    33196
    5167
    hammermfg
    hammermfg
  1. Today
  2. 11-08-2025. VERY busy day. running around trying to finish all the little things keeping me from being able to drop the 4.2 into the Z. Then I dropped it in. Feels great to have gotten it done, at least this far. I also was able to do some old paint removal.....the paint on this car is SO THICK.........anyway, pics.
  3. You don't need to change anything internally. Typically you would add some top ring gap on a turbo motor, but these motors already have plenty. My build is probably the cheapest high tech option possible, and I am very happy with the turbo's response and power. Back in the day it would be simply swapping some junkyard turbo model parts, but these days they are rare and not worth it. There are many ways to go about it, main factor is budget.
  4. Yesterday
  5. Did you see the turbo threads here? Kind of hard to find. https://forums.hybridz.org/forum/90-l-series/
  6. Nice. The strut brace may not be really necessary; it sounds like you'll be making the upper rad core support stronger than original. 👍👍
  7. Some of my stuff at Ortiz Aluminum Polish Specialist. Still in the process of being finished:
  8. THANKS! Well, that is my intent. as it is hollow, I will fit a spacer inside for the grade 8 bolt to go through on both sides, so 4 total. I may have to get inventive as far as a strut tower brace, the 4200 doesn't leave room for that!I I am planning on making a thick aluminum plate that goes across the top of the entire radiator support and have it polished for looks.
  9. Last week
  10. Hey everyone, I’m working on converting my 1976 L28E into an L28ET and could use some guidance from those who’ve done it before. The engine is already torn down, and my goal is to build it back up as a turbo motor from the ground up. I’m planning to run around 8psi of boost—nothing crazy, just a solid street setup. I’ve searched through the forums and found bits and pieces, but I’m hoping someone can help me with a more complete list of what I’ll need. Specifically: What internal components should I upgrade or swap (e.g., pistons, head gasket, oil pump)? Which turbo setup works best for this kind of build? What ECU or fuel management options are reliable and relatively straightforward? Any tips on sourcing parts—junkyard compatibility, aftermarket suppliers, or trusted vendors? I’m not looking to cut corners, but I also want to be smart and cost efficient about sourcing parts. If you’ve done this swap or have solid info, I’d really appreciate your input. Thanks in advance!
  11. That's one clean-looking shell....she's coming along nicely!! 👍👍 Have you made the upper portion of the radiator core support bolt-in? Done that with my last couple cars and it makes engine pulls sooooo much easier! As long as you have a decent front strut tower brace; there's very little stress on that section of the shell, IME.
  12. Today I cleaned up the motor mounts and alternator bracket and gave them a coat of paint. I also drilled out the holes in the motor mount pads on the crossmember and painted the visible spots. Lastly the wheels came in....16x8 in the front, 16X9 -15 in the rear. Tires are 205/55R16 and 225/50R16. have to slot a couple holes ont he alternator bracket still and a couple holes on the motor mounts needs some time with a burr bit but almost ready to drop the engine into the Z.
  13. The Datsun EFI system might look complicated but once you understand how it works it’s dead simple. Start with the basics and preform all the electrical measurements at the ECU plug. Don’t worry if the measurements are a bit out of spec and try and leave the AFM (Air Flow Meter) alone till you’re out of options. I suspect your issue might come down to something as simple as a bad connection or a broken wire. Try to look for damage to the wiring harness in the engine bay. Even though you replaced the fuel pump measure the fuel pressure just after the filter. The pump might be fine but it could still be that you aren’t building pressure. There is a fuel pump cut off switch inside the AFM to shut off the fuel supply if the engine stops running.
  14. The computer grounds the injectors every third spark. It uses the wire to pin 1 to monitor the ignition system. There's a pretty simple electrical system check in the 1980 EFI book. Check the circuits before getting crazy with parts. That's why they wrote the books. https://www.classiczcars.com/files/file/32-efi-book-1980/
  15. 11-04-2025. I did a little bit of spot putty work this morning, have a few spots a couple thick coats of filler primer then went ahead and painted the engine compartment and cleared it. Yep, the work isn't very good.......I did what I could. PICS.
  16. 11-03-2025- VIN verification day. Trailered it to the dealer to get the VIN verification done. You can see some of the work that has been done, as far as rust repair.
  17. Howdy! Recently picked up a 1977 280z, cars getting spark & fuel to the rail but it seems that the injectors arent firing. I’ve pulled them & cranked the car, they will fire at the very last second when turning the ignition off. Brand new fuel pump, & have changed the fuel injection relay out Any ideas? Not sure what to try next
  18. Unfortunately I live in the Netherlands so I will probably never be able to attend SEMA and there aren’t a lot of S30 Z’s running around here let alone modified with Apex Engineered hardware. I do plan to change that over time as the suspension kits look really good not to mention the perfect timing of new Retro Mod line which retains the original differential setup. The wife isn’t happy with me spending money on the car but I really want my 280z back on the road this spring. I’ll wait till black Friday to see if there are any good deals and then contact for an order for at least the frame rails and rear suspension.
  19. Need a set of 77 78 seat rails
  20. Hello, we will not be there but there will be 2 (that we know of) Zs running our full line up at SEMA, A green 2+2 and a wrapped 240z! Feel free to check them out, ask questions and let us know if you have any questions
  21. Got the title transferred. all legit now
  22. This is the only picture that I could find of the car with the 16x8 wheels and stock bodywork:
  23. I'm currently running 15x10 wheels with a 5.25" backspace on all four corners. I use 23.0x10.5-15 Avon Slicks or Hoosier 275/35-15 tires on all four corners. I run a 1/4" spacer on the front and it just barely clears my coilovers. No spacer on rear, and I have at least a 1/2 clearance to the strut. I have a modified version of the SubtleZ body on my car which provides an extra 1.5 of clearance at all four corners. Below are some pictures with the 15x10s and SubtleZ kit.
  24. thanks. God willing I will continue to. I got very lucky, buying a car looked over due to the rough paint, but clean....rails, doors everything clean no rust. 2 spots int he floors and a couple other spots, that's it. Still love my 240Z best, but this is a nice home for my ATLAS engine.
  25. Ditto what @74_5.0L_Z said....same experience for me, but in a 4" backspace vs 5" (i.e. 0et). The 245/45-16 fit front and rear with my standard-size ZG flares, which I believe are similar to your setup? What tires/treadwear rating are you thinking of running? I've actually found a *slightly* better selection of tires in 15", especially at the performance end of the spectrum; but then you start running into interference issues with brake and steering/suspension components.
  26. When I was running the stock bodywork I used to run 16x8 with a 5" backspace. I could fit 245/45-16 under the rear and 225/45-16 under the front without rubbing. Availability of 16 inch is an issue these days. Research tire availability before committing to running 16" wheels.
  27. I don’t know if they attend or what can be found at SEMA but I’m interested If Apex Engineered will be there. I just saw that they dropped a new line of suspension upgrades this weekend called the Retro Mod line of suspension. The Retro line allows you to keep the stock R180 or R200 diff and looks a lot like there I guess existing suspension (non track attack) line that seems to be renamed to the Pro Touring line.
  28. SEMA SHOW 2025-LAS VEGAS NOV. 3-7 I know that many HybridZ forum members are unable to attend this show so I will try to look for any product at this show for you. Please list your request as detailed as possible( manufacturer name and description of the item). I will, of course, look for items related to Z cars but there are thousands of vendors and it is easy to miss items. Toolman
  • Who's Online   0 Members, 0 Anonymous, 536 Guests (See full list)
