OniZ Posted January 24, 2011 Share Posted January 24, 2011 I found a lsd in the junkyard and the spot it is in is a pain to remove. I was wondering if it is possible to just take the spider gears and install them in the diff i have now. Does anyone know if the internals are the same or different? I have the r200 now but it's an open diff. oh and i also have a 240z Quote Link to comment Share on other sites More sharing options...
johnc Posted January 24, 2011 Share Posted January 24, 2011 I found a lsd in the junkyard and the spot it is in is a pain to remove. I was wondering if it is possible to just take the spider gears and install them in the diff i have now. Does anyone know if the internals are the same or different? I have the r200 now but it's an open diff. oh and i also have a 240z The internals should be the same but its even more of a pain to remove the diff internals then it is to just remove the whole rear end. Endure the pain and get the whole unit out from under the Z31. Quote Link to comment Share on other sites More sharing options...
OniZ Posted January 24, 2011 Author Share Posted January 24, 2011 thanks for the info i will it's almost there anyway. Quote Link to comment Share on other sites More sharing options...
OniZ Posted January 24, 2011 Author Share Posted January 24, 2011 oh if i take out the stub axles from the diff can i swap them with the older style? Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted January 24, 2011 Share Posted January 24, 2011 Not usually, I think the Spline counts are different. Quote Link to comment Share on other sites More sharing options...
OniZ Posted January 25, 2011 Author Share Posted January 25, 2011 what parts will i need if i have to change to the cv style then? Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted January 25, 2011 Share Posted January 25, 2011 Not usually, I think the Spline counts are different. Na, pharaoh knows not the truth... I have 280z stub axles/half shafts in my z31 r200. fits perfect. cheaper too... Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted January 25, 2011 Share Posted January 25, 2011 Oh? That's news to me, I'd thought the Z31 LSD's used the higher # of splines, but I just re-read my notes and it seems it's the R180 that has different splines than the R200's that includes the Z31. So yeah, my bad. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted January 25, 2011 Share Posted January 25, 2011 The 88 Z31 SS had a VLSD with different spline counts. All other 87-89 Turbos had a CLSD with the 280Z R200 spline counts, IIRC. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 25, 2011 Share Posted January 25, 2011 Yes, the 280Z stub shafts work with 240-280ZX, 510 and probably some other U jointed halfshafts. The problem for the OP is he has a 240, so he won't have those stub shafts to use, unless someone else already installed an R200 in his car. The yoke is also different, so his driveshaft won't line up. I put a list of parts needed in my big sticky diff post. Quote Link to comment Share on other sites More sharing options...
OniZ Posted January 25, 2011 Author Share Posted January 25, 2011 i have a r200 with the stubs that fit all of my factory set up and i have the correct phlange to swap for the driveshaft too Quote Link to comment Share on other sites More sharing options...
