zzzzed Posted April 21, 2009 Share Posted April 21, 2009 hey guys I am about to buy a l20et motor and loom, I already have a f54 l28 with a p90 head and want to transfer everything from the l20et. I need to know will the l20et injectors and ecu be sufficient to run a l28et and is there any thing else i need to change to do the swap. Don't worry about the sump my l28 has already got the oil return for the turbo Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted April 21, 2009 Share Posted April 21, 2009 http://forums.hybridz.org/showthread.php?t=143259&highlight=l20et Discussion of L20 vs L28 parts. [url=http://forums.hybridz.org/showthread.php?t=143259&highlight=l20et][/url] Quote Link to comment Share on other sites More sharing options...
zzzzed Posted April 22, 2009 Author Share Posted April 22, 2009 how did i miss that i did a search Quote Link to comment Share on other sites More sharing options...
zzzzed Posted April 22, 2009 Author Share Posted April 22, 2009 sorry mate i didnt find any thing in that thred about l20et to l28et thanx any way Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted April 22, 2009 Share Posted April 22, 2009 Another helpful thread. http://forums.hybridz.org/showthread.php?t=143375 some of the pics might be the same on both threads but the exhaust manifold turbo placement might be an issue. Quote Link to comment Share on other sites More sharing options...
zzzzed Posted April 23, 2009 Author Share Posted April 23, 2009 thanx mate, This motor is curently running in a 240z, also i have a l28et exhaust manifold so thats no real concern Quote Link to comment Share on other sites More sharing options...
jc052685 Posted April 23, 2009 Share Posted April 23, 2009 isnt the turbo smaller on the l20 than on thee l28? Quote Link to comment Share on other sites More sharing options...
zzzzed Posted April 24, 2009 Author Share Posted April 24, 2009 yes it is, all ia after is to get it up and runing untill i can afford to upgrade the bolt on's Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 29, 2009 Share Posted April 29, 2009 Actually, the center cartridge of the L20ET is identical to the L28ET. The only real differences is the A/R on the exhaust housing, which is a .43. If applied to an L28, your boost threshold is around 1700 for a 17psi boost level. You will be able to get full boost by 2000. Running the smaller L20ET turbo on an L28, it acts more like a Supercharger than the traditional turbo where when you drive it wrong, you find soggy 'bottom end' performance. My setup was all in by around 5500 with the smaller turbo, but it was a hoot to drive. I lament selling the turbo to someone with a 2L Isuzu! Quote Link to comment Share on other sites More sharing options...
zzzzed Posted April 30, 2009 Author Share Posted April 30, 2009 ahh thanx for the imformation. I relay need to know wether the l20et ecu and injectors will work with the l28et ? Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted April 30, 2009 Share Posted April 30, 2009 L28E and L20ET use the same injector i believe from my browsings on here, L28E and L28ET use different injectors, so I would say probably not. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 1, 2009 Share Posted May 1, 2009 That is correct, the L20ET's only support 145 HP, what you can do is install an adjustable FPR and up your fuel pressure to make up for the difference in fuel delivery between the N/A L28 (L20ET) injectors, and the 270CC units on the L28ET. 4 bar? I forget. You are limited on boost then, though, since the stock fuel pump will internally bypass at boost pressures above .7 bar. Getting larger injectors in the 270 to 320CC range is advisable. It's always easier to 'trim fuel down' somewhat, than to increase it appreciably by increasing the pressure under boost. Quote Link to comment Share on other sites More sharing options...
zzzzed Posted May 1, 2009 Author Share Posted May 1, 2009 thanx guys that answers my question. I think i will run the l20 untill i can afford the injectors and after market ecu for the l28 Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted May 2, 2009 Share Posted May 2, 2009 with my old l20et i used vg30et injectors. which are 270cc, if you can find any near you that would help. Im pretty adimint that the l20et ecu will run the l28 happly.. But you;d need to swap the oil pump/dizzy drive and dizzy over to the l20et CAS unit.. Check to see what oil pump is on the l20et to.. Both of mine (JDM) had the same oil pump as the l28et Automatic. H4 rings a bell, I'd have to confurm that tho.. Ive done the some converions in my Hr30 skyline, She isnt running yet.. (funding) Orginialy had a l20et, now a n42/n42combo with l20et gear and alot more. Quote Link to comment Share on other sites More sharing options...
