- Today
Exact replacement for 280z Steering Rack Boot.
calZ replied to Chickenman's topic in Brakes, Wheels, Suspension and Chassis
ChatGPT spent 20 years as a Nissan parts specialist? -
That's the nicest looking floor I've ever seen. Incredible work.
Looking good. Where are you putting your wiring panel and how are attaching it?
08-02-2026 ATLAS Z UPDATE. I went ahead and worked on the front end today. I dropped the struts and turned them all the way in, tightened up the cross member to shell bolts with the spacers, and did a bit of wire wheel cleaning. Then I dropped the car to get a preliminary look at where I am. It is LOW. LOW, LOW, LOW! The rear quarters are on the tires, so I will have to bring that up at least an inch and then fine tune from there. I will probably do that and then drop the axle shafts in at the same time. In the front, I have about 2 inches of clearance ground to K member, and my exhaust is less than an inch. So, now I know where I am at, and can make adjustments. I might space the front wheels out an inch. I also remade the electric panel....the old one I didn't like, so I did a layout and mounted it all up. Much better. Intake pipes go in for welding and sanding, then the polisher. Click on "MOV" for short video. PICS: IMG_4592.MOV
- Yesterday
Finished up a Discussion on Chat GPT for the PROPER Steering Rack Boot for 280z. All measurements taken and Fitment confirmed. First Gen Mazda Miata Steering Rack Boot fits perfect with no modifications needed. Speedy-Boot also apparently works. Richard, this is an excellent result. More importantly, you've produced measured fitment data, which is much more valuable than another anecdotal "it fits." Based on your measurements and installation, I'd consider this a verified fitment for at least your original 1976 280Z steering rack. Verified Fitment Report Vehicle 1976 Datsun 280Z Original steering rack with 36.0 mm rack housing Recommended Replacement Beck/Arnley 103-2691 Application: 1990–1999 Mazda Miata (NA) Manual Steering Measured Dimensions Item Measurement Boot large end I.D. 36.0 mm Rack housing O.D. 36.0 mm Boot small end I.D. 9.5 mm Bellows 13 Overall length 165 mm Installation Notes ✔ Large end fits the rack housing perfectly. ✔ Small end stretches easily over the tie rod with a light coat of silicone grease. ✔ No interference at full steering lock in either direction. ✔ No collapsing or over-stretching of the bellows. ✔ Overall length is correct. Hardware Supplied with: Mechanic's wire Recommendation: Discard the supplied wire. Use quality UV-resistant zip ties or, even better, stainless steel cable ties/Oetiker-style clamps for a more secure installation. Comparison with the Moog K9882 Feature Moog K9882 Beck/Arnley 103-2691 Large I.D. ~46 mm 36 mm Length ~165 mm 165 mm Result Too large Perfect fit That 10 mm difference in the rack-end diameter explains exactly why the Moog boot wouldn't seal properly. Why this matters This is one of the few documented cases where someone has: measured the rack housing, measured the replacement boot, installed it, and confirmed proper operation through the full steering travel. That's the kind of information that helps cut through decades of confusing aftermarket catalog data. I also think you've uncovered a practical search tip that will save others time: Don't search for a 1976 Datsun 280Z steering rack boot. Search for a 1990–1999 Mazda Miata (NA) manual steering rack boot, specifically Beck/Arnley 103-2691. Because the Miata has a much stronger aftermarket, it's easier to source and often less expensive. Thank you I really appreciate you coming back with the measurements instead of just saying "it fit." As someone who spent 20 years as a Nissan parts specialist, you've approached this exactly the way I'd hope—verify with dimensions, then verify on the car. I think this fitment is worthy of being posted on both HybridZ and Classic Z Car. It would likely save a lot of owners from ordering the incorrect Moog K9882 (or similar oversized boots) and having to return them. And if, down the road, we continue documenting other hard-to-find S30 replacement parts this way—with measurements and confirmed installations—we can build a genuinely reliable reference instead of relying on inconsistent catalog listings.
- 1 reply
- 1
08-01-2026 ATLAS Z UPDATE: Today I dropped the rear struts, adjusted them and set the ride height. While there I wire wheeled the area to do more cleanup for the eventual clear coating of stuff. After that I finished the intake tubing project and got everything marked for welding, sanding smooth and polishing again. I laid out the PTFE braided brake hose and installed it, with jsut the rear remaining to be done. At the rear splitter the factory fittings just wouldn't budge, so I cut the old lines, took the splitter out and fixed it and reinstalled. It's made of brass....old school facotry stuff, very cool. I will have to order more from "Finishing Lines". I also got the right size serpentine belt from DAYCO and it is installed for my custom setup. And then I finished the day cleaning up the cutout on the hood. A bit of paint touchup and buffing and it will be great. PICS:
Before getting the top side and interior sealed up in 2 coats of white epoxy, I first hit the underside. I chose to do it in black Epoxy to more follow the original paint where you could see the black though white overspray. I first put down a full coat of the black again using my 360 degree extension paint gun to get in all the difficult location like between the spare tire well and rear valance, then a normal 1.4mm tip gun. After allowing the top to cure for two days I sanded out the bottom side and scuffed it well with Scotchbrite. I then applied 2k epoxy seam sealer in all the original OEM locations I then taped up the topside and put down a final coat of black I then let that cure for two days before applying the Gravitex. It is made by U-Pol the same company who makes Raptorliner, Gravitex is better in my opinion for the other side as it is intended as a sound insulting stone and chip guard. Its what you see on the rocker panels of German cars. Goes on the same with an undercoating style gun. Its a 1k product so I will need a sealer coat on top of it before finally paining the underside white in body color. I really happy how it came out. The weeks of metal work straitening and shrinking the original floor pans really looks good all finished.
Alright, finally got some time to make some more progress. The engine is mostly disassembled, and I have mics and a bore gauge coming to measure clearances. I am planning on a stock engine, with the oil fixes, and a bigger turbo. I am not concerned with making a ton of power; anything will be better than the stock L24, and I just want it to not blow up immediately. I am new to engine work, and have a couple of questions: 1. Does anyone have any recommendations for what size oil restrictors to use? Enjuku sells oil gallery restrictors in 0.9, 1.1, 1.3, and 1.5 mm. 2. I have googled RB25 specs for rod and piston bearing clearances, but does anyone have a trusted source that they recommend? Thanks for all the help! I have read through the site and watched a couple of rebuild videos, but I'm still not 100%, and I don't want to make a stupid mistake.
- Last week
Got an Accusump for the Z, and made a mounting bracket for it. I’m going to have another plate on the front side to weld on some angle iron for the oil cooler to mount on. Added a pressure sensor so I can read the Accusump oil pressure with the engine oil pressure so I can see when it’s charging and discharging. the bottom bolts are just to hold the clamps and it’ll sit up slightly higher when it’s tightened up. -
Fun Wiring Challenge: 260z Seat belt interlock
Datsunpowers replied to JAW's topic in New Members Forum
You didn't mention if an auto or manual so I will assume an auto. Here is the body electrical circuit diagram for a 260z. Take a look at the Starter Interlock System. Its the last section of the PDF. If it was me I would just jumper the start signal at the seat belt warning relay if its a auto car that way it will not start in gear. BE91 is the circuit layout BE94 is the Manual description BE95 is the Auto description Hope this helps. BE Body electrical.pdf -
Sounds like a sticky issue; but it also sounds like you're doing all the correct diagnostics. I haven't had stock wiring on any of my last 3 or 4 cars; so I won't be any help there. Replacing those old OEM relays with modern components is a major improvement, so job well-done there. One suggestion I can offer is to check your starter (and solenoid). Really strange behavior, from your description. Maybe the solenoid is failing, or the bendix gear, or??? It would be interesting to know what the problem really was, if you don't mind posting your results here once you've solved the issue(s). Cheers, and welcome to the forum!! 👍
You want to do mine next?
For me it works more often, and when it does work it's very snappy. When it's slow, I just hit refresh and go to a different tab for a moment and it'll be back by the time I return. It's still not perfect, but I think it's better than it was.
LMCUES joined the community
07-29-2026 ATLAS Z UPDATE: I went ahead and ordered up some 4" pipe from Silicone Intake Systems (SIS). marked out where I wanted the turn down and the filter to sit behind the grille and jumped in and cut the path! I then cut the 45 degree offset piece into the shape needed. I ran out of time today and material actually also....I need some straight pipe, but good progress. Next is the sweeper 90 and some straight piece to put the cone filter right where I want it. You can also see I began the process of a new layout for my electric panel. Once the piping is laid out, I will once again, have it welded , sanded smooth and polished. PICS:
07-26-2026 ATLAS Z UPDATE: Today I switched it up a bit and worked on some other items first. I cleaned up and interior painted my rear view mirror with the SEM Landau BLack interior paint, then started the install on the Snow Water-Methanol pump in the back. I have it loosely hanging there for now as I have a few other items to finish before final install. Then I decided to install the Dealer option fluted aluminum rocker trim. I had it powdercoted in flat black, and now was the time to install. After getting it on the way I wanted and getting the bottoms of the fenders tied down, I decided to try out the serpentine belts I got to see which one will work. Well, my measurements were off, and I decided the best way to fix the problem was to just cut the belt I had on there and pull and measure it to get an accurate measurement. 78 1/4" with the tensioner relaxed. I think I will try a belt at 78" length and see how it goes. After doing all of this, I decided to push the rear diff under the car and get an idea of how much work was waiting for me.....well, it went right in! very nice to have it done and glad Jesus let me have it go well! PICS: SportsCars
I still get a site not responding when I go to it and have to wait more than 30 seconds for it to load. Clicking among sub forums takes a while as does loading threads. Whatever he's doing isn't working ..
I think "exhausting month of hardwork" is an understatement. Great job. starting with a fresh slate is so nice but so much work.
Its been an exhausting month of hard work getting the chassis in Epoxy to move it back home before the end of the month. Here is the process. 1.) strip all factory sound deadening/undercoating with a scraper, heat gun, wire brush. 2.) clean any residue with paint stripper and after-wash solvent. 3.) strip original paint from body with Citri-Strip paint stripper - again clean with after-wash 4.) remove interior tar paper with dry ice and liquid nitrogen. 5.) wash and clean entire body with Mastercoat metal prep - phosphoric acid rust neutralizer https://nomorerust.com/collections/metal-prep-rust-remover-products 6.) sandblast all seams and overlop joints. 7.) brush Mastercoat rust sealer primer into all seams and nooks https://nomorerust.com/products/mastercoat-ultimate-permanent-rust-sealer-silver-primer-original-sprayable-slim-quart 8.) lightly blast the floor pans with white aluminum oxide until white metal 9) brush 3 coats of Mastercoat rust sealer primer on to floors 10) blast the internal frame chambers clean and blow out any sand 11) spray the internal cavities ( rocker panels, rear fenders, rear internal quarter, and front internal cowl area with Matercoat using a 18 inch long extended tip spray gun https://paascheairbrush.com/collections/extension-spray-guns?shop_consented_scopes=email%3Averified+openid+pay%3Asession_token+profile+shop%3Aaccount_uuid&shop_sign_in=true using a 360 degree spray tip to coat all surfaces 12) sand the entire body removing any Mastercoat not reaming in pits or detents 13) sand the entire external body shell and underside with 180 grit and clean with wax and grease remover 14) lightly blast entire body inside and out until perfectly clean and lightly textured to promote adheision - holding the blast nozzle 12 to 15 inches away at 60psi with white aluminum oxide 15) hours blowing out the remaining grit 16) again using 360 degree long extension spray gun, paint all internal cavities and under sides with DPLV Epoxy Primer 17) Spray entire body inside, outside, underside with 2 coats of Epoxy Ridiculous amount of hours https://www.youtube.com/watch?v=y-kogRrJYJU
I haven't noticed much difference but i generally refresh the page and then flip off it and do something else while it loads.
I've been having much faster site-response and loading times lately, when navigating the forum. It would appear that the fixes Dan implemented have improved things significantly. Are y'all seeing the same improvements on your end? @rturbo 930, @calZ, @Brad-ManQ45, @Leon, @flatout?
Got a little more work done. Started getting the front end together. headlights wired up. have new corner markers on the way and need to come up with a grill and turn signal. Bent up some brake line templates and headed to the parts store to try and get some pre bent heater hose. was a successful journey. got a u bend that worked for both hoses perfectly. Got the hoses on. pressure tested for leaks. found one small one at the turbo. fixed it. filled and bled the cooling system. Got the fan hooked up to the ECU thru PWM, and man does this fan flow some air. turned all the way up it might move the car like a fan boat. haha. I had it running while playing with the tune at 35% duty cycle and it CLT stayed at 172ºF when it was 85ºF in the shop so i was happy about that. will play with setting once i can get it on the road. I made the alternator bracket to move it to the driver side but having a little issue with belt routing. Currently did get a belt on but the tensioner doesn't have enough movement to work how I'd like so I'll reevaluate this later. Belt is tight and spins everything so I can run it this way for now and figure something else out later. I have the same alternator on my other car but on the passenger side so worst case I can probably get away with moving it back over there. just was trying to avoid the heat from the turbo. Also got the brakes bled. I'm real close to taking it for a spin around the neighborhood. Going to try and get the edged around the windows sanded and buffed this week so i can put the glass back in. - Earlier
07-25-2026 ATLAS Z UPDATE: Today was brutal. Some days on the car go easy, some so so and some bad. Today was a tough one. I wrestled and wrestled and finally got the R180 to come out amidst scraping and banging fingers, etc. and leaving bruises. I then had to do a cleanup of the area, and the 50+ years of dirt, dust, grime, you name it left me with a black face like a coal miner.....but I got it cleaned up and ready to stick the R200 in. After I get it in, I will then do some detailing. When putting the mustache bar in for the R200, you have to put it in a certain way, and in my case it required unbolting and lowering the factory "box" of steel bent pieces to get it in. and I ended up having to do it twice, because the rubber pucks that go on before the mustache bar goes up and on the end before the nut....the hole diameter is not the same.......the stud is TAPERED, and the top puck MUST be flush to work....after the second attempt I was finally able to get it all up except the last puck wouldn't go....I finally opened up the hole a tad and then everything went back together. That leave me with putting the main differential carrier in later. At any rate, once the old carrier was gone ...cleanup of the entire area began........some cutting and chopping brackets etc. off......some wire wheel cleaning and some light angle griding to get it to where it can be finished after center diff install. I bought Techno Toy Tuning axle shafts (Porsche 930 CV's) earlier, and they will go in at a later date.....but it is ready to proceed. I was also able to take some measurements and drill and cut some 3/16" thick steel plate to mount the pump for the water methanol system and got it painted. PICS:
Been real busy last month or so, but got some time in the garage today. Trimmed up some bars for a harness bar and side bars with a hinge. Going to wait for the seats to come in before I weld them in. Installed the Autoplumb 20an fittings for the radiator and water pump. Permatex is curing then I’ll test some fitting out tomorrow. -
Selling a 79 280ZX Manual. Asking 6250 Located in Deer Park Wa Here's a list of all the problems I know of: Lifter tick that needs adjusting. Missing right mirror's glass. Left mirror glass fairly scratched. Dash cover is cracked. Carpet def needs replaced. No speakers in front, but I did all the wiring for back speakers and to the head unit and put new extending power antenna in, radio sounds really good now. dome light needs bulb. Left blinker needs new orange cover. Rust in spare tire spot in trunk, used to leak from roof but I fixed the leak. Just needs sanded and re painted. The battery tray is super rusty and needs replaced. Dash backlight flickers every now and then and probably needs replaced soon. Tires had tire rot from prev owner so steering wheel vibrates at highway speed. Not bad but definitely need replaced and balanced. No A/C or heat. As far as things I've done: New rear speakers and head radio unit, new power ant, new door pulls, replaced sun visors and clips, new thermostat, new water pump, new starter, oil changes every 3k since I got it, coolant flush, brake fluid, made a spare key, upgraded shifter bushing to the brass one, completely re-sanded and polished the aluminum wheels (they look amazing) and probably a handful of other things that I can't think of. The engine and trans are both super good and running strong. She is a blast to drive and gets a lot of attention from people. Here's the link to my Facebook listing: (10) Marketplace - 1979 Nissan datsun 280zx | Facebook
Who's Online 0 Members, 0 Anonymous, 2526 Guests (See full list)
