01vincer6 Posted June 8, 2009 Share Posted June 8, 2009 I have an 88zx turbo r200 clsd diff that needs completely rebuilt. I will replace all of the bearings and seals in the diff but I dont know where to find the clutch packs nor want to tackle the teardown and install. If someone knows where to send the clsd off to let me know. I already have the clsd out of the diff. Also if anyone knows where to get all of the bearings and seals for the diff that are not on back order post up some part numbers and links or details.. Thanks! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 8, 2009 Share Posted June 8, 2009 The clutches are NLA from Nissan, and they were $30 EACH when you could get them which is a horrible rip off. You might consider swapping out the spacers for 4 more clutches from Gary Savage (if he still has any) and then shimming it to suit. I have a sticky thread on shimming and Austin 240hoke has one on putting in the extra clutches. It's really not a difficult job at all. Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 8, 2009 Author Share Posted June 8, 2009 i read both threads already. and still would prefer someone else to do it Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 8, 2009 Share Posted June 8, 2009 Replacing the bearings is a LOT harder than doing the LSD. I would think any differential shop should be able to swap parts into the LSD. Finding someone to test it properly is probably a little more tricky if you're looking to hit xx lbs breakaway. Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 8, 2009 Author Share Posted June 8, 2009 do u have the link for the replacement parts? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 8, 2009 Share Posted June 8, 2009 No. Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 9, 2009 Author Share Posted June 9, 2009 Is there a ring gear smaller than the 3.7 that I currently have that will work on this lsd? Im shifting to 6th gear in the 1/4 currently :burnout:and I would rather not. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 9, 2009 Share Posted June 9, 2009 The very common 3:54 R200 will help slightly..... Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 9, 2009 Share Posted June 9, 2009 You can't just swap the ring gear. You can swap the LSD into a diff with 3.54s. Lots of documentation on this, but you need to search. I wrote a FAQ post on installing the LSD into an open diff. That should help you a lot. Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 9, 2009 Author Share Posted June 9, 2009 The very common 3:54 R200 will help slightly..... How slightly? Possibly not worth the hassle? Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 9, 2009 Author Share Posted June 9, 2009 You can't just swap the ring gear. You can swap the LSD into a diff with 3.54s. Lots of documentation on this, but you need to search. I wrote a FAQ post on installing the LSD into an open diff. That should help you a lot. I have been searching and reading all of your posts. Im just getting tired from all of the reading and looking for a quick answer. Quote Link to comment Share on other sites More sharing options...
johnc Posted June 9, 2009 Share Posted June 9, 2009 Im just getting tired from all of the reading and looking for a quick answer. Then this ain't the place for you. Try Twitter. Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 9, 2009 Share Posted June 9, 2009 There are 3.36 LSD's out there...in European Turbos. Euro Z31 Turbos specifically. The S130 Turbo came with an R200 but it wasn't LSD. There's the source for the ring gears you wanted...now go get 'em! It will neither be cheap, fast, nor easy so.... Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 10, 2009 Author Share Posted June 10, 2009 Then this ain't the place for you. Try Twitter. Thanks for the useless response Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 10, 2009 Author Share Posted June 10, 2009 There are 3.36 LSD's out there...in European Turbos. Euro Z31 Turbos specifically.The S130 Turbo came with an R200 but it wasn't LSD. There's the source for the ring gears you wanted...now go get 'em! It will neither be cheap, fast, nor easy so.... Thanks thats the size that will be better for me. I will start looking Quote Link to comment Share on other sites More sharing options...
mark Posted June 10, 2009 Share Posted June 10, 2009 I had this guy rebuild mine. I shipped it and he installed the lsd and new bearings. It's been on the track for a couple of years and has not missed a beat. http://forums.hybridz.org/showthread.php?t=142964 Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 10, 2009 Author Share Posted June 10, 2009 Quote Link to comment Share on other sites More sharing options...
onefast87 Posted June 13, 2009 Share Posted June 13, 2009 You can't just swap the ring gear. You can swap the LSD into a diff with 3.54s. Lots of documentation on this, but you need to search. I wrote a FAQ post on installing the LSD into an open diff. That should help you a lot. are you sure about this?? because i installed a 3.54 gear set into my CLSD. no problem at all. Quote Link to comment Share on other sites More sharing options...
V8INtheZ Posted June 27, 2009 Share Posted June 27, 2009 are you sure about this??because i installed a 3.54 gear set into my CLSD. no problem at all. you installed the gear SET. cant just swap the ring gear and leave the old pinion in place Quote Link to comment Share on other sites More sharing options...
01vincer6 Posted June 28, 2009 Author Share Posted June 28, 2009 anyone know of a good overseas parts locator? I have only found 1 3.36 gearset that has sold back in 08. Quote Link to comment Share on other sites More sharing options...
