Back to work on the Z Turbo car and taking a break on the NA car after finishing up the body work. Time to dry fit the rear suspension for the Turbo Car.
Designed and built my own control arms and rear support years and years ago, finally fitting it up. They are 4130 seamless Chromoly that I polished welded then clear powder coated.
Here are the rear control arms. I stuck with the standard urethane mounting bushing fror the inner front pivot location, but used really nice Teflon lined Aurora rod ends everywhere else.
I had some 6-4 titanium bar drops and plate, so I was feeling creative and made all the big control arm bolts from the titanium
Here it is all installed with the brakes and custom parking brake cable as well as custom CV axles, Diff mount and front mount
This is a custom front diff mount with a double hump for the duel exhaust that will fit in very nicely. The Diff is an R-200 with 3.70 gears and a Quaife Limited slip. Can remember where the diff cover was from, but I think it was a Nismo part.
I bent up my own sway bars from StressProof steel and made two point adjustment links for the end.
I machined some mounts with solid Teflon busings for the sway bars, similar tot he 280z placement, front mount style
The bar is sitting too low and will hit the duel exhaust pipes so I need to remake the mounts and raise the bar higher in the chassis.
Thats it for now, on to the front suspension and crossmenber next.
Let me know if any questions, clarifications or more pics.
Busy Summer.
