EAGLE ROD NUT REMOVAL????
Corzette
Hey guys I have a question. I just bought the EAgle H Beam rods with arp wave locks I think. What kind of tool do I need to take these friggen nuts off with. This is frustrating to say the least. I didn’t know I would need special tools to install. Please can some one advise… Grumpy you out there?
If it isn't one thing its another...I thought full floater meant no worries...it would be nice if I could get the FRIGGEN NUTS OFF to install them... :confused:
Are they just too tight? Typically when a rod is built, it is surfaced to make the hole undersized, the bolts are torqued, and then honed to correct size. Clamp the big end of the rod in a vise with a block of wood on either side of it, then use a socket to take the nut off. If the rods have cap dowels, you may have to tap the cap to get it off. Use a brass hammer VERY JUDICIOUSLY to loosen the cap.
