malibud Posted May 21, 2014 Share Posted May 21, 2014 I am looking for some where to vent my BOV. I see a lot of people venting it into a vacum port on the intake I was told to put it a 60 degree bend right before the turbo . Does it make a difference ? Thanks Dan Quote Link to comment Share on other sites More sharing options...
SDgoods Posted June 30, 2014 Share Posted June 30, 2014 On 5/21/2014 at 2:41 PM, malibud said: I am looking for some where to vent my BOV. I see a lot of people venting it into a vacum port on the intake I was told to put it a 60 degree bend right before the turbo . Does it make a difference ? Thanks Dan I vented mine to the turbo inlet with some radiator hoses and an epoxied fitting on the turbo inlet Quote Link to comment Share on other sites More sharing options...
davek Posted July 18, 2014 Share Posted July 18, 2014 SDgoods That's a good idea Did it quite the swoosh down to almost nothing? Quote Link to comment Share on other sites More sharing options...
SDgoods Posted July 19, 2014 Share Posted July 19, 2014 On 7/18/2014 at 8:31 PM, davek said: SDgoods That's a good idea Did it quite the swoosh down to almost nothing? Thanks... it quieted it down and I believe just made the whole system work better... the air re-entering after the maf (running z31 electronics) has already been metered as opposed to metered air being vented and in turn running rich during shifts. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted August 21, 2014 Share Posted August 21, 2014 Upgraded my crappy intercooler to a huge one. A bit too large, it took some pie-cuts and lots of finagling. Old one: New one: I'm happy with the fitment. Still needs some real mounts on it to hold it in place, but the piping does not rub on anything anymore, and the fitment relative to the radiator is much better. Quote Link to comment Share on other sites More sharing options...
cuztm240z Posted June 17, 2015 Share Posted June 17, 2015 I did 3" piping with a 31x12x3 intercooler everything just barely fits, still dont know if my stock hood will work. Crossing my fingers that the hinges will clear. Quote Link to comment Share on other sites More sharing options...
hwvigo Posted July 16, 2015 Share Posted July 16, 2015 This is my current setup awaiting the pipes to be made this weekend. Quote Link to comment Share on other sites More sharing options...
hwvigo Posted July 20, 2015 Share Posted July 20, 2015 (edited) On 7/16/2015 at 2:05 PM, hwvigo said: This is my current setup awaiting the pipes to be made this weekend. 11222956_10203007433667066_4722877405544169974_n.jpg 11248807_10203007435947123_4741637207980555556_n.jpg 11694743_10203007436347133_7649123919325942699_n.jpg Got the pipes done and intercooler install done and it came out dang near perfect. Edited July 20, 2015 by hwvigo Quote Link to comment Share on other sites More sharing options...
Barrel_Ball Posted July 10, 2016 Share Posted July 10, 2016 (edited) I think somebody mentioned an air/water setup, earlier? PWR 5x6" core, will be using a Honda CR80 radiator as the front heat exchanger, and an RB25 recirc valve. Probably the shortest, intercooled piping setup on one of these engines. We're almost done with the fabrication, just need to plumb the recirc outlet, and paint the pipes before doing the coolant plumbing. EDIT: Done fabrication and paint. Core is installed. Even runs stock air box! Edited September 20, 2016 by Barrel_Ball Quote Link to comment Share on other sites More sharing options...
