The 165s are satisfactory. If the valves haven't been adjusted for a while, try that and check the compression again. If you're sure the valve adjustment is fine, squirt a tablespoon or so of oil into the cylinders and take the c. test again. If the numbers raise significantly the problem lies in the rings. If the numbers stay about the same the trouble is in the valves.
