nzarano
nzarano last won the day on August 22 2019
nzarano had the most liked content!
  • Gender
    Not Telling
  • Location
    Near: Summit, New Jersey usa
Recent Profile Visitors
7605 profile views
nzarano's Achievements
Newbie
  • Dedicated Rare
  • Conversation Starter Rare
  • One Month Later
  • One Year In
  • Week One Done
Recent Badges
  1. I was away for the weekend and had a shop install a full legalis system on my '73 240z and it fits like sh1t.... the muffler is low and to the left, the whole thing is low, and the first resonator bit doesnt sit snug, the actual header hits the crank vent....wondering what modifications people have done to make it fit or if there is an installation order of operation/ tips and tricks to make it fit? The 2nd image where the first resonator (or whatever it is?) shows where i think all the issues start, but not sure how thats supposed to be made to fit.... Looked around and everyone seems to think its supposed to fit the way it comes.... Quite annoyed
  2. nzarano
    Speeduino
    look into some motorsport anti vibration (AV) mounting. Pretty much just grommets on bolts but if they can survive in race cars they can survive most things...ifused properly!
  3. nzarano
    Speeduino
    will definitely be messaging you for info as i doing an na to turbo conversion and planning on going this route... its simple enough but powerful enough but not extremely well documented for the Z which has me a bit on edge.... do you have any xl files or other planning documents youve used? I want to make sure i get all the right sensors etc and theyre all compatible and someone has maybe used them (so a comprable basemap can maybe be had...) Building a motorsport grade harness (or trying.. deutsch connects are crazy expnseive!) so once I have a list of components can start mapping a loom and stuff! Glad to see someone doing this, looking forward to updates
  4. would you ship it to the east coast?
  5. Noticed that compressor brackets were hard to come by or expensive for Sanden and newer style compressors, would people be interested in these? Need like 10 people to get them made probably
  6. guaging interest....I have access to a high volume and high end production facility, would people be interested in these cranks? these would be brand new... could potentially be forged or billet...
  7. has anyone used the silvermine kit? its priced and looks oddly similar to the CRX racing kit... Ive bought stuff from silvermine before and had no qualms but it has caught my attention that a bunch of their stuff looks similar (albeit a bit ...cheaper?) to other companies. Seems like a good price but at this point just want to make sure for 100$ more or something I wouldnt be better off with a different kit
  8. title says it all...currently have header to 2.5" all the way back to a 10"x6" oval muffler that has 2x3" exits and its jsut hard to keep a conversation in the car on the highway....
  9. there are a bunch of different ways to do a parallel hybrid system but honestly the starter motor on the 240z is super old ive seen motors that size these days be able to put 20-30hp + out. If using capacitors for quick burts then your power pack can be fairly light and you can get a good advantage on power to weight also while increasing overall efficiency would need: the motor some inverter / ac/dc dc/dc or whatever converters are needed based off your power source, regen, and your motor energy storage batery/cap management potentially some sensors and other stuff to make sure everything plays nice if its capacitors might not even need a charging circuit. think the hardest part right now would be making sure it all plays nice and maybe making a clutch for it, these days you can find motors that can operate in so many different conditions, if the right one is found and an adapter and potentially a clutch and a grear box might need to be made.... vonnen does a cool kit for porsches where they pretty much integrate everything into the bell housing. this would be a way cooler peice of kit, but could cost quite a bit more and be more complicated to develope.
  10. Been trying to look around and havent found much....has anyone tried turning their z into a hybrid? (figured this was the right place for ittaking a class on electric vehicles thouht the possibility was intesting.... you have enough space where the starter is to design something that could add some power directly to the flywheel... with capacitors and a regen system could be fairly light and good fun. looking to see if anyone has done something like this for the L-series or similar engine and car thank you!
  11. has anyone tried making their own exhaust similar to the legalis r? I have a header similar to the pace setter that goes 3-2-then a y pipe 1 to.... was thinking y out again to two pipes (size recommendations?) then an x pipe muffler then 2 lines to a final circular muffler.... i currently have header straight into 3" pipe with a resonater which is halfway along the driveshaft, then a magnaflow or knock off magnaflow from a local exhaust shop with a signle 2 3/4" i think inlet and 2 2" or so outlets and no tips... it sounds pretty good but it drones and i cant hold a conversation in the car ever even with some dynamat under the carpets.... I just want an exhaust thats sub 3-400 ish (i can fab stuff if need be) that i can hold a conversation while cruising, even if i have to talk slightly louder, but also have a sweet exhaust note any input appreciated! thank you edit: spelling
  12. flat surface is ideal, however with ball transfers and level these can compensate slightly.....they can also come with load sensors to do corner weights. For caster turn in plates do help but arent necessary. these can help with measuring caster as well. really help with all measruements if you use them right. theyre used by most racing teams because theyre quick, easy, and dont take up alot of space
  13. exactly this! my designs were made for a race team to help make toe, camber, etc adjustments quickly. We can change set up 3 times a day during testing and they can be quite different set ups. probably only for people tracking their car that wants better accuracy than standard at home adjustment methods and dont want to have to pay someone to adjust their suspension.
  14. i have a set of dished pistons from a 280 used but has rings, came from working car message me can have them shipped tomorrow!
