sharing options...
zcar? Posted April 16, 2009 Share Posted April 16, 2009 I found this. Very discouraging to me, but all I did was glance at it. I love diesel engines but I hate a ton of weight http://www.adieselengine.com/new_page_1.htm Im sure those are semi engines. as a 6cyl cummins ina truck is a 6bt and should be smaller than those inthe link. you may look into the 4bt those are smaller and lighter. I just found this place it has a ton of good info for dims. and weight: http://www.4btswaps.com/forum/showthread.php?t=8187 Jeremy Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted April 16, 2009 Share Posted April 16, 2009 I'm sorry, I dont know about any engine in particular. I thought that list would have gone from normal truck engines to tractors/heavy equipment. I guess I was wrong Quote Link to comment Share on other sites More sharing options...
dustin280zx Posted April 16, 2009 Share Posted April 16, 2009 duramax with a turbo 400 would probably be most likely. I think they have about the same dimensions as a bbc. I'm sure all of you know about the duramaxx powered mustang that runs in the 9's and gets 33mpg or something like that. Be ready to spend some money though unless you find a good deal on one. For a used stock engine they have been going for about 3500-6000 depending on miles and year. I've been looking. Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted April 16, 2009 Share Posted April 16, 2009 drop in an LD28 stock mounts, stock tranny... Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted April 16, 2009 Share Posted April 16, 2009 Sorry for hijacking this thread, I tend to do that a lot. But...LD28 huh? Does it weigh about the same as the L28 N/A? That sounds intriguing. Wasn't there a guy here making a DET head for L6s by using 2 KA24 heads? Couldn't you use that idea and modify the spark plug holes to use injectors and have a direct inject LD28? And then you could put as much boost to it as you want because you dont have the octane issue. How's the revs of a LD28? Wikipedia didn't have anything about it and I couldn't find anything in search engines. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted April 16, 2009 Share Posted April 16, 2009 Sorry for hijacking this thread, I tend to do that a lot. But...LD28 huh? Does it weigh about the same as the L28 N/A? That sounds intriguing. Wasn't there a guy here making a DET head for L6s by using 2 KA24 heads? Couldn't you use that idea and modify the spark plug holes to use injectors and have a direct inject LD28? And then you could put as much boost to it as you want because you dont have the octane issue. How's the revs of a LD28? Wikipedia didn't have anything about it and I couldn't find anything in search engines. Its 3 Ka24 heads and he isn't producing them. Just a one off custom piece. I would be nervous using it with the compression of a diesel motor anyways. The LD28 came in the maximas in 81-83. There's a video of a white 240z with one in it floating around on youtube. The swap has been talked about on here before too. I don't know too much about the motors but I believe they have an iron head, different stroke, and smaller bore than your standard l28. I know you have to modify the oil pickup because the oil pan is a front sump. Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted April 16, 2009 Share Posted April 16, 2009 The only thing I found so far is a white Z that had the crank from a LD28 in his L28 to make a 3.2 ltr. I didn't expect the KA head thing to be produced, just mentioned it because if it works than anyone could make it. I was just thinking out loud. Is there any DOHC heads for L-series engines? I saw one on youtube, but from what I read that was a rare datsun factory thing. I thought OS Giken made one but dont see anything on their site or anything. Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted April 17, 2009 Share Posted April 17, 2009 Here the LD28 came in a number of different cars, the Laurel diesels, Cefiro, some light trucks, Patrols. theres a good number around. checking out Trademe.co.nz, theres an LD28 plus GBox for $600 now, about 300 USD. thats about standard for a workign engine, the price normally ranges about $300 to $800 depending on condition for a running motor. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted April 17, 2009 Share Posted April 17, 2009 The only thing I found so far is a white Z that had the crank from a LD28 in his L28 to make a 3.2 ltr. Quote Link to comment Share on other sites More sharing options...
slown280z Posted April 17, 2009 Share Posted April 17, 2009 Its 3 Ka24 heads It's 2 heads. One cut in half and the other has the number 1 and 4 cylinder cut off it. As for a diesel, you won't get the power out of an LD28 that you will out of a powerstroke or cummins. The good thing is that it basically bolts in, you can bolt the turbo manifold to it, and modify the fuel setup to compensate for boost. Quote Link to comment Share on other sites More sharing options...
