RJ280ZX
About RJ280ZX
  • Birthday 10/21/1979
Contact Methods
  • AIM
    RJ280ZX
  • MSN
    rj_davenport@hotmail.com
  • Website URL
    http://www.truckwerks.com
  • Yahoo
    RJ280ZX
  • Gender
    Male
  • Location
    Lake Dallas, TX
Recent Profile Visitors
5081 profile views
RJ280ZX's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
10
  1. Welcome, 200HP is easily obtainable on a stock setup, intake, exhaust and turn the boost up to 12psi. However, you will want to replace the stock ecu and wiring harness. These old cars are prone to poor electrical connections and the engine management is not great at all.
  2. Just remember, you can't really sand epoxy "primer" sealer.
  3. If you keep it stock, the N/A trans is fine, as soon as you turn up the boost and drive it hard, they won't last. I am on #3, but I don't drive it nice either.
  4. - oil cooler and lines, valance for oil cooler ( it has cut-outs in it), ignition coil mount (it's turned 90 degrees from non-turbo), boost sensor is mounted on the shock tower, boost gauge, oil-temp gauge, I think the 82 also has better rear calipers and master cylinder. Don't forget to get the exhaust elbow that bolts on to the down-pipe. If it's a manual trans, the turbo trans is slightly stronger than the N/A.
  5. Stock camshaft info here: https://www.atlanticz.ca/zclub/techtips/cam/index.htm
  6. Muriatic acid will eat the rust and leave you with bare metal, the full strength stuff works better but hard to come by. Be careful, if you leave it on too long, it will eat the metal. Here is an example of what the acid can do https://www.youtube.com/watch?v=Tfk2J0fXZzM full strength version of the acid https://www.youtube.com/watch?v=V2Q7I26cwkU Skyco ospho rust converter will "convert" the rust into something paintable. You apply it, let it sit 24 hrs then wash it off, then paint it. I just started doing this method this last year, so I can't offer you any lasting results, but I think it will work better than other methods I have used. Remember, you need to wash it off after you let it sit or the paint won't stick. I recommend using POR-15 to repaint it, they have an aerosol can that can be painted directly to the bare metal.
  7. Not final, but here is my progress installing the intercooler piping.
  8. Too bad you are not closer, I could do it for you. If you need some parts let me know, I usually get really good deals. Here are a couple shops near you, I haven't used them before, but they are active on TexasNissans.com Please Feel free to contact Ben and Dane via email at houstonzauto@gmail.com by Phone at 936 463 8966 or Visit their Facebook page www.facebook.com/houston.zauto Powerfab Auto: Cypress Creek Parkway #703 Houston, TX 77070 Phone: 281-477-0572 sales@powerfabauto.com www.powerfabauto.com
  9. Z32 or Q45 diff swap is what I recommend
  10. You might look into the Mercedes straight 5 cylinder engine. A lot of people are doing them in jeep swaps. I personally know of a guy that did the swap in his 94 Jeep Wrangler and is getting 30 mpg.
  11. 7" touchscreen monitor run by a mini-itx motherboard
  12. iPad can't run megasquirt or MSD software 7" Touchscreen in a 280ZX
  13. Been working on this for a few weeks Running Windows 7 64 bit 3.4GHz AMD quad core 8GB ram GPS, Webcam Controlls MSD 6-AL2 programmable and will control megasquirt as soon as i get it installed.
