janaka Posted June 10, 2009 Share Posted June 10, 2009 Well since I have a 1974 260z (2+2) I'm now trying to figure out what is transferable from my 280z. I've heard that 'late' 260's are basically 280's for the most part and the 'early' are more 240's. When does the early/late transition happen? Thank you Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 10, 2009 Share Posted June 10, 2009 If it has 280z style turn signals, it's a late 260z. Yours is easy though, since, as far as I know, there is no early 2+2 of any kind. I may be mistaken, but I'm pretty sure. And yes, late 260zs are more or less 280zs, and early is like the 240z. Hope that helps... Quote Link to comment Share on other sites More sharing options...
jhm Posted June 10, 2009 Share Posted June 10, 2009 janaka- The transition occured Aug/Sep 1974. Anything earlier is an "early" '74 and anything later is a "late" '74. I believe that the chassis number also indicates "early '74" vs "late '74". Anything up and including chassis # RLS30-060000 is an early 74; anything later is a late 74. Both pieces of information can be found on the metal body ID tag riveted to the inside of the driver's side door jamb. As rturbo pointed out, the turn signals are a dead giveaway for early vs late. The bumpers are another easily identifiable distinction. A good deal of Z-car historical and reference data can be found at the following website: http://www2.zhome.com:81/. Enjoy.... jhm Quote Link to comment Share on other sites More sharing options...
zcarnut Posted June 10, 2009 Share Posted June 10, 2009 rturbo 930 said: Yours is easy though, since, as far as I know, there is no early 2+2 of any kind. I may be mistaken, but I'm pretty sure.... That is incorrect. There were lots of 2+2 early 260Z's produced. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 10, 2009 Share Posted June 10, 2009 zcarnut said: That is incorrect. There were lots of 2+2 early 260Z's produced.Like I said, I may be mistaken. Thanks for the correction. Quote Link to comment Share on other sites More sharing options...
janaka Posted June 10, 2009 Author Share Posted June 10, 2009 Thanks for the help guys. As for turn signals and bumpers. Mine has neither stock or else I would have known by skinny vs fat (like i have on the 280). I'll have to see what the date is on the door of the car. Quote Link to comment Share on other sites More sharing options...
jhm Posted June 10, 2009 Share Posted June 10, 2009 Even if your bumpers have been replaced, you should be able to determine which bumpers were there originally. The thin (early) bumpers had indentations in the front and rear corners to accommodate bumper mounting; the thick (late) bumpers had no such indentations. Quote Link to comment Share on other sites More sharing options...
janaka Posted June 10, 2009 Author Share Posted June 10, 2009 Hmmm I guess I'll have to go to the container to look at the car and see for sure when I get a chance. I do have the title and the ID # is GRLS30003945 which by your previous post would certainly make it an 'early' '74. I guess the suspension and such may not be transferable Quote Link to comment Share on other sites More sharing options...
beezed Posted June 11, 2009 Share Posted June 11, 2009 Jason,According to the MSA parts catalog your 280 strut assembly,s should bolt in to the 260 2+2 chassis ,also 2+2,s have the r200 diff, and the stick cars have the 3.36 ratio vs the auto 3.54 Quote Link to comment Share on other sites More sharing options...
