PETEW Posted May 11, 2009 Share Posted May 11, 2009 Hey guys. I had my half shaft shortened for my R200 install, at a machine shop. He didn't have any metal straps so he told me that I could just use large zip ties, for the boot, and that would be fine. I figured I would ask if others have done this and if there any adverse effects. It just sounds too easy to me. Thanks. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted May 12, 2009 Share Posted May 12, 2009 Done it before, no problems. However, I would just track down the proper straps if I had to do it again. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 12, 2009 Share Posted May 12, 2009 I went the medium cheesy method and got stainless straps from Harbor Freight. There was a thread a week or so ago mentioning where to get a proper CV strap. Quote Link to comment Share on other sites More sharing options...
NCchris Posted May 12, 2009 Share Posted May 12, 2009 I've done it in my Hondas. I used a quality zip-tie with an inserted metal ratchet. Worked quite well, I would not hesitate to do it again assuming I could find the right zip-tie. Quote Link to comment Share on other sites More sharing options...
Lazeum Posted May 12, 2009 Share Posted May 12, 2009 Working for a company making half shafts (Delphi), I've asked engineers in charge. They told me I should avoid zip tie because plastic get dry overtime + it could expand with speed. I went with universal metal straps you just clamp by friction. By looking at my hafl shafts now, I'm not sure if this is a better solution. I know Murray's and other auto parts store were selling those kind of straps. For production at Delphi, we use clamp with a flat buckle we pinch with special pliers to get tension. Unfortunately over the whole batch of parts the company is using none is at the right size Quote Link to comment Share on other sites More sharing options...
PETEW Posted May 12, 2009 Author Share Posted May 12, 2009 Thanks for the help guys. I just decided to go to some of the local parts stores and see if any had universal straps, or if they loaned out the tool to put on regular straps. I found one that actually put the straps on for me while I waited. $10 bucks later and I am good to go. Not the cheapest, but not a rip off (at least I didn't think so). Thanks, again. Quote Link to comment Share on other sites More sharing options...
260DET Posted May 15, 2009 Share Posted May 15, 2009 Nylon zip ties seem OK, nylon is used in other auto applications and seems to perform and last OK. Quote Link to comment Share on other sites More sharing options...
Careless Posted May 15, 2009 Share Posted May 15, 2009 I've seen cheaper aftermarket driveshafts with thick nylon straps with the metal clip as mentioned by NCchris in regards to his (shhhh! *honda*). But a good metal strap installed properly for 10 bucks is about as good a price as you'll get anywhere. Quote Link to comment Share on other sites More sharing options...
jerryb Posted May 15, 2009 Share Posted May 15, 2009 Ive had heavy duty nylon ZIP ties on mine for years...just dont buy the cheapo dollar store kind. Also pick up one of thise ZIP tie guns. You can get them for a few bucks and they will help tighten those ties snug. Quote Link to comment Share on other sites More sharing options...
