Post your Intercooler setup.
  • Please log in to reply
128 replies to this topic
#41 sq_creations
sq_creations
    Member
  • Members
  • PipPipPipPip
  • 429 posts
  • LocationAlbuquerque NM
Posted 18 January 2011 - 04:32 PM
Posted Image
Posted Image
Posted Image
73 240z - LQ4, BW S480, AEM EMS, Glide, Moser 8.8 - 770whp/703wtq - 9.56 @ 147mph
97 Integra - Built B16, SC61, SQC Chip - 11.8@125 (sold)
97 Buick Regal GS - Supercharged Daily
http://www.sq-creations.com/240z.html - My Turbo V8 240z build
#42 mr jdm
mr jdm
    Member
  • Members
  • PipPipPipPip
  • 246 posts
  • LocationChicago
Posted 18 January 2011 - 08:48 PM
Posted Image
#43 cd1105
cd1105
    Member
  • Members
  • PipPipPipPip
  • 143 posts
  • LocationOakland, C.A.
Posted 19 January 2011 - 08:28 PM
Im using a 2" to 2.5" 90* elbow right off the stock t3. 2.5" all the way to the 60mm TB. I figured it would be the smoothest way to transition from the two sizes and 2.5" inlet/outlet inter coolers are plentiful. used an ebay kit and had left over parts but I didn't go under the motor or anything fancy. My cold side is rather long as it comes from the passenger side fresh air hole in the core support, I dont like the idea of adding more bends and trading cooler air for less efficiency. One of the reasons I went bar and plate for the IC.
Thanks :) what ebay kit did you buy? i bought one(2.5"), but i think i will need more piping.
#44 Nigel
Nigel
    Member
  • Members
  • PipPipPipPipPip
  • 783 posts
  • LocationToronto, Ontario, Canada
Posted 20 January 2011 - 02:35 PM
Posted Image
"May the Forced Induction be with you"
http://www.motortopia.com/nigel/cars
www.ontariozcar.com
Avatar courtesy of J.P. Matte
#45 280zjoel
280zjoel
    Half Motor
  • Members
  • PipPipPipPip
  • 225 posts
  • LocationLoma Linda CA 92354
Posted 20 January 2011 - 07:57 PM
Top Mount intercooled, spools really fast B)
Posted Image
zcolor-1.jpg?t=1262151591
1975 280z RHD converted with SR20DET
#46 wigenOut-S30
wigenOut-S30
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPipPip
  • 1097 posts
  • LocationMobile AL
Posted 24 January 2011 - 01:45 PM
How does Air go through the intercooler with this setup? do you have a hole in the hood there?
1977 S30: L28 turbo/intercooled:385rwhp 390TQ:11.56@122
#47 280zjoel
280zjoel
    Half Motor
  • Members
  • PipPipPipPip
  • 225 posts
Posted 27 January 2011 - 12:50 PM
I had a hood with vents cut into it, but now im going to use the datsun competition hood scoop and cut vents under it for the air to flow through.
Posted Image
#48 Cannonball89
Cannonball89
    Member
  • Members
  • PipPipPipPip
  • 210 posts
  • LocationMaryland
Posted 16 February 2011 - 12:48 PM
I just mocked up my intercooler piping today. I got the aluminum pipe and couplers from http://www.siliconeintakes.com/ ;) I have a cheap ebay T3/T04E and the piping is 2" off the turbo then necks up to 2.5" at the intercooler then into the throttle body. I just need to order a 2.75" to 2.5" adapter now for the throttle body because I didn't realize my 240sx throttle body is a little bigger than 2.5" I need to order some 3" stuff for the intake into the turbo too and a nice K&N filter, then once the fuel lines and surge tank are mounted, the megasquirt wired up, and the exhaust and wastegate welded up this baby will be on the road again! (Oh yea and a custom driveshaft)
This shiny new motor is going to make my old faded paint look even worse!
I got this trick BOV coupler from silicone intakes too. Pointing down is the only way I could get the Type RFL BOV to fit. This saved me from having to buy the equipment to weld aluminum or pay someone to do it.
It's gonna be pretty tight between the fan and the motor. I think there is enough clearance though. Once I tighten the clamps I can get about 1/4" clearance on each side of the pipe. I might rigidly mount this pipe to the motor if there is any problem with it hitting the fan.
Edited by RB26powered74zcar, 09 June 2012 - 06:40 PM.
Images way to large. Please resize before posting.
1971 240z
L28ET with Megasquirt 3, T3/T04E turbo, Intercooler, 440cc Injectors, T5 transmission, 3" exhaust, 38MM Wastegate.
#49 itzgoten
itzgoten
    Junior Member
  • Members
  • PipPipPipPip
  • 234 posts
  • LocationSan Jose, CA
Posted 16 February 2011 - 01:01 PM
My old setup..
Posted Image
My current setup
Posted Image
Posted Image
72 240z - SR22DET Powered - Pictures Here! Read my build here - HybridZ
391rwhp 307wtq (pump gas)
fb.com/sr240z
IG: sr240z
#50 mario_82_ZXT
mario_82_ZXT
    Member
  • Members
  • 1426 posts
  • LocationT-Town AZ
Posted 16 February 2011 - 09:36 PM
Cannonball89, it looks nice but why run the cold pipe behind the radiator?
It works better if you have the drivers side be the cold pipe so that it is only an S bend to the throttle body.
78 280z | Back to L28ET in progress
77 280z | $200 parts car turned daily driver
76 280zT | Dad's car (L28ET, MSnS-E, Big IC, 14psi) DAILY DRIVER
#51 Oddmanout84
Oddmanout84
    Blank
  • Members
  • PipPipPipPipPip
  • 663 posts
  • LocationMy Garage, Massachusetts
Posted 16 February 2011 - 09:43 PM
How is that setup wrong? Its exactly as you describe it should be. The cold side is going directly to the throttle body.
#52 Cannonball89
Cannonball89
    Member
  • Members
  • PipPipPipPip
  • 210 posts
  • LocationMaryland
Posted 17 February 2011 - 08:36 AM
Yea, cold pipe is definitely not running behind the radiator lol.
1971 240z
#53 mario_82_ZXT
mario_82_ZXT
    Member
  • Members
  • 1426 posts
  • LocationT-Town AZ
Posted 17 February 2011 - 09:02 PM
Lol I was tired when I posted that... =p
#54 Cannonball89
Cannonball89
    Member
  • Members
  • PipPipPipPip
  • 210 posts
  • LocationMaryland
Posted 17 February 2011 - 11:07 PM
It's all good Mario, we all have our moments. Looking back at some of my early posts on Zcar.com I wonder what the hell I was thinking... Then realize I wasnt't lol, I was either too drunk or tired.
1971 240z
#55 Kali
Kali
    Always Here
  • Members
  • PipPipPipPip
  • 147 posts
  • LocationZama-shi, Kanagawa, Japan
Posted 10 April 2011 - 01:41 AM
SRT-4 intercooler
ebay piping
#56 Nhuwar
Nhuwar
    Moving Up
  • Members
  • PipPip
  • 42 posts
  • LocationHouston
Posted 21 December 2011 - 07:22 AM
Is anyone running water to air intercooler here. I was thinking about running one and using my old condensor core from the ac to cool the water. Piping should be a snap too.
And for Sh#*s and giggles throw a few peltier junction cooler in between the tank and intercooler.
Any thoughts?
Nick
Edited by Nhuwar, 21 December 2011 - 08:06 AM.
#57 texis30O
texis30O
    Member
  • Donating Members
  • 1272 posts
  • LocationTexas
Posted 10 January 2012 - 06:54 PM
What manufacturers are people using.........
How come no one is going in and out the same side? Rather than going across the front of the motor and fhe radiator.
1970 240 Z #806, LS2 with a Maggie, t56, Fritz 8.8 swap, Coilovers, Cage, Flares, Wilwood.....
IG: sean70240z
'13 Tundra, CrewMax, .....I have issues...
"Driving this car on the street is like kissing a porn star on the cheek." -RebekahsZ
#58 Nelsonian
Nelsonian
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 719 posts
  • LocationSan Diego, CA
Posted 10 January 2012 - 08:19 PM
Revisit page 1, post #6.... Treadstone single sided inlet/outlet....
Nelsonian, San Diego, CA.
#59 Fuzzydicerule
Fuzzydicerule
    Junior Member
  • Members
  • PipPipPipPip
  • 310 posts
  • LocationSan Diego, Ca
Posted 15 January 2012 - 01:15 AM
Posted Image
Posted Image
Posted Image
Posted Image
Mine is composed of 2.5 inch Oreillys/pep boys exhaust tubing, a Tial 50mm BOV, and an Isuzu intercooler. Runs in between the steering shaft and the frame rail, under the motor, around the oil filter, up between the filter and the starter, through the Firewall into the V mounted IC, out past the IAT sensor, the BOV and into the TB
1972 Datsun 240z: Patina Lime green. 1jz Vvt/ w58
#60 PR280z
PR280z
    Member
  • Members
  • PipPipPipPipPip
  • 514 posts
  • LocationSan Sebastian, Puerto Rico.
Posted 18 January 2012 - 06:45 AM
Re-post of my setup.
Posted Image Posted Image
Z E T T O - B A S T A R D
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
