AC Delco/GM Alternator Swap Part 2 - CS144 Installation
  • Please log in to reply
31 replies to this topic
#21 Hardwyre
Hardwyre
    Junior Member
  • Members
  • PipPip
  • 47 posts
  • LocationVancouver WA
Posted 09 January 2010 - 10:53 PM
The swap was successful except my charge light on my volt meter doesn't seem to light up anymore. I used a 100ohm resistor off the alternator. Headlights don't dim anymore when I have the radio, radiator fan, and heating going anymore.
#22 Hardwyre
Hardwyre
    Junior Member
  • Members
  • PipPip
  • 47 posts
Posted 11 January 2010 - 11:27 PM
Okay boys and girls; apparently there is a unique deal with '76 280z and this swap.
Your battery will die if you don't rewire/disable the "brake warning lamp check relay". I had a dead battery this morning and have been fighting with it since I got home from work. Zed apparently ran into this problem before me and was awesome enough to point me to this thread:
http://www.classiczc...3999#post313999
You'll know you're possibly going to have problems with this swap and need to hunt relays if you hear the relays click/throw when you reconnect the battery, even if the car is "off". After I cut the yellow wire, it was dead silent when the negative terminal was reconnected. Thank you Zed!
Posted Image
#23 jeffp
jeffp
    Level 10 Necroposter
  • Banned
  • PipPipPipPipPip
  • 595 posts
  • LocationReno Nevada
Posted 28 January 2010 - 02:07 PM
I have since decided to go with yet another upgrade for the alternator. This unit is made by Penntex out od Texas. The alternator is mede her in the US. I think this just may be what I was looking for in the first place.
The differences in the alternators are for one date of manufacture. The other is the r4ectifier set for each unit, and as you mentioned the rotor. Also the 244 unit has two cooling fans, one in the front and back.
Realistically, you are correct 140Amps should be sufficient for welding LOL, or to power your car easily.
The problem with the Alternators are the CURRENT OUTPUT @ idle, and that is where you run into problems. Ecah alternator is rated at X amount of rotor speed for that unit. You will note the differences in the rotor speed of each unit for the specified output current. The smaller units "generally speaking" will require a faster rotor speed to get the unit into the higher current ranges that we would like to see at idle. Easier said then done. The other thing you will notice is that the larger the alternator current output, "Generally speaking" the more current it is able to provide ast a lower rotor speed.
So that was my criteria for the 244 unit "and it is fully upgraded with the stator, brushes, Diode rectifier, and finally the external regulator I installed. So I started with a 200.00 part that was stated to provide me with 95 amps at idle, it did not do that. So I called and it was mentioned there was a larger stator, and better diode block for the unit. I bought those, again the alternator did not fit my needs. I changed to a 2 " pulley to spin the alternator faster. Still not quite where I wanted it. I was seeing the line voltage drop off after the alternator got hot. So then it was the internal regulator that was the problem. I bought that for 145.00 (external unit) and installed that. Still not what I wanted and it did not improve the line voltage drop when the unit was hot.
So in a nut shell, the unit would not do what I wanted it to do after spending 500-600 total on the install and upgrades, for this one unit it still was not quite good enough. So what to do now, lower my line voltage to 13.8 that seemed to work, but again I am where I started. Total waste of money in my opinion.
True, I have somewhat of a unique situation with my car, so like I mentioned somewhere else, a 200 amp unit is not required, however if you are looking at idle current, the the only things you can do are spin the rotor faster, and that helps. The second thing you can do is get more robust, higher current devices in the unit that will not get so hot, and finally increase the windings of the stator.
I did all of those "upgrades" and still could not maintain 14.2 volts @ idle when the car was fully warmed up. So for me this was a total waste of money, and my time.
Take a look at the new unit and see what you think. I built the bracket and I think that part is about strong enough to lift the whole car LOL.
Do you have any ideas that would make the page links better? I do have the mouse-over funstion on the page links. So if you leave the mouse on the small picture the title of the page will show, and you get the page title on the explorer lower tool bar. Anyway.
I really am interested in the performance of this new unit. My goal is to maintain 14.2 volts under any condition, well within reason, so if I can run the car, turn the lights on, and at that time an electric fan, and electric water pump. I have since went away from the electric water pump for some heat testing of the cooling modifications I have made.
This alternator was NOT cheap, but if it does all that it says then worth every penny.
This has been an ongoing modificaton for me, very costly to test all of the different parts and all the upgrades, will it never end LOL.
#24 logan1
logan1
    Member
  • Members
  • PipPipPipPip
  • 315 posts
  • LocationTulsa, OK
Posted 19 April 2010 - 06:53 AM
How did you guys get the nut off that central shaft for the CS144 to swap the pulley for the V-groove pulley?
#25 Nigel
Nigel
    Member
  • Members
  • PipPipPipPipPip
  • 783 posts
  • LocationToronto, Ontario, Canada
Posted 19 April 2010 - 06:30 PM
Impact gun, or if you don't care about the old pulley, then just clamp it in a vice.
Nigel
'73 240ZT
"May the Forced Induction be with you"
http://www.motortopia.com/nigel/cars
www.ontariozcar.com
Avatar courtesy of J.P. Matte
#26 Nigel
Nigel
    Member
  • Members
  • PipPipPipPipPip
  • 783 posts
Posted 30 August 2010 - 03:15 PM
Update:
I've had my CS-144 alternator in my Z for just over a year and less than 10K miles now. It was working fine up until a few weeks ago. I started to hear an occasional rattling sound coming from somewhere near the front of the car when the engine was idling. At first they were brief rattles, that would just last for an instant and sounded something like a loose exhaust heat shield. But it quickly became more persistent, to the point that it would often be a constant, loud, whirring, rattling noise any time the engine was idling. However, to complicate matters, sometimes there would be no noise at all, like everything was fine. Or, it would start out noisy, and then just go away.
My initial fear was that it was the timing chain. If I had to imagine what a loose timing chain would sound like, this would be it, and the sound was coming from the very front of the engine. But with the use of a stethoscope, it was determined that the sound was actually coming from the alternator. After removing the belt, and turning the alternator by hand it was easy to hear and feel that the alternator fan was rubbing on the housing. But why?
The rotor in the later model of these alternators is bolted to the inner race of a ball bearing that has the outer race pressed into the front housing of the alternator and provides the main support for the rotor. At the rear is a small needle bearing that the other end of the rotor sits in. Other than the press fit of the ball bearing in the housing, there is nothing securing the rotor axially in the alternator. As I was told by a reputable alternator repair shop, sometimes the ball bearing will work itself loose in the housing, and the rotor will gradually move back in the alternator until parts start rubbing. If this happens, the housing is junk, and there's no point in reusing it. It will just keep happening. If you didn't do anything about it, I'm sure the alternator would eventually seize right up. Earlier versions had a plate that secured the bearing in the housing to prevent this. So much for progress...
Here's an exploded view of the later version of the CS-144 alternator...
Posted Image
Hopefully posting this will reduce the troubleshooting time for someone in the future.
Nigel
Edited by Nigel, 30 August 2010 - 03:15 PM.
www.ontariozcar.com
#27 Nigel
Nigel
    Member
  • Members
  • PipPipPipPipPip
  • 783 posts
Posted 14 September 2013 - 03:54 PM
Update #2
I've just had a second alternator fail due to the ball bearing coming loose in the front housing! There is a snap in retainer available (part number 46-1509 in the exploded view I provided in my previous post), but neither the OEM or rebuilt CS144 alternators I've had have one. I'm going to try to get one, and hopefully salvage the alternator I have now. It's only a $2 part. I'd advise anyone doing this swap to install one.
Nigel
www.ontariozcar.com
#28 Nigel
Nigel
    Member
  • Members
  • PipPipPipPipPip
  • 783 posts
Posted 17 September 2013 - 01:47 PM
Here's a picture of the inside of the front housing after the bearing had worked itself part way out:
I stopped by a local alternator repair shop and they gave me the snap-on bearing clip for free! (Thank you R&D Auto Electric in Brampton, Ontario!)
Nigel
www.ontariozcar.com
#29 tamo3
tamo3
    Always Here
  • Members
  • PipPipPipPip
  • 433 posts
  • LocationSan Jose, CA
Posted 10 October 2014 - 09:15 PM
It was so hard to remove pulley.
I followed this step to try to remove pulley.
http://www.ifsja.org...ad.php?t=131960
Attached File  cs144sidepulley_02.jpg   45.71KB   2 downloads
I don't know how much I need to bang hammer with 27mm socket.
I try to use impact gun to try to remove the tapered collar.
Attached File  IMG_6524.jpg   111.91KB   2 downloads
No luck to remove the collar.
I decided to cut it off.
Attached File  IMG_6529.jpg   109.38KB   2 downloads
Attached File  IMG_6532.jpg   93.03KB   1 downloads
Attached File  IMG_6533.jpg   98.81KB   2 downloads
Once the collar comes out, pulley fell off!
Attached File  IMG_6534.jpg   121.26KB   1 downloads
Once the pulley is out you may now get very excited and start telling your wife all about how awesome you are. When it becomes clear that she simply does not appreciate just how awesome you are, proceed to next step .....
Attached File  BEER.jpg   31.87KB   1 downloads
Beer!
Edited by tamo3, 10 October 2014 - 09:24 PM.
#30 HuD 91gt
HuD 91gt
    Always Here
  • Members
  • PipPipPipPip
  • 123 posts
  • LocationVancouver
Posted 20 October 2016 - 02:51 PM
Alternator gurus please help.
Purchased this 1994 Cadillac Seville Alternator to do a conversion on my 240z.
The alternator looks almost identical to the one in this thread, but it has the connector on the side, with 3 individual connectors. This bunch of wires does not let the alternator twist in it's mount to adjust.
Does anyone know what these are? I tried removing the connector, but can't seem to open the alternator. Also the connector which which holds the sense wire has 4 wrongs, from this thread it seems the others have 2?
1971 240z - Balanced .040 over L28 w/ Ported P90 head - Colt c542.s cam, SU w/SM needles, MSII (ignition)- LS2 Coils Wasted Spark, MSA Premium Exhaust - 6-3-2 Header
#31 HuD 91gt
HuD 91gt
    Always Here
  • Members
  • PipPipPipPip
  • 123 posts
  • LocationVancouver
Posted 20 October 2016 - 02:54 PM
Pictures
EDIT:   Further investigation shows that I purchased an alternator for a Cadi with a heated windshield.   The 3 wires coming off the alternator are an AC output for the windshield.  This version of alternator also has one extra prong.
Let's hope I can dissemble the casing, and reclock the ALT so the connection is on the other side and gives me a little more room.
Edited by HuD 91gt, 20 October 2016 - 08:40 PM.
#32 HuD 91gt
HuD 91gt
    Always Here
  • Members
  • PipPipPipPip
  • 123 posts
  • LocationVancouver
Posted 21 October 2016 - 01:13 PM
Well, after some research I disassembled the alternator, removed the AC wires, clocked the alternator over 90 degrees and put it all together.
On my '71 240 I purchased the msa converted for an internally regulated alternator. I attached the 12v constant yellow to S "sense" output. I then attached the switched 12v wire to F "field" prong.
I'm not getting any charge at all. The later 280z had a discharge light. Is this used as the exciter? I don't believe a 240z has this. Do I require a resistor?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
