To fit the struts I had to get creative. I already had camber plates welded and did not want to modify those. The BC setup is nice but not a large amount of camber adjustment.
Not much problem for the front. I only needed a 1mm thick bushing to fill the gap between the shaft and camber bearing. After I tried to drill something several times I ended up just 3d printing one.
The rear required some fabrication. I had slotted the towers and built my own camber plate/spring perches. To retify I duplicated the plate in aluminum and bolted the BC bearing holder from the bottom.
