az240z
Everything posted by az240z
  1. It was an early Rebello build 3.1 build..
  2. Good questions with no answers. Will look into it..
  3. I'm wondering which head would be best for my car. I have a 1973 240z that I bought last year, that was supposed to have an early Rebello engine. Unfortunately there is no documentation on it and Rebello doesn't keep records for early 1990 builds. 2 months ago the head went bad with a burnt valve. I replaced the E88 head with a P90a that had been rebuilt, just to drive the car, and took the E88 to a machine shop to get it rebuilt. I now have the head and realize that its a standard head with no porting, or polishing. The shop replaced the springs, did a 3 way valve job, lightly shaved the head to eliminate some very minor unevenness. The question is should I re install it or leave the p90 on? I have someone who may buy the car but wanted the E88 back on, assuming that it was a built head by Rebello. He now knows that that isn't the case. I have a n L28 block, rebuilt, with flat top pistons that the P90a was on. Are there any performance gains between the 2 heads assuming everything else are equal.. By the way when changing the heads, I didn't have a micrometer to measure the bore, so used a paper to get the bore size and than miked it at work. It measured at 89mm.
  4. Dang I have a passenger side door available..
  5. Are you looking for the column cover or the steering column itself..
  6. Tony I must say that that was one of your best response to a new poster.. You must be getting mellow in your old age....
  7. I can come up with a complete set of black interior. I think all 280z interiors are the same..
  8. I have some flat top carbs, don't know if they run, but you can have them for $25.00+ shipping.
  9. If RP260z isn't interested I might be. Pm price shipped to Glendale, Az 85308
  10. I have cracked 280z dash complete. I also have the metal frame from a 280zx dash, you might be able to make it work..
  11. I have a passenger door from a 240z. Good condition with no rust.
  12. I got it back in using anti seize, dry ice and rubbing alcohol..
  13. So the breather tube on the block broke and there is about 1/2" of the tube in the hole. What is the best way to get it out? Is it pressed in?? Is using a thin bladed screw driver to bend it inward the best way to go?? I went to ace looking for a tap or reverse screw but they didn't have anything big enough as Its approx 7/8" wide.
  14. az240z
    WTB L28
    I have an L28 rebuilt, bored 30 over with flat tops. Rebuilt p90 head... $1800 and I'm in Glendale, Az..
  15. Looking for 4 konig rewind center caps.. What do you have???????????
  16. Sorry I just have the passenger side only
  17. I have 280z vinyl for strut towers.. I also have some round strut covers..
  18. I have a complete R180 for sale
  19. I have 3 harnesses. Some have connectors cut some don't. I think you could make one from the three.
  20. I have 2 passenger side doors from 240's. $75.00 + shipping from Glendale, az 85308 These doors only, no glass, no trim but with regulators and no rust or major dings..
