L28ET Cam Swap
#41
Posted 28 January 2011 - 06:55 AM
#42
Posted 01 February 2011 - 02:44 PM
#43
Posted 21 February 2011 - 09:34 PM
Thanks,
Dave
#44
Posted 22 February 2011 - 04:01 PM
#45
Posted 23 February 2011 - 06:50 AM
get your engine installed and running with IC and 12 psi
drive it for awhile
then worry about the cam, as you have bigger fish to fry!
#46
Posted 11 April 2011 - 06:53 AM
Edited by cygnusx1, 11 April 2011 - 09:33 AM.
#47
Posted 11 April 2011 - 06:58 AM
I would like to know this, i've been thinking about a L28ET for my 240zOh, you mean like 'which cam is BEST for an L28ET engine'?
Datsun 1200 sold
Datsun 510 still waiting
#48
Posted 11 April 2011 - 08:17 AM
#49
Posted 11 April 2011 - 09:31 AM
I have the P90A head so without modification I cant use the cam. Let me know how converting your head to be able to use the cam works. I might want to do the same
Converting the head to solid is fairly easy with thread adapters for the solid rocker posts. Then just install the new cam, and check the wipe pattern. My P90A head happens to be factory solid. I didn't convert this one.
I always reference this chart for cam info. The early A is not drilled for oil, I am not sure about the later A cams.
http://www.atlanticz.ca/zclub/techtips/cam/index.htm
Edited by cygnusx1, 11 April 2011 - 09:34 AM.
#50
Posted 12 April 2011 - 12:06 AM
The fourth P90A I have is in a relatively unmolested 83 ZXT 2+2, and it's got the hydraulics in it. Externally it's identical to two of the ones I have in storage, and the other one simply doesn't have the oil cooler on it.
#51
Posted 13 April 2011 - 08:35 AM
#52
Posted 13 April 2011 - 04:26 PM
Is there an advantage to this rather than going with a non-hydraulic lifter head?
This tompic has peaked my interest, but I have a p90a Hydraulic head.
#53
Posted 13 April 2011 - 11:10 PM
Mines an 83 so its hydraulic
OMFG...
TWO of the THREE I got in the shed came from 83's. The year, the casting... MEANS NOTHING--you can say you have Hydraulic when you have LOOKED and CONFIRMED it.
How hard is this?
#55
Posted 07 May 2011 - 05:21 PM
or advantages? perhaps cost?Converting a P90A-H to a P90A-S has no disadvantages over a P90, that I can think of.
#56
Posted 08 May 2011 - 10:15 AM
Cam availability.or advantages? perhaps cost?
77 280z | $200 parts car turned daily driver
76 280zT | Dad's car (L28ET, MSnS-E, Big IC, 14psi) DAILY DRIVER
#57
Posted 08 May 2011 - 02:52 PM
I don't know if they varied the coolant chamber design between the two heads.
Edited by cygnusx1, 08 May 2011 - 02:53 PM.
#58
Posted 23 May 2011 - 10:37 AM
Is there a site that lists out which cams can do what L28ET?
#59
Posted 29 November 2011 - 09:40 AM
I pulled an E31 head from a scrapyard engine, and the cam looks good. There is some bearing surface wear, but I'm hoping that doesn't create an immediate issue -- the lobes on the factory cam all look good. So I am going to swap the towers, spray bar, rockers and the "A" cam to my P90.
I am installing an E31 "A" Cam, rockers, and matching external oil towers with spray bar into my L28ET/P90A solid "lifter" (rocker post) engine. The full engine rebuild will start today and proceed for the next couple of weeks. Based on the info here, I should have a nice gain in top end with some possible mid range torque gains. Will report my butt dyno results, of course. Any word from the OP and the "C" cam?
I've done quite a bit of searching and reading up on these cam swaps, but I still have a couple questions, and of course any comments on this swap are welcome.
The lash pads are of course worn, and I have kept them with the associated (and numbered) rocker arm. Assuming the wipe pattern is centered on the rocker arm, is it ok to reuse the lash pad or do I need a new one? If I can re-use the lash pad, does it matter if it is installed 180 degrees around (I didn't document orientation)? I suppose I can mark the lash pad surface like the rocker surface and ensure the pattern stays within the wear area...
Tell me if this is false economy. I am just trying to get a valve train up and running with a new fuel computer, and then I intend to re-do the valve train properly, perhaps with another set of externally oiled cam towers once I have a reasonable tune. I don't want to worry about a cam break-in without a reliable tune.
And I am also interested in feedback from the OP on any aspect of this swap, or anyone else regarding used cam swaps and/or results of the 240 cam in a turbo engine.
'05 Jeep Liberty CRD, B100
'01 VW Beetle TDI, B100
#60
Posted 05 December 2011 - 12:08 PM
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
