Head options for F Prepared Z
h4nsm0l3m4n
I've been studying to build a higher compression L28 for my autocross car. Seems like most FP Z cars use E31 heads but those are getting hard to find. I'd like to use a more common N42/N47 or ,ideally, a P90/P79 head. However since the P heads are out of the s130 I dont think you can use them on the s30 cars..
I checked the rulebook and all it says in the rulebook in regard to cylinder heads is:
1. The original or a specified alternate cylinder head shall be used.
Any valve guides and valve seats may be used.
2. Compression ratio may be altered by machining, using any head
gasket(s), or elimination of head gasket(s).
Could I use a P90 or P79 head in a FP autocross car?
Not in a 240Z. E31 or E88 for the 2.4L engine. A later, bigger valve E88 is a good choice.
I have an E31 with a fresh valve job and the larger L28 exhaust valves installed. Very reasonably priced in Seattle. DAW
Find yourself a maxima N47 head and fit it with 280Z N47 intakes if you want. TONS of compression (itty bitty 39cc combustion chamber) and really nice quench.
EDIT: post number 666, awesome.
Edited by Mack
Honestly, if you machine off the numbers of the cylinder head, they will never be able to tell the difference, unless they put it next to a stock one. Do any of the scca techs have a source of info for the z motors? or is it based on there call?
The 240Z has been raced with SCCA since 1970. Do you really think something as bush-league as that wouldn't be spotted by SCCA Techs and/or your competitors? FYI... I'm a SCCA Tech.
they have been racing circle track for over 50 years and we manage to get away with stuff like that.
  On 3/26/2010 at 12:46 PM, woldson said:
If you get away with something, is it then ok?
That's sort of the principle I'm going by. Most tech people here probably wouldn't realize or care that the p79, etc, heads came out of a later car. I don't plan on competing on a national level either, where inspectors might be more interested in whats inside the car. Heck, most of the time I don't even specify a particular class when I run, so really I can do pretty much whatever I want...
I'm trying to build the car per SCCA rules mostly because I thought it would be fun and more interesting to build the car to a particular ruleset.
Edited by h4nsm0l3m4n
More along the lines of it's "if not in the rule book its not a rule" there is no interpretation of the rule book, there is what is written and what is not.
So that is why their are warnings that are nuts, like cruise control on RV's. And others. I do see your point, however, dealing with contract of absurd sizes is also a product of this.
I do understand being unique about rules as needed, remember mercedies and their push rod engine years back, now that was ingenius and well within the rules.
Oh and BTW Hoov, I do like you, I find your comments clever and well thought out, so my comments are ment to shine some light, not castigate.
Except for the catch all rule the SCCA has in the GCR and the Solo2 rule book:
"If a modification is not specifically authorized in this or previous applicable sections of these Rules, it is not allowed"
Basically, if it doesn't say specifically you can, you can't.
The rules state:
  Quote
G. Cylinder Head
I'm not sure how I'd take that rule... you could take that to mean that only the original cylinder head that came on the engine may be used, but since 240s and 280s are listed on the same line in the appendix their engines can be swapped. Does the fact that any engine from the 3 models can be used that their heads can be swapped between them as well? I wonder if it's been protested before. If others are doing it without being protested you could probly get away with it, but you can write the PAC/SEB for clarification: seb@scca.com
Anyways, by whatever interpretation of that rule you pick the p-heads are not allowed.
  On 3/30/2010 at 10:55 PM, Two80z4me said:
dang, the techs in MT are slacking, some tried to tell me 78 280z's came with a turbo option :/ I guess I can getaway with turbo's here until I go to nationals lol
That's only because I've never inspected your car. I'll have to school our techs.
I was mistaken. You can put a P series head on a 2.4L engine although it doesn't make sense given that the minimum weight in FP is 1,900 lbs. With the weight/displacement formula a 2.4L could weigh 1,800 lbs. but can't. probably better to build a 2.8L which has a 2,100 lb. minimum.
