aplyedmind Posted September 20, 2010 Share Posted September 20, 2010 Wow that center console is pretty early 115 outta 3000. I wonder where the car is . By the way your ZX is Coming out very nicely Really digging the wheels and the whole look. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted September 21, 2010 Author Share Posted September 21, 2010 The 10th Ann has been decommissioned a long time ago. Frame was beyond any help. I'm getting the digital cluster sometime this week so I'll be installing that as well as changing the color of the display to something else besides green.. Well see how that goes. That'll be posted up when it's done Quote Link to comment Share on other sites More sharing options...
abc_was_here Posted September 21, 2010 Share Posted September 21, 2010 You've got one good looking S130! Quote Link to comment Share on other sites More sharing options...
richracing Posted October 3, 2010 Share Posted October 3, 2010 nice progress. one question though, why would you put the boost/ vacuum gauge where its hardly visible? also, sell the grids and find some lower offset wheels. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted October 4, 2010 Author Share Posted October 4, 2010 Grids was almost in impulse buy.. And I was having a slightly hard time finding something nice on a budget.. Eventually I'll get something better but it's good for now. Boost gauge I'll probably replace with something nicer on the A-Pillar.. But in due time. The prosport one is crap anyways. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted October 13, 2010 Author Share Posted October 13, 2010 So the Digital cluster will have to wait.. apperently I need the dash harness too. oh well.. however the valve cover is finally done heres a pic.. and since I ran out of distractions I need to get back to the turbo swap.. still need some misc pieces.. Quote Link to comment Share on other sites More sharing options...
310z Posted October 17, 2010 Share Posted October 17, 2010 The valve cover came out nice. It looks good under the hood. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted October 27, 2010 Author Share Posted October 27, 2010 Update- ordered my oil lines and T3 turbo rebuild kit. They should come in early next week. I'll post up the turbo rebuild on this thread. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted October 29, 2010 Author Share Posted October 29, 2010 So the oil lines came in yesterday, the feed doesn't seem long enough tho... Oh well eBay, what can you expect? Also, I picked up a set of strut tubes/hubs so I can finally get my car lower.. I'm gonna go with a set of coilover sleeves and springs. That will be late next week or maybe even the week after.. But in the mean time I can prep the struts, cut the perches off and clean them up.. Can you believe they were $140 at pick n pull? Dayumn!! Anyways.. I'll post up some pics an junk later after work. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted November 1, 2010 Author Share Posted November 1, 2010 So heres the ebay oil lines i got. Also the struts i got, and the result after i cut the perches of to put the sleeves also i had an epic win at pick-n-pull today. picked up digital cluster and gauges with the dash harness, also replaces my horribly oxidized rear view mirror. plugged the harness in and voilla!! it works! Excuse the crappy Iphone photos Quote Link to comment Share on other sites More sharing options...
PurePontiacKid Posted November 2, 2010 Share Posted November 2, 2010 WTF! you spent $140 on strut tubes from the junkyard?! that's crazy man lol I wouldn't spend moar than $60 on a pair of struts from the junkyard, $100 with hubs haha you're not going to section them? what shocks are you going to run? spring rates? Quote Link to comment Share on other sites More sharing options...
akumazedex Posted November 2, 2010 Author Share Posted November 2, 2010 (edited) na, jus gonna go with the sleeves with my tokicos. Yeah, the struts were a bit rediculous but ehh. no idea on spring rates, gonna mock up a set of some generic sleeves i can get from the local shop, if that works i'll get something more precise, probably ground control. I have to figure out whats the lowest i can put the perch before i rub my wheel on it.. I finally got tired and want to drop it lol. Plus this way is much cheaper than s13 coilover swap.. not all of us here are rich hahaha.. just a thought, i think i need hub spacers if im gonna go lower.. Edited November 2, 2010 by battlesquaddatsun Quote Link to comment Share on other sites More sharing options...
akumazedex Posted November 3, 2010 Author Share Posted November 3, 2010 I finally got around to swapping my gauges today, heres how it went.. To start of, heres the before.. stock analog gauges Its easier to get the cluster out if you drop the steering wheel, two bolts on the column. Once you get the 4 screws holding the cluster in place out and disconnect the spedo this is what youll have left Next youll need to remove the radio console 4 bolts on each side Youll need to detach the climate control from the dash, not necessary to remove it tho now the fun stuff, unbolting the dash, theres 4 bolts on the bottom and 4 screws under beauty covers in top slowly start to wiggle the dash free making sure to detach any connectors in the precess carefully and voila! heres the dash with the harness still attached and heres what were doing, swapping in digital cluster and turbo gauge pod heres the backside, remove the harness and replace with the digital one, connectors are the same as the analog but we need the whole thing, also a good time to replace that buzzing center speaker that has been annoying you for years with the gauge pod installed installing is the opposite of the removal and the finished result Quote Link to comment Share on other sites More sharing options...
akumazedex Posted November 6, 2010 Author Share Posted November 6, 2010 so I got the T3 rebuild kit in finally. I'll be working on it this sunday so I'll post up some progress when I have some. Quote Link to comment Share on other sites More sharing options...
AKZX Posted November 23, 2010 Share Posted November 23, 2010 I know this is simple and probably obvious to most people, but I'm in a 1980 280zx Non-turbo with a set-up similar to yours. I have a Prosport gauge on either side of where the stereo would fit, but how did you get the stereo in? Is it a universal adapter to fit it? I have a metal plate with a rectangle cut in it, but I don't know much about electrical or stereo installation.. Quote Link to comment Share on other sites More sharing options...
akumazedex Posted November 27, 2010 Author Share Posted November 27, 2010 I'm sure there's a plugin adaptor but I just cut off the factory connector and wired it in directly to the aftermarket harness the new one comes with Quote Link to comment Share on other sites More sharing options...
Sonethirty Posted December 10, 2010 Share Posted December 10, 2010 Updates? Quote Link to comment Share on other sites More sharing options...
akumazedex Posted December 24, 2010 Author Share Posted December 24, 2010 You asked for updates and you shall have, Ive been more active On ratsun actually, diddnt think anyone was following this thread anymore. so after many days of procrastinating the turbo if finally back together. I talked to some of the guys at GPOP about the cracked turbine housing and they said its not a big deal. yes, I am stubborn. haha correct me if im wrong, i dont remember the parts off the top of my head so this is everything in pieces the center section has two bushings and four snap rings, those all get replaced the back of the compressor, the center springy thing for the thrust washer and the bearing get replaced the new thrust bearing now you can start putting everything back together the turbine housing and compressor wheel back on the compressor housing back on, be sure to clock the housing, otherwise youll have clearance issues and fitment problems reinstall the wastegate actuator and voilla! dones. now you have a nice rebuilt turbo for a fraction of the cost of a new one, sure its not pretty but it works. Prices: Garrett Airesearch T3 turbo $60 from HybridZ G POP shop complete rebuild kit about $110 shipped personal satisfaction of mending something, 4 tquitos and a slerpee now all I need is Turbo fuel pump, turbo oil pump and the oh soo confusing megasquirt I finally got around to replacing my heater core on my car after it decided to try and recreate the great lakes on my floor. This was a really fun job, riping the dash out and swapping it out took most of the day but now its done. I just need to replace the heater control valve because the old one was leaking to, its bypassed for now. And now some goodies. I got a set of ground control sleeves and springs for the front struts (out of my old 210). So now theyre almost ready to drop in. Hopefully I can get them welded in. Quote Link to comment Share on other sites More sharing options...
Sonethirty Posted February 1, 2011 Share Posted February 1, 2011 MOAR UPDATES!! Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted May 28, 2011 Share Posted May 28, 2011 updates please Quote Link to comment Share on other sites More sharing options...
