I used a dremel at medium speed with a cutter bit to make the inside even.
Then I used a drum sander to clean off the plastic burrs.
Then put the gauge in from the out side and use the included mounts. fron behind. I used a washer and nut to tighten and hold the gauge to the outer ring.
I figured out the place where the posts would come through the back.
Then drilled them out.
I put the back cover on and drew an outline around the power/sensor and light bulb posts.
I used the dremel cutter to cut out the section for those areas.
Pass the light wires through the hole you just made.
Mount the rear cover and screw into place with the original screws.
Use the meter's supplied star washers and thumb nuts to tighten it all down.
re-install the original bracket "thing"
Put the gauge under that dash and screw the mounting bracket on.
Help
View Garage
