1970 240z
  • Content count
    7
  • Donations
    0.00 USD
  • Feedback
    0%
Community Reputation
0 Neutral
About 1970 240z
  • Rank
    Newbie
  • Gender
    Male
  • Location
    Arizona
Recent Profile Visitors
Enable
  1. Hope this helps. Using a Test light or Multi-meter: Check for power at the fuse block(see diagram of fuse block), both ends of the fuse should have power. Power on one side and not the other means bad fuse or fuse connection. Check to see if you have power (from the fuse box) on #2 in diagram (Grn/Blk) wire at the connector on the column that leads to your Combo Switch. If so, Jumper #2 to #1 (Grn/Wht) which leads to the marker lights and your markers should light up. If lights work with jumper but not when plugged back into switch and in on position then switch is the issue. (1977 280z Wiring)
  2. As a side note, I replaced my turn signals with LEDs as well on my 77 280z. I didn't use any load resistors. I simply replaced my flashers with electronic ones from Rockauto, Oreilly's has them too. They've been working great for a couple years now.
  3. 1970 240z
    Will this plastic filler crack?
    Google "How to use a Stud Welder and Pull out a Dent", I think that should help improve your corner, or maybe you could rent one, or ask a body shop to straighten that one corner metal shaping it only.
  4. 1970 240z
    VG30ET swap
    I'm not a z31 guy, but i would think a turbo engine harness and maf
  5. 1970 240z
    Custom Fuel Rail
    Reach out to Pallnet, he has made many fuels rails for folks here. http://forums.hybridz.org/topic/99098-pallnet-fuel-rails/
  6. 1970 240z
    ZX Weatherstripping Supplier Found
    My t-top zx needs doors seals too, I hope he can offer them.
  7. Looks like I missed out on this run, it there going to be another?
  8. 1970 240z
    1977 280Z SWAP AC
    Will, I have a 77 280z with RB25DET Neo and I am running ac. I had no clearence issues with the RB AC compressor (looks to be the same as a 2000 sentra other than sentra has larger pulley). I did have a failure with my RB compressor so I switched to the 2000 Altima comprssor as it is more durable, I had to change the fittings on my lines at the compressor as the ports were located differently. The Altima is also physically larger. It still fit but was a tighter fit than the RB/Sentra compressor.
