- Past hour
Hey everyone, I'm in the middle of rebuilding the L28 in my '81 280zx 2+2 and I've hit a brick wall. I'm trying to get the oil pan and the lower engine block/upper pan (the big cast aluminum piece) off, and it will not budge. I'm 100% sure I've removed all the bolts I can see, but it's sealed on there like it's welded. Here's what I've tried so far: Engine Oil Pan Separator Tool: Did a bit but not a lot. Razor Blade: I'm trying to work a razor in, but it's taking forever and barely making progress. I'm worried I'll be here for days. WD-40 : Thought that i could break up the seal/glue with it and... nothing Tap the side of the pan with a mallet to shock the seal; nothing I'm getting frustrated and don't want to start prying and gouge the mating surfaces. Am I missing something obvious? Are there hidden boltsthat I'm not seeing? What's the magic trick to breaking the seal on this RTV from hell? Any tips, tricks, or tools you've used for this specific job would be a huge help. Thanks!
- Yesterday
I'm sure that you've considered it and I don't know what you would do to cure it if it is a problem but those engine mounts are very long lever arms. What happens if you grab the top of the engine and pull it side to side? Probably best to test it now than to wait. Even the mass of the engine in a turn will place a lot of force on them. Just something that grabs the eye from the pictures. Unusual engine mounting. Edit - fore and aft also. Much lifting force on the rear mount under braking. Fatiguing of the front crossmember engine mounting points might be a problem. It wasn't designed for that type of twisting force. And you've moved the elastic portion up to the engine at the top of the lever arm. The attachment to the crossmember is all metal. Hate to be a Debby Downer but you have access now to work on it, rather than later.
11-08-2025. VERY busy day. running around trying to finish all the little things keeping me from being able to drop the 4.2 into the Z. Then I dropped it in. Feels great to have gotten it done, at least this far. I also was able to do some old paint removal.....the paint on this car is SO THICK.........anyway, pics.
You don't need to change anything internally. Typically you would add some top ring gap on a turbo motor, but these motors already have plenty. My build is probably the cheapest high tech option possible, and I am very happy with the turbo's response and power. Back in the day it would be simply swapping some junkyard turbo model parts, but these days they are rare and not worth it. There are many ways to go about it, main factor is budget.
- Last week
Did you see the turbo threads here? Kind of hard to find. https://forums.hybridz.org/forum/90-l-series/
Nice. The strut brace may not be really necessary; it sounds like you'll be making the upper rad core support stronger than original. 👍👍
THANKS! Well, that is my intent. as it is hollow, I will fit a spacer inside for the grade 8 bolt to go through on both sides, so 4 total. I may have to get inventive as far as a strut tower brace, the 4200 doesn't leave room for that!I I am planning on making a thick aluminum plate that goes across the top of the entire radiator support and have it polished for looks.
hammermfg joined the community
76_280Z joined the community
Hey everyone, I’m working on converting my 1976 L28E into an L28ET and could use some guidance from those who’ve done it before. The engine is already torn down, and my goal is to build it back up as a turbo motor from the ground up. I’m planning to run around 8psi of boost—nothing crazy, just a solid street setup. I’ve searched through the forums and found bits and pieces, but I’m hoping someone can help me with a more complete list of what I’ll need. Specifically: What internal components should I upgrade or swap (e.g., pistons, head gasket, oil pump)? Which turbo setup works best for this kind of build? What ECU or fuel management options are reliable and relatively straightforward? Any tips on sourcing parts—junkyard compatibility, aftermarket suppliers, or trusted vendors? I’m not looking to cut corners, but I also want to be smart and cost efficient about sourcing parts. If you’ve done this swap or have solid info, I’d really appreciate your input. Thanks in advance!
That's one clean-looking shell....she's coming along nicely!! 👍👍 Have you made the upper portion of the radiator core support bolt-in? Done that with my last couple cars and it makes engine pulls sooooo much easier! As long as you have a decent front strut tower brace; there's very little stress on that section of the shell, IME.
Today I cleaned up the motor mounts and alternator bracket and gave them a coat of paint. I also drilled out the holes in the motor mount pads on the crossmember and painted the visible spots. Lastly the wheels came in....16x8 in the front, 16X9 -15 in the rear. Tires are 205/55R16 and 225/50R16. have to slot a couple holes ont he alternator bracket still and a couple holes on the motor mounts needs some time with a burr bit but almost ready to drop the engine into the Z.
flatout joined the community
77 280z Injectors not getting power
Mitchel0407 replied to Acesss's topic in Trouble Shooting / General Engine
The Datsun EFI system might look complicated but once you understand how it works it’s dead simple. Start with the basics and preform all the electrical measurements at the ECU plug. Don’t worry if the measurements are a bit out of spec and try and leave the AFM (Air Flow Meter) alone till you’re out of options. I suspect your issue might come down to something as simple as a bad connection or a broken wire. Try to look for damage to the wiring harness in the engine bay. Even though you replaced the fuel pump measure the fuel pressure just after the filter. The pump might be fine but it could still be that you aren’t building pressure. There is a fuel pump cut off switch inside the AFM to shut off the fuel supply if the engine stops running. -
NewZed replied to Acesss's topic in Trouble Shooting / General Engine
The computer grounds the injectors every third spark. It uses the wire to pin 1 to monitor the ignition system. There's a pretty simple electrical system check in the 1980 EFI book. Check the circuits before getting crazy with parts. That's why they wrote the books. https://www.classiczcars.com/files/file/32-efi-book-1980/ -
11-04-2025. I did a little bit of spot putty work this morning, have a few spots a couple thick coats of filler primer then went ahead and painted the engine compartment and cleared it. Yep, the work isn't very good.......I did what I could. PICS.
11-03-2025- VIN verification day. Trailered it to the dealer to get the VIN verification done. You can see some of the work that has been done, as far as rust repair.
Howdy! Recently picked up a 1977 280z, cars getting spark & fuel to the rail but it seems that the injectors arent firing. I’ve pulled them & cranked the car, they will fire at the very last second when turning the ignition off. Brand new fuel pump, & have changed the fuel injection relay out Any ideas? Not sure what to try next
Mitchel0407 replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
Unfortunately I live in the Netherlands so I will probably never be able to attend SEMA and there aren’t a lot of S30 Z’s running around here let alone modified with Apex Engineered hardware. I do plan to change that over time as the suspension kits look really good not to mention the perfect timing of new Retro Mod line which retains the original differential setup. The wife isn’t happy with me spending money on the car but I really want my 280z back on the road this spring. I’ll wait till black Friday to see if there are any good deals and then contact for an order for at least the frame rails and rear suspension. -
Apex Engineered replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
Hello, we will not be there but there will be 2 (that we know of) Zs running our full line up at SEMA, A green 2+2 and a wrapped 240z! Feel free to check them out, ask questions and let us know if you have any questions -
Got the title transferred. all legit now
This is the only picture that I could find of the car with the 16x8 wheels and stock bodywork:
I'm currently running 15x10 wheels with a 5.25" backspace on all four corners. I use 23.0x10.5-15 Avon Slicks or Hoosier 275/35-15 tires on all four corners. I run a 1/4" spacer on the front and it just barely clears my coilovers. No spacer on rear, and I have at least a 1/2 clearance to the strut. I have a modified version of the SubtleZ body on my car which provides an extra 1.5 of clearance at all four corners. Below are some pictures with the 15x10s and SubtleZ kit.
thanks. God willing I will continue to. I got very lucky, buying a car looked over due to the rough paint, but clean....rails, doors everything clean no rust. 2 spots int he floors and a couple other spots, that's it. Still love my 240Z best, but this is a nice home for my ATLAS engine.
Ditto what @74_5.0L_Z said....same experience for me, but in a 4" backspace vs 5" (i.e. 0et). The 245/45-16 fit front and rear with my standard-size ZG flares, which I believe are similar to your setup? What tires/treadwear rating are you thinking of running? I've actually found a *slightly* better selection of tires in 15", especially at the performance end of the spectrum; but then you start running into interference issues with brake and steering/suspension components.
CrazyThinker63 joined the community
When I was running the stock bodywork I used to run 16x8 with a 5" backspace. I could fit 245/45-16 under the rear and 225/45-16 under the front without rubbing. Availability of 16 inch is an issue these days. Research tire availability before committing to running 16" wheels.
Who's Online 2 Members, 0 Anonymous, 720 Guests (See full list)
