BTF/PTM Posted March 23, 2010 Share Posted March 23, 2010 I've found phrases in several threads from several forums that indicate that it may be possible to run (in a '72 240z) a 280zx D6K8 distributor in conjunction with a MSD-6A (or equivalent) without any igniter module on the distributor. Instead the pickup coil wires can be run directly into the control box and it's all good. Has anyone done this? If this can in fact be done, I'm very interested in this method. Thanks all. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 23, 2010 Share Posted March 23, 2010 (edited) I've found phrases in several threads from several forums that indicate that it may be possible to run (in a '72 240z) a 280zx D6K8 distributor in conjunction with a MSD-6A (or equivalent) without any igniter module on the distributor. Instead the pickup coil wires can be run directly into the control box and it's all good. Has anyone done this? If this can in fact be done, I'm very interested in this method. Thanks all. Nope. Doesn't work. Your car will explode in a fireball if you try it. http://forums.hybridz.org/index.php?/topic/77189-is-the-e12-80-module-required-with-msd-6al/page__p__734547__hl__msd%206al%20module__fromsearch__1entry734547 Edited March 23, 2010 by JMortensen Quote Link to comment Share on other sites More sharing options...
vantage Posted March 23, 2010 Share Posted March 23, 2010 Just wire the magnetic pickup coil's output wires to violet/green of the MSD 6A, thats all. Quote Link to comment Share on other sites More sharing options...
BTF/PTM Posted March 24, 2010 Author Share Posted March 24, 2010 Thank you, gentlemen. Jmortensen has put up with the same question from me on two forums now, but I promise I'll not ask again. Thanks for the link you put up, Jm, my primitive analog brain (I'm a mechanical engineer, I can't help it) isn't happy without very straight forward binary answers. That was exactly what I needed. Thanks again!! p.s. - if my car explodes in a fireball and no one's around to see it, will it still go snap-crackle-pop? Quote Link to comment Share on other sites More sharing options...
duragg Posted April 21, 2013 Share Posted April 21, 2013 (edited) Resurrecting this old thread: From the NA ZX Dizzy without Module there is a Red / Green Pigtail. The input to the MSD is a Green / Violet pigtail. Tossed a coin and wired: Dizzy Red-to-MSD Green DIzzy Green-to- MSD Violet. Hit the button and fired right up. TIming way off but tach worked fine. I've read some places that it doesn't matter which wire goes to which wire, and other posts say the polarity can mess stuff up. Everyone seems to agree that the Dizzy R/G go to the MSD G/V but not many posts make it clear in which order. Edited April 21, 2013 by duragg Quote Link to comment Share on other sites More sharing options...
30 ounce Posted April 21, 2013 Share Posted April 21, 2013 If the wires are backwards it will run very poorly. I wired mine backwards at first because both wires from my distributor look purple. I could not tell a difference. After a few phone calls to MSD they hit on this. I reversed the wires and all was well. Quote Link to comment Share on other sites More sharing options...
duragg Posted April 21, 2013 Share Posted April 21, 2013 Dizzy Red-to-MSD Green DIzzy Green-to- MSD Violet. Starts and idles perfectly and seems to run good. But Snap-on (evil dial-back light) timing indicates funky to be about +30 degrees (36 idle and 60+ all in). Reversed: Dizzy Red-to-MSD Violet DIzzy Green-to- MSD Green Starts crappily, idles lunky, spits and barks at higher rpm But Snap-on (evil dial-back light) timing indicates timin just right where I put it staticly (15 Initial / 36 higher rpm). Previous to installing I pulled VC, verified TDC and put the bar-left-of-Notch and crank pulley mark lined up proper. Guess I should double check with a regular dumbass timing light. Quote Link to comment Share on other sites More sharing options...
duragg Posted April 22, 2013 Share Posted April 22, 2013 Final config: Dizzy Red-to-MSD Violet DIzzy Green-to- MSD Green Dicked around with timing and got it squared away. Snap-on dial-back timing light seemed to work fine and agreed with crappy Harbor Freight non-adjustable light. Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 22, 2013 Share Posted April 22, 2013 Are you still at 36 static and 60+ all in? Quote Link to comment Share on other sites More sharing options...
duragg Posted April 22, 2013 Share Posted April 22, 2013 Are you still at 36 static and 60+ all in? No, It never really was there. With the mag pickup wires hooked up backwards in reverse polarity the timing shows funky numbers. Once polarity was corrected to Green to Green, Red to Violet the timing was where I set it statically at +15 / +35. Quote Link to comment Share on other sites More sharing options...
tamo3 Posted April 24, 2013 Share Posted April 24, 2013 So, is it same thing to use 280z(not zx) distributor + MSD - 6AL? Quote Link to comment Share on other sites More sharing options...
duragg Posted April 25, 2013 Share Posted April 25, 2013 Yes I think so. I thought mine was a ZX. It had a black box on the side but it wasn't marked e12-80. It had something like Fy4 on it? I need to check. There may be a 2 and a 4 wire configuration. Quote Link to comment Share on other sites More sharing options...
tamo3 Posted April 25, 2013 Share Posted April 25, 2013 I wonder there is any advantage to use 280zx distributor without e12-80 box along with MDS-6AL. If there is no advantage over 280z distributor + MSD-6AL, it is cheaper solution. Quote Link to comment Share on other sites More sharing options...
30 ounce Posted April 25, 2013 Share Posted April 25, 2013 I'm using a 260 distributor & MSD6. Different advance curve & amount. Quote Link to comment Share on other sites More sharing options...
duragg Posted April 25, 2013 Share Posted April 25, 2013 The Mech Adv in my dizzy was stamped 9.5 = 19 total mech advance. Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 25, 2013 Share Posted April 25, 2013 If you use a ZX distributor with the ignition module (black box) intact, aren't you using a module to trigger a module? Instead of the sinusoidal signal, the output would be square. You should be able to take the ZX module off and just use the wires inside from the magnetic pickup, if i understand the MSD instructions correctly. Wondering. I've never used an MSD but it's tempting, to try to smooth out the idle a bit. Quote Link to comment Share on other sites More sharing options...
duragg Posted April 25, 2013 Share Posted April 25, 2013 I removed the module and trigger directly to the MSD. Smoother idle? Ya, maybe. Seems to start better for sure (I have triples). They stabilize at whatever RPM they feel like being at that particular moment much more quickly. I had a thread a year or two ago about unstable timing indications. With this new ZX Dizzy, and the modules the timing indications are rock steady as viewed from two different timing lights. Quote Link to comment Share on other sites More sharing options...
