Leaderboard
Popular Content
Showing content with the highest reputation on 06/30/25 in all areas
  1. Got the front wildwood brakes installed today! A couple small quirks along the way on my install: First side I installed the rotor on the adapter ring to the hub wrong and the caliper didn't line up. It has two separate mating surfaces, one for a 240z and one for the later 280z hubs. Since I've replaced my 280z hubs with the T3 hubs, I failed to realize they're essentially a universal hub for early and late models which is why they had an extra shim ring of about 10mm to account for where the 280z mounting surface is. I took the ring off, so technically I had to install them where the 240z ones are, unless I wanted to run my rotor ring AND the hub spacer shim that they came with. Avoiding too many unnecessary pieces so I redid that side to mount on the 240z mating surface of the adapter and we were fine. Problem 2 - because I ordered the 280z brake kit, the included hardware also assumes you're still using stock 280z hubs. It's on and worked on my short drive, but I noticed in the picture where they're installed that the bolts don't go all the way out to the mating surface for the wheels. Quite a few threads left unengaged. It's probably safe for the time being, since I thought about the forces on those specific bolts and it's not really in or out since they're perpendicular to the rotational force applied by the brakes. I also didn't feel like I had particularly few threads engaged as I was bolting the rotor to the hub. Probably safe for casual driving, but it's a high priority fix right now to get the correct length bolts from T3 or locally. Better safe than sorry! Other than that I'm really happy. Bled the system with my new Motul brake fluid, which should cope much better with the heat off the turbo vs the cheap generic O'Reilly fluid I had before.
    1 point
  2. 06-28-2025. Putting the new turbo on. With the new turbo to manifold piece, I had to actually remove the intake manifold, put it all together, and then slide the manifold back on. It WORKED! Look at those HUGE ports! I haven't seen them in awhile! That's my Russ Racing prepped and shaved E31 head! I have it almost all assembled, I had to "slip" the top hose clamp up a bit to get a really good seal clamped down. Looks "different" but it is SNUG. I vacuum tested the new wastegate actuator......WAY too high (boost crack at 15 psi !!!) , so I put the older one on, and it boost cracks at only 2.5 psi.,....but I didn't port the turbine housing this time, so keeping that in mind, I think very little boost will be bleed off....enough to protect the engine, but it's going to pump quite a bit of air and fuel! (boost creep expected). The Skillard brake master cylinder heat shield I ordered came in, and is waiting me to custom mod as needed and install. Also went ahead and started clamping down the vacuum hoses to avoid any more hoses blowing off under boost. I have also added on a few pics of my intake ports if interested. Almost done! It is now HOT, have to keep stopping and wiping my face off. I think it was over 86! cheers! pics attached.
    1 point
